Need help on how I can make this drivetrain acceptable
Brief story- I was walking my dog and ran across a “mountain bike” a neighbor had out for bulk trash pick up. Being in pandemic times and itching for a project I decide to take the bike home. Turns out, unfortunately, that Dynacraft is the maker of the frame (Walmart bike). The frame seems to be sturdy and decent quality (guessing this), the rest not so much. So I decide to build me a cool mountain bike with it by upgrading/changing components. I have never done this before but I’m a sharp guy so what’s the big deal?
So I decide that I don’t want the stock 3x6 18-speed setup but one of those cool looking 1x11 configurations I’ve been seeing and reading about (obviously not enough reading on my part).
I bought a drivetrain set that includes:
-SunRace 11 speed cassette 11-50T
-Box Two 11speed derailleur x-wide cage
-Box Two 11 speed twin shifter
-Box Two 11 speed chain
-the crank cog bought separate has 35 teeth
So I fiddled with the derailleur adjustments and hop on for a test ride. I knew to expect some chain grinding due to the width of the cassette being driven by one crank cog. I also heard from a bike shop guy recently, as I was finishing this build, that the 1x11 setup was not really intended for a 26” bike. The chain stay is too short. Yep, it’s a 26” bike.
So when attempting to be in one of the first four gears the chain immediately derails. Mid range gears are fine. And cannot get to that highest 50T gear (will try to further adjust the derailleur). What I now have is a six speed bike that is really slow.
I have questions. Can this even be made to work correctly? A longer crank axle? Some kind of chain that has more flex? So I’m a guy that didn’t research the mechanics involved in making this change but I’m kinda enjoying the learning aspect of getting in there and doing it.
Any suggestions will be very helpful. I’m hoping to not replace too much of what I’ve added if at all possible. (I posted a pic of the bike in the Gallery yesterday but wasn’t able to add it to this post due to being new to the site).
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
The chain will become more flexible as it breaks in, but it still might not work due to the short chainstays. Is the chain too short for the big cogs?
A smaller cassette (11-42) might work.
Great tip about checking the chain length. I’ll check it out. I imagine that is only going to be a factor on the large 50t cog not lower ones. And true, the chain would not be broken in at this point. Thanks
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Box has good instructions how to set up their RD and size the chain. If you follow them it should work. In high gear with the suspension topped out it should have just a little tension and set the indexing, in low gear you adjust clearance from the cassette to the jockey with the b-screw. If you choose to size the chain in the big bottom gear like old style, you also need to have the suspension compressed.
The front ring is a question mark. 35 is an oddball. Narrow wide rings have even number of teeth. If it’s a single speed ring it needs to be for 3/32 chain. If I t’s part of a double or triple you need to get rid of it, they are made for shifting and chains don’t stay on without a derailleur or chain guide
Likes For Darth Lefty:
Likes For DMC707:
Quoted: 166 Post(s)
Liked 252 Times
One thing I do know the OP can probably ditch that bash guard its not gonna do much.
Disco Infiltrator
Liked 2,102 Times
I am asking this because I don't know, but why would the suspension movement matter on this bike? it looks like the crank is on rear suspension triangle so wouldn't it stay the same during movement?
Another thing to consider is the chain line. If that crankset is from a single speed as appears, it may have a chain line further inboard than ideal for the cassette. Can be solved with a bottom bracket spindle the correct length.
Genesis 49:16-17
Genesis 49:16-17
You are right, I did not look at the frame too closely.
Likes For prj71:
