Do you put patched tubes back in your saddlebag?
#101
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,211 Times
There's lots of environmental and work safety pressure to eliminate the use of cyclohexamine, and there are alternative chemistries that work just as well. the zinc thiocarmates require an activator, which is usually stearic acid, or zinc oxide in combination with stearic acid. None of these require use at levels that show up on SDS, because the SDS is about work place and transport safety, not reverse engineering the trade secrets of products.
Zinc oxide, by the way, wouldn’t be in any vulcanizing fluid for patching. It’s not soluble in the organic solvents used in any of the fluids, whether rubber cement or vulcanizing fluid. It seems to be used in the hot vulcanization
I know that the SDS isn’t for reverse engineering a product but it can give valuable information on what’s in a substance.
Stuart Black
Stuart Black
#102
The spoke bolts inside all wire wheels I ever had sooner or later make pin-hole leaks in the inner-tube. I tried care in placing the rubber gasket in place which is supposed to prevent this but it still did not work. I purchased a set of smooth interior mag wheels which have no wire spokes and no spoke bolts and it has been almost two years with never a leak since. The wheels came from China and claim to be lighter than wire wheels but since I do not compete in races to ride into town for my groceries I don't care.
#103
Bikes: road: 1999 GT road:40Kmi+ // 2001 fuji finest AL:9Kmi+//1991 schwinn paramount ODG:0.1Kmi+
Quoted: 19 Post(s)
Liked 10 Times
unless you know of a problem with your patching technique - they should be better than new
(now one place is 2 layers deep )
#104
Quoted: 2601 Post(s)
Liked 1,925 Times
#105
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times
Not to jinx myself, but I must be living a charmed life as I've gotten maybe a half dozen flats in the past 11 years (5,000 miles this year and one flat). And, most of my flats have been because the stem broke away from the tube (two of them I noticed while the bike was in the garage so no need to change on the road). So, my view is skewed based on my experience. I carry a patch kit but have never used it, partly because I'm a klutz and would probably screw up gluing it on, but mostly because my tubes have lasted a long time without flatting due to a puncture. So, I don't have practice patching and, given my infrequency of flats, I wouldn't be surprised if the glue hasn't dried up and become ineffective (I'm assuming that happens??). My position is to just toss the tube when it flats, even on the rare occasion it's a puncture - up til now, they've always lasted a long time.
#106
Replaced a flat during a ride with a new tube from my saddlebag. Brought the flat home and found the hole. Patched it. Is it safe to put it back in the saddlebag for next time or does folding it ruin the patch or cause it to tear or or anything?
I would obviously roll up the tube so the patch wasn’t on a bend but...
Thoughts?
and to be clear sure I could take out the tube I replaced with yesterday and the put the patched tube back in the tire and roll up the spare tube again and put it back in my bag but man I just don’t feel like it!
Thoughts?
#107
Quoted: 1607 Post(s)
Liked 2,579 Times
We need a link for these $2 tubes...
#108
I only put a patched tube back into my saddle pack on my touring bike, never on my
road bike. I'm running tubeless on my gravel and mountain bike.
#109
Quoted: 195 Post(s)
Liked 207 Times
Thoughts?
Thoughts?
#110
Bikes: MASI CXGR, KHS Urban One 11, Trek 370 Sport, Austro Daimler Olympian
My patched tubes go back on the tire, I'll only use a spare if the patch job fails. If that happens I re-patch the tube at home and it goes back on the tire. I don't get many flats fortunately.
#111
Quoted: 195 Post(s)
Liked 207 Times
Safe? Sure. Worst case, you put a leaky tube back on and use up an inflator or some arm strength squeezing the mini pump. I reused previously punctured tubes all the time in my college days (some with more than 1 patch). Now, the $2 for a new tube seems like a cheap alternative to patching, rolling, and hoping on an already punctured tube is road worthy.
#112
One would think that after 40-50 years of riding that I could patch a tube but I've had a few failures lately right at the patch. One thing about testing tubes (overnight) is that the tube has to be inside a tire to test it under pressure. It takes very little pressure to inflate outside a tire, so it's not a solid test.
#113
Yes, install the other I had with me, and ride on. Ive used tures with numerous patches in them, for spares. As long as it works.
#114
Liked 1,925 Times
#116
Liked 2,579 Times
My first experience with patching a tire was in the early 60's on a trip down 99 to San Diego in a 49' Chevy pickup. We got a flat and my Dad pulled the split ring, hot patched the tube and hand pumped it back up. Bikes are so much harder, lol...
#117
Bikes: 2005 Seven Odonata (DuraAce /Reynolds),1983 Trek 950 (Mavic/Suntour/Regina), 1986 Stumpjumper Shimano/Suntour/Regina), 1986 MASI 3V, (Campy/Mavic/Regina) 1995 Schwinn LeTour (Suntour/Wienmann/Phil/Shimano/Regina): All Brooks Saddles
Quoted: 25 Post(s)
Thoughts?
Thoughts?
#118
I'm mostly on tubeless these days, but I still have one set of wheels that's tubed, or sometimes. And on those, I've taken to putting ~15-20mL of sealant that I use on my tubeless wheels, into the inner tubes. Pulled a 1.5" staple out of a tire this past summer - spit a bit for ~5sec., but then I rode the 20km home still on ~100psi.
#119
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 249 Times
Likes For rekmeyata:
#120
Bikes: CoMotion Tandem (Rohloff), Surley LHT,, Bike Friday, Specialized Vado
Funny, as another person mentioned I also run the patched tube and only carry new tubes in my bags. A patch can fail if it's not done well, something I don't want to find out after the tube in my tire also has a hole in it.
Something I see very rarely so I always mention it: the spare tubes I carry are wrapped in duct tape or masking tape. This prevents them from wearing holes in the corners as they vibrate around in your bag. I get so few flats that a spare tube might be carried around for a year or two and many thousands of miles. The last thing I want is for it to be full of holes and completely useless!
Likes For Bill Abbey:
#121
in my experience (5000+ miles/yr for 30+ yrs), the cost of the tube matters very little, but a patch always affects the feel of the ride and eventually works loose. To each his own i guess.
#122
Quoted: 195 Post(s)
Liked 207 Times
Wow. Glad I never raced against you. Anyone that can tell they are riding on a patched tube has sensitivity far beyond my abilities. I've had some patches fail to work but I've never had one fail once it's successfully holding air. Lucky I guess.😊
Likes For Cycle Tourist:
#123
T
funny. Keep the wheels down friend.
#125
Liked 249 Times
When a patch works its way loose at any time that means you prepared the tube wrong, I've never had either a glue on or a glueless patch eventually work loose...well, as long as the glueless patch was a Park, I used a few other brands, even the well known Lezyne, those don't stick for more than a few hours, but the Park brand will stick for the life of the tube.
