Do you put patched tubes back in your saddlebag?
#176
Quoted: 152 Post(s)
Liked 173 Times
Because the Lezyne patches suck. They stick for while but then leak eventually. You were the one who mentioned it first and I was agreeing with your post. Park are fine, I've never had a problem with them.
#177
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 253 Times
Got ya. I tried Lezyne myself and they did indeed suck as do all others out there besides the Park. I haven't been able to confirm this but I think Topeak Flypaper glueless patches are the Park patches with the Topeak trademark emblem printed on the patch itself, otherwise, they look exactly alike.
#178
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,215 Times
Stuart Black
Stuart Black
#179
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Tirichloroethylene in the Rema fluid is a rubber solvent and softens the tube to make it integrate with the glue and patch. You cannot arrive at a similar effect running dry.
#180
Liked 253 Times
If that is true what I said, then is Park making the patches for Topeak under the Park license?
By the way, Lezyne patches were among the worse glueless patches I've ever used, along with Skab which I think they sold the name rights to Slime some years back. Here's the interesting thing as to why I brought that up, I heard that Gorilla Glue company made a tough black tape, so I bought some and cut a square piece and applied it to a tube that had a hole, that darn Gorilla black tape held up just as long as the crappy glueless patches from Skab and Lezyne did for a lot less money, so the Gorilla black tape will get you home, but that's about it.
#181
Liked 4,215 Times
I'm not so sure Park worked with 3M, I could be wrong, but here's what I remember. When I first started using glueless patches they said 3M on the box, I used those for maybe 10 years, then 3M stopped selling them and I was told that 3M didn't want to be in the bike business and sold the rights to Park.
Gorilla Tape might work but It’s not going to be very permanent and will probably ruin the tube for a cold vulcanizing patch.
Stuart Black
Stuart Black
#182
I replaced my spoke wheels with magnesium alloy wheels from China I got on ebay. That was more than two years ago and the causes of so many of my flat tires was pin-hole leaks from the spoke nuts even though I had rubber gaskets covering them. Since I changed to wheels with smooth interiors I have not had a flat tire even after putting more miles on my bike than I used to. This has been more than a luxury to have freedom from flat tires upsetting the apple cart in my life when I needed to get to appointments.
#183
Quoted: 961 Post(s)
Liked 1,628 Times
I wonder... Could sanding and polishing the heads of the spoke nuts have remedied this problem? Could you have sanded and polished them on the wheel?
#184
That might have worked but I was unwilling to trust it because replacing the wheels guaranteed an end to this problem. I also like the look and style of mag wheels which I had painted with premium urethane paint the lime green color of the Chevrolet Spark. The seller claims they weigh less than most spoke wheels and the are probably stronger, but I am not a competitive rider so even if they weigh a pound or two more, I would never notice.
#185
I don't trust spoke nuts enough to try it.
There is no guarantee it would have worked but the replacement wheels were a 100% way to eliminate the problem. I also like the style of the mag wheels better than spokes. The ebay seller claims they are lighter than steel spoke wheels but even if they are not, a pound or two difference is inconsequential because I use my bike for transportation. I do not compete in bike races. While I know of no destructive strength tests to make a comparison, I think the claim mag wheels are stronger is credible. Either way, like spoke wheels they are more than strong enough. Another virtue is I never have to suffer the tedium it inflicts to true up the spokes,
Likes For drbarney1:
