my modified FSIR spin 5.0
...yes, they are more fiddly to adjust but i did it once and never had to do it again. I dont miss the stopper it folds in both directions. The one thing to concern about that i see is the stock cable routing with V-brakes, that i changed on my Spin2, my Spin5 has discs.
Likes For splithub:
Concerning the brakes of your spin2 what you changed? I have new cables coming in, but I certainly can't fit brake disk as the frame do not allow for them.
Clamp force seems sufficient to me.
I changed the cable routing to allow longer brake arms to accomodate thicker tires. Space is tight on the Spin2. Spin5 seems fine as i see on yours. Side effect is that it can fold now both directions, but there is no benefit of it other than choosing if you want to have the handlebar stem outside or the drivetrain.
..before i forget, did you come across the flaws of that bike, they were discussed here partly already. The frame halves tend to rotate harder slowly until you cannot separate them without danger for damage, and the bottom bracket height is beyond acceptable, in my case 31cm with 1.75 tires. Tried different things to fix
Likes For splithub:
thanks clear, I already have long arms which accommodate perfectly big tires and the fender. I see you are using from the picture above the litepro, which would not work for me because of the fender width
The bottom bracket height I will check how much is mine, but riding it I don't think I see big difference with another bike. What is the issue you have identified with the height? and which fixes? thanks :-)
PS: measured and same height for me as well
It is time for a new update :-)
Few changes made and always for the better:
- changed the bottom bracket and crackset with a second hand Campagnolo Super Record. Actually the previous one from litepro was lighter but the power transfer was not good. It was also making noises, no matter how much I would turn the bolts etc. Now with the Campagnolo super record another world
- changed the saddle with a Ritchey WCS Carbon Streem; a little lighter but especially much much more comfortable. No more pain on my back! highly recommended.
- changed the stem with a curved one, with the height fit for me (lost the adjustments possibilities although), lighter and I also think at the end aesthetically nicer
- changed the chainring with a Miche Supertype 51t. So I have lowered of one tooth (before it was 52t) which is better for the hills
- changed brake and shifter cables with some Litepro Pro
- few gold-look bolts in aluminum 7075, like the one for the brake-pads, nicer and lighter
- I have tried to change the clamps as suggested above, I did not like them, I prefer the originals, much more functional. Although I have replaced the clamp handle with the gold one of the new clamp :-)
All in all, I have been able to save some grams and the final build is now only 8.3kg!
Likes For mrsus018:
Quoted: 463 Post(s)
Liked 567 Times
User's tip: lubricate the pivot with WD-40 like spray with a thin straw introduced through the bottle cage bolts on the main tube.
