Move saddle back or get longer stem?
Hi ,
When I ride my bike i often find myself settling far back on the saddle so that I'm not really sitting on the saddle properly but more like on the back edge.
I already have a generous setback seatpost(VO Gran CRU) and saddle(B17) slammed back in the rails.
So it seems that my body naturally tries to make the cockpit longer by pushing back to the edge of the saddle. It feels like I need to make an adjustment here.
So my question , I could go for a longer stem here(current is 90mm) or I could go for a saddle with longer rails for more setback(B17has notoriously short rails).
Why would I do one over the other ? does it matter and is increasing reach a god answer to wanting to sit further back on a saddle than it allows?
Thanks
J
Thanks
J
Quoted: 6177 Post(s)
Liked 4,794 Times
Road bike?
Partly might depend on where you want the BB underneath you. The further back you move the seat, the more you are making your road bike a cruiser type bike. And the more forward your BB the more upright you'll tend to want with your position.
Longer stem will let you get stretched out more, but if your saddle is already far back in relation to the BB then you might feel scrunched up with your thighs shoving into you. In that case move both the Saddle forward and get an even longer stem. Or move the saddle forward and lower your stem.
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 164 Post(s)
Liked 92 Times
For proper fit, the saddle belongs in only one position, not to be moved fore and aft to accommodate a front end or a frame that simply doesn't fit. Set your correct saddle height and saddle setback and then and only then determine what length stem you require.
Likes For gkamieneski:
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
Generally speaking, saddle position is determined by balance on the bike, not reach. Reach is the last thing you adjust, and you do it with the stem. When your balance is correct, your hands are light on the bars and in fact can lift them up briefly while pedaling without sliding forward on the saddle.
It is possible that you will need a saddle with longer rails to get a well-balanced position.
After your saddle is correctly positioned, your reach is optimal if your upper arms are square off your torso with hands on the hoods.
Results matter
Results matter
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I think the basic fitting procedure is to get your saddle positioned over your bottom bracket first (to a configuration that feels right), and then work on handlebar position that gives you the angle of lean than you want.
For me, a Brooks B17 set all the way back on a VO long (30mm) setback Grand Cru seatpost set all the way back puts me in the ballpark. After that it's just finding the right bars and stem to get my hands in the position I want.
A B17 is a hammock saddle, that means you can't move much fore and aft on it, and the saddle fore-aft position is kind of critical. So you have to figure that out first.
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
Yes, the correct balance on the saddle. Get the saddle positioned first.
I like this saddle position method video. The goal is to get the saddle where you don't either slide forward on the saddle or have difficulty lifting your hands off the bars.
The test starts at the 4:00 mark, but the whole video is useful.
This method worked great for me. And with the bars at a good height, I can ride in the drops as just another hand position, not only for extreme headwinds or steep downhills. It's so nice to switch between drops and hoods on longer rides. My bars are considerably higher than his example bike.
(with my somewhat curved back Fizik saddle, I have the nose slightly up from level. The horizontal part of the saddle is now closer to the back, just right for me. That's very common with Brooks saddles too.)
Likes For rm -rf:
Quoted: 41 Post(s)
Liked 11 Times
One possibility is that your saddle is too LOW. Sliding back could be your body's way of getting the increased leg extension it wants. Try raising it 5 - 10 mm, see what happens.
Liked 4,794 Times
When doing the balance test, note that he did say to be doing it at the cadence and resistance level that closely matches your typical riding experience. You won't get it right if you do it while not moving or with way too light a resistance.
Quoted: 1034 Post(s)
Liked 1,289 Times
It is entirely possible that the opposite is true. I found myself scooting back on my Brooks, when my seat was TOO HIGH. I was not stable on the seat, so I would scoot all the way back to prevent myself from sliding forward, and to relieve pressure on the perineum. I have since dropped the seat slightly, after advice from Steve Hogg's site, as well as others, and now I sit stable on the seat, and do not feel the need to scoot back. What seems obvious, isn't always the case.
Quoted: 164 Post(s)
Liked 92 Times
Saddle height and saddle setback are calculable dimensions solely relying on lower body measurements. That's why I am saying that there is one and only one saddle position. After that is set, you can calculate what your upper body position should be on the bicycle. Meaning, is the frame stretched out enough or too much for you and what size stem is required as well as can the bars be set low enough beneath saddle height. So, basically stack and reach.
Liked 1,938 Times
Results matter
Results matter
Quoted: 164 Post(s)
Liked 92 Times
Yeah, that's why bicycle fitting is such a big business. They know you're going to rely on "using your body as a measuring tool" and that you will be coming back to them.
Liked 1,938 Times
Improve reading skills. I said "only your mind," not someone else's. If it were as simple as you say, every bike would come with written fit directions and neither this entire forum nor fit calculators would exist. Fortunately (my view of course) we are all different and so are our bikes.
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 164 Post(s)
Liked 92 Times
"Your mind" may trick new cyclists into thinking that a cushy, wide saddle and upright position to the handlebars is the right fit because of the comfort factor. But at least with a road bicycle, that's most likely not the proper, efficient fit.
That's why I emphasize properly fitting the engine, your lower extremities, to the correct saddle position, fore/aft and height, and the correct frame size, then worry if the frame and/or stem and bars are in the right position for your upper body.
I doubt we're expressing opposing views, but I surely hope novices are not reading this thread and coming away thinking that what feels best to them in the showroom is necessarily the right, efficient fit.
Liked 1,289 Times
Yeah, no. Bike fit is not a set of angles and numbers. If a fitter fits that way, they are no good. A bike fit requires the fitter to watch how the person interacts with the bike dynamically, not statically. In other words, using the body as a measuring tool. Too many fitters leave that part out of the equation, and people end up with seats too high, or too great of reach. Seat height is what is often incorrect by a "well trained," but inexperienced fitter. Even many fitters who have years of experience neglect the individuality of the rider, and instead rely on numbers. Those fitters need to be avoided like the plague, and unfortunately they are all too common. They, unfortunately, can cause serious injury to their clients.
Likes For phughes:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Liked 193 Times
The saddle needs to be positioned to achieve optimal leverage over the cranks - whatever that may entail. Maybe try playing around with saddle angle and height while you're at it. Then, try a longer stem if anything
Liked 1,289 Times
Back to ignore... You should really stop trying to dispense bad information. For your own benefit, I would suggest going to https://www.stevehoggbikefitting.com...or-road-bikes/ and then reading through his articles. Here is another: https://www.stevehoggbikefitting.com...ard-can-it-be/
Likes For phughes:
Drip, Drip.
Liked 193 Times
I'm not really sure why I clicked to view your post, especially after reading it. No, the saddle is not supposed to be positioned to achieve optimal leverage over the cranks. The saddle should be positioned to achieve proper balance on the bike. It should be placed far enough back so that you are not falling over when you take your hands off the bars while pedaling at a moderate load, essentially unweighting the upper body.
Drip, Drip.
Liked 193 Times
I bet you can assert many different things. Id be willing to go so far as to wager that you're just like the rest of us when you stand by your opinion as being the most correct.
adjusting the saddle can achieve better (or worse) balance on the bike, and it can also impact how your feet are positioned over the pedals (ie how much leverage you have over the cranks. )
Originally Posted by Aniki
Fore and aft is set to achieve balance over the bottom bracket
https://www.bikeforums.net/21966786-post9.html
Seriously, stop writing, start reading!
Likes For aniki:
Quoted: 164 Post(s)
Liked 92 Times
The emphasis on “balance” here is well overblown. And as far as I am concerned the input from the “balance” crowd borders on bullying of those with ancillary views.
Good luck with your “balance” when you’re trying to close a gap, stay up in a rotating pace line, etc. “Balance” is great, once you’ve set your engine correctly over the cranks/pedals, but it’s mainly for unicycles.
I first became involved in this thread when it was being discussed to move the saddle fore and aft to solve a reach problem (caused by incorrect frame or stem size). I am 100% convinced that is not the way to go.
Liked 1,289 Times
Of course moving the saddle to solve a reach problem is the wrong way to go. That is what everyone, except the moist one is saying.
Senior Guest
my $0.02
I would get a couple of cheap stems in different length and a couple of cheap seat posts with different setbacks to try different positions. 5-10 mm makes a huge difference for me as far as comfort is concerned. For me comfort means riding without pain all day. I also have several different length stems to use. When I am in a very good cycling shape a slightly longer stem goes on my bike. Sometimes early in the season when I am out of shape I will put a shorter stem and and is set up higher a little than later in the season.
Quoted: 164 Post(s)
Liked 92 Times
We used to drop a weight line from the tibial tuberosity once the saddle height was correct and at the same time set the cleats so that the ball of the foot and the drop weight were directly over the pedal axle. Now we have charts and formulas to help us get in that ballpark. Multiple stems together with multiple setback seat posts introduce more than 1 variable to the rest of the calculation. Using variably different setback seat posts would again be like moving a saddle fore and aft on its rails to solve a reach problem.
Yes, use whatever saddle and seat post gets you correctly over the drive of the bicycle and then worry whether your top tube and stem will take care of the rest.
