Gran Sport triple chainring
Bikes: Raleigh Gran Sport
I have a vintage Raleigh Gran Sport with all the original components. Is it possible to install a triple chainring in order to make it more suitable for hilly terrain and my age (in my 60s)?
As I understand it, it is not possible to install a different freewheel with more speeds (currently 6 speeds). Looking on e-bay and various forums, I couldn't find a definite "yes" or "no".
The other option may be just to buy a more contemporary bike and to keep the Gran Sport only for flat terrains.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
GLT -
If your Gran Sport has the original Stronglight 93 crankset with the plain alloy chain guard, you are already set up to triple the crankset as the axle and fixing bolts are triple sized on your current configuration. Change the chain guard for an outer toothed ring and add the two inners to your choice. However, this will not be easy since these old chainrings are getting rare. Much easier is to buy a 37 T inner ring from Red Clover Components and just do a simple bolt on.
blahblahblah chrome moly
Quoted: 1173 Post(s)
Liked 2,569 Times
Pictures or detailed specs on the current parts would allow us to be more specific.
Some Gran Sports came with a Stronglight 93 crankset with a toothless outer ring as pants guard. Is that the crank you have? If so, good news, it means you already have the longer crank spindle for a triple. You just need to move your current large chainring to the position currently used by the pants guard. (Pants guard will probably need to be "disguarded", though there is a trick to save it if you really like it.)
Then you replace the current small ring with a "triplizer" ring from Red Clover. This becomes the middle ring of the triple, and the granny ring bolts to the triplizer. You can then use as small as 24 teeth for the granny, a huge improvement compared to the existing gear. Not the cheapest way to go, but it keep the bike as close as possible to original.
If you don't have that special Stronglight crank, with 2 chainrings on a triple spindle, then you might have to replace the crank bearing/spindle (bottom bracket) to get the longer, triple spindle. Buying used stuff like on ebay can make this pretty cheap but a certain amount of knowledge is needed. For example with many brands of vintage cranks, it's not obvious which length of spindle you need. Even a lot of bikeshop mechanics will lack the necessary knowledge, because its before their time. Asking questions here is probably your best bet.
Good luck,
Mark B
Quoted: 1106 Post(s)
Liked 1,327 Times
GLT -
Quoted: 5888 Post(s)
Liked 3,471 Times
As the others have pointed out, there are lots of ways to mod an old bike to make it suitable for hill climbing. A picture of your bike from the drive side would let us give you better advice. The site won't let you post pics until you have 10 posts but you can load pics to your profile and we'll post it to the thread.
If you have a stronglight 93, you could buy and install a stronglight 99 which will let you run smaller chain rings than a 93.
The point is that there are lots of ways to make your bike better for climbing hills.
It has the Campagnolo Gran Sport crankset and there is no chain guard.
Liked 3,471 Times
You can triplize it. Here is the middle chain ring:
https://www.redclovercomponents.com/..._42_Teeth.html
The inner is 74 bcd which is easy to find.
You'll likely need a longer axle or just get a sealed square taper bottom bracket in the right length.
Your rear derailleur may not be able to handle this much chain. What kind of a rear derailleur do you have?
Lucky you to live near those mountains. It's fun retrofitting an old bike for climbing and yeah that doesn't get any easier the older we get.
Gran Sport PICs added
Thank you for all the quick replies! I was pleasantly surprised to receive so many feedback in such a short time. Thanks, again.
I've just added some photos in my profile showing some details of the bike.
Liked 2,569 Times
That can be done on the alloy 3-arm version too, but it's a lot of work and not worth it unless there's sentimental value. Much easier to just source a "native" triple crank.
Mark B
Liked 3,471 Times
It's a later Gran Sport than the one that came with a Stronglight 93 crank. Yes the 144 bcd triplizer will work. You will likely need a longer axle.
The rear derailleur will need something like this to handle the triple:
https://www.somafab.com/archives/pro...ur-cage-plates
That's a very pretty bike. Fix it up and keep riding those mountains.
Liked 2,569 Times
You can also get the Soma Rally-style long cage that bolts right onto your derailer, which will give you the needed extra chain take-up to allow the triple chainwheel.
OP's pics from his profile album:
-Mark B
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Which version of the Gran Sport crank? Campagnolo made at least three different Gran Sport cranks; one with 3 arms and a 116mm BCD, one with five arms and a 116mm BCD, and the third with five arms and a 144mm BCD.
The five arm, 144mm BCD crank would be the easiest to convert, as there are tripilizer rings available. The others could be problematic.
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
...and as bulgie recommended the Soma long cage conversion for your Gran Sport RD, it will allow you to move up to at least a 32T and possibly a 34T sprocket on your Suntour (my best guess from the picture) freewheel. I'll post a picture shortly of my set-up which is similar (Photobucket is down at the moment).
Bob
Bob
Ah, I didn't see your post until after I replied about the 3-arm crank. I see now your crank is the 5-arm, so you'll be good to go with a Red Clover triplizer ring, a longer spindle, and any 74 mm inner ring of your choice.
-Mark B
-Mark B
