Teach (___) How to Choose the Right Size Stem
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
I know this is a very difficult topic with many differing opinions. Let's keep this concise and try not to coincide with each other opinions too much.
The top tube length of most bikes is usually designed around the use of a 100mm stem in mind. This means that anything more or less than whatever length stem the bike was designed around would be for a differently proportioned rider or use case than what the manufacturer initially intended.
like aniki said, saddle position is always going to be a starting point for frame fit. There is no "right" or "wrong" saddle position. Lets say you found a position that more of less works from the perspective of comfort and power transfer. Other than crank arm length which is a whole other topic of discussion, the next thing we consider is the stem length, right?
i learned that you should have roughly a 90 degree bend in your elbows when riding your bike. As such, wouldn't this be a general guideline for choosing an ideal stem length? Example. I have never seen, myself included, anyone have a comfortable 90 degree bend at the elbow whilst using a 100mm stem. Unless you already have achieved this right angle in your elbow, wouldn't you want to use whatever length stem it takes to achieve this?
Whether i use a 100mm, or 40mm length stem, I will be equally low on the bike, except I will be a hell of a lot closer to comfortably maintaining a right angle at the elbows with the shorter stem. Is this a good starting point?
Likes For aniki:
Quoted: 6963 Post(s)
Liked 10,962 Times
Expired Member
Quoted: 3671 Post(s)
Liked 5,424 Times
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
“ If you can’t dazzle them with brilliance, baffle them with bull$#!t “- W.C. Fields
just another gosling
Quoted: 3888 Post(s)
Liked 1,938 Times
There you have elbow bends of 90°, also greater than and less than. What's immediately obvious in any case, is that stem length has nothing to do with elbow bend, which has every thing to do with hip angle. Yeah, the more you bend over at the hips, the more you have to bend your elbows in order to keep your hands on the bars. Who knew?
Actually, I think you made an error in your OP and didn't mean to talk about elbow bend at all. I'll give you that, OK?
Results matter
Results matter
Likes For Carbonfiberboy:
IIRC, there is some research that seems to say the shoulder angle should be 90 degrees, but I don't buy it. I think I'd need a much longer stem to reach that angle. More important, it doesn't seem to take into account the variation in bone length. JMO, of course.
Habitual User
Quoted: 4944 Post(s)
Liked 8,085 Times
Drippy's Bike-Fit Misinformation and Other Bad Conclusions...
...coming soon to Netflix
Quoted: 514 Post(s)
Liked 448 Times
First get the proper height and get balanced over the saddle. Then choose a stem that gives you an 80-90 degree angle between your humerus and back, with hands on the hoods. Then readjust your saddle for balance.
Likes For oldbobcat:
Quoted: 139 Post(s)
Liked 136 Times
Moisture : I applaud your passion for bike fit and your dilligent pursuit of info. However, it seems that you often clutter your own path to progress with flawed assumptions.
In other words, the goal is good (i.e. how do I determine the best stem size for "me"), but you then put the goal out of reach by building your formula upon an unstable foundation. I have no idea why you believe that all bikes are designed around a ~100mm top tube, or that there is no "wrong saddle position". You are sabotashing your own path to success with certainty.
It is very difficult to be both curious and certain when searching for answers.
Drip, Drip.
Liked 193 Times
It doesn't necessarily promote me to get very aero though, at least for me. I'm not sure why, because my legs are not significantly longer in proportion to my torso when compared to the average.
Drip, Drip.
Liked 193 Times
Cycletography , as I continue to learn, you may have noticed that I quickly shifted my focus away from what simply works for me.. its not a useful way to learn by generalizing one type of rider proportion.
I don't get the 90 degree shoulder-torso angle recommendation, given the wide variation in bone sizes, conditioning, flexibility, and desires from person to person.
The position of the hands on the 'bars comes from the combination of, at least, top tube length, torso size, humerus size, forearm size, shoulder width, riding style (bent back vs. bending at the pelvis), degree of elbow bend, etc., etc., etc. Add to that the way a rider wants to ride (tops, ramps, hoods, drops, upright vs aero) and the handlebars themselves (width, reach, and drop). Then there's the question of stem height, especially for those of us with quill stems which can vary from essentially slammed to Technomic 9" stems. Then, those of us who use biking to get into shape (whatever shape one wants to get into) are likely to get more flexible as we cycle more, and that can affect stem length.
I know there's at least one study that shows maximum power output when a rider's shoulders form a 90 degree angle with his body, but IIRC (can't find it now) the sample size was minuscule and averaged. Meanwhile, one of the 1st photos a web search turned up was of a woman in cycling kit, 90 degree angle at shoulders ... and straight elbows, a sure recipe for pain on roads around here.
I'd say choosing a stem that obscures the front hub when on the drops (which was the recommendation when I set my bike up 39 years ago) can work - except that I understand the current standard reco is obscuring the hub when on the hoods, and that probably has some basis in evidence.
My bet is that there's no formula for stem size that doesn't cause pain for a LOT of people.
My bet is that stem lengths are chosen by manufacturers based on looks, based on the proposition that smaller stems look better on smaller bikes and bigger stems look better on bigger bikes.
Quoted: 514 Post(s)
Liked 448 Times
There's nothing empirical about that 90-degree angle. It just seems to be a decent compromise for controlling the bike, opening the chest and diaphragm, and getting power from the glutes and back muscles. And let me qualify this. It's for performance riding, road or MTB. For tootling on the bike path on a cruiser or comfort bike, that angle will be closed up as the rider sits more upright and power is less of a concern.
As for getting aerodynamic, that's all in your back angle and it's your choice to go as low or high as you want. It's a matter of simply changing the handlebar height and modifying the stem length slightly, to maintain that angle.
And stock stem lengths aren't selected on looks. They're based on assumptions on the average proportions of the average rider with average posture for a given frame size. Larger frames come with longer stems because taller riders tend to need more reach relative to the cockpit length. They also tend to use more saddle setback and slacker seat tube angles to balance the weight of their larger torsos.
Drip, Drip.
Liked 193 Times
