Stupid Noob reflector question
I have this reflector on my bike and I remove it, will I need to add a spacer to make up for the missing piece on the steerer or just tighten the headset more?
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
Generally, yes, or the nut will bottom out before the headset is adjusted correctly.
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
Because you don't have the quill stem installed in that photo, you should be able to visually look down inside the top nut and see how close the upper "cap" or shoulder of the nut is to bottoming out on the top of the threaded steer tube. If that distance is pretty close, then you may need to replace the reflector bracket with a spacer.
Likes For hokiefyd:
Quoted: 1572 Post(s)
Liked 643 Times
It's a little off topic but one of the most critical adjustments on the whole bike involves the tightening of that headset nut.
Quoted: 194 Post(s)
Liked 204 Times
Well you certainly looked at the bike in question
The chances are that with that 'giant thing' fitted you will not need a spacer. Since to remove the giant thing to remove the reflector bracket, you will be able to see whether you need a spacer or not - it may be that the giant thing is all the spacer you need.
Still wondering what that “giant thing” is?
Maybe some sort of mounting lug for a front/handlebar bag?
Looks like that Miyata is a touring model. That hunk of cable floating in the breeze suggests a cantilever brake .
Quoted: 800 Post(s)
Liked 2,964 Times
mystery spacer.
canti brake hanger?
Keep the reflector; get rid of that other giant thing.
Habitual User
Quoted: 4930 Post(s)
Liked 8,062 Times
Mad bike riding scientist
Quoted: 6201 Post(s)
Liked 4,204 Times
It’s a cantilever hanger and the reflector bracket has a hole. You can see the straddle wire Special_k44’s picture.
Stuart Black
Stuart Black
SE Wis
Liked 3,389 Times
I personally would never cut the steerer and use spacers instead as it gives you or the next owner more options on replacement headset stack height or future accessories.
Likes For dedhed:
Quoted: 513 Post(s)
Liked 445 Times
I'll bet it's the cable stop for the cantilever or centerpull brake cable. Not like the bendy old things Peugeot used to use.
Perhaps something more like this one...
... would be more appropriate ;-)
