Degrees? Percentages?
I'm confused about the connection between degrees of slope and percentages of slope. I want to be real clear up front: I've looked at the detailed sciento-mathematical descriptions on the internet, and they don't give me what I want. I don't want another definition of how each is figured. That won't help.
What I want is to be able to translate--approximately, and in very broad strokes--percentages to degrees, or degrees to percentages as I'm riding and looking at maps and tour guides. As an example of what I'm looking for: I know that a 5 degree slope is going to be hard for me; but what's its equivalent in %s? Yes, the answer to that question will help me, but what I really need ... I need to have a rule of thumb to work with. Anybody willing to give me information that will get me 80% of the way to an accurate translation of degrees to percentages and vice-versa?
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
I don't know that you'll find an easy way you can do this in your head. It's definitely too complicated for me.https://sciencing.com/convert-percen...s-8093249.html I wonder if it's often necessary to do this. It might be easier to just get used to dealing with both measurements. Sort of like when we talk about bike sizes in inches or cm. Most folks know their size either way w/o actually doing a conversion. Hope this makes sense. Edit- If you use something like RWGPS you'll have consistent measurements.
Quoted: 6193 Post(s)
Liked 4,809 Times
basically rise over run for grade or percent. The other is simply a degree as in angular measurement from the horizontal.
A 100% grade will be a 45° slope.
Likes For Iride01:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
It's complicated
Best follow what's known as Eddy's Rule,
modified for reality in consumer societies.
Ride up grades before buying upgrades.
Likes For Wildwood:
OK, thanks. That helps. But a couple of questions--
1. Are those Canadian degrees? Aren't they 10% bigger than American degrees? (Sorry sorry sorry.)
2. So if 45% is (according to this diagram) 12/12m, which is 100%, then I can I extrapolate arithmatically to 6/12 would be 50% and 22.5 degrees? Which is important at the lesser angles, the ones we typically encounter riding, i.e. 2/24 = 15% more or less or 9.2 degrees? Or is there some trigonometric factor that varies it from the strictly arithmatic?
If I remember high school trigonometry, the tangent of the angle of the grade is the percentage grade. For example, the tangent of 45 degrees is 1 (or 100%).
Likes For Hiro11:
Liked 4,809 Times
- one table showing percent grade to degrees
- one table showing degrees to percent grade
Likes For John Valuk:
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
2. So if 45% is (according to this diagram) 12/12m, which is 100%, then I can I extrapolate arithmetically to 6/12 would be 50% and 22.5 degrees? Which is important at the lesser angles, the ones we typically encounter riding, i.e. 2/24 = 15% more or less or 9.2 degrees? Or is there some trigonometric factor that varies it from the strictly arithmatic?
As shelbyfv noted there is no easy way you can do this in your head. Best to use one of the calculators provided. OR, don't worry about it and just climb.
Quoted: 1461 Post(s)
Liked 1,485 Times
https://www.calcunation.com/calculat...to-percent.php
1 degree = 1.8%
2 degrees = 3.5%
3 degrees = 5.2%
4 degrees = 7.0%
5 degrees = 8.8%
6 degrees = 10.5%
7 degrees = 12.3%
8 degrees = 14.1%
9 degrees = 15.8%
10 degrees = 17.6%
I'm curious as to what kind of maps/routes you're looking at that are using degrees instead of slope %?
Veteran, Pacifist
Liked 4,833 Times
Is the analysis for the purpose of general knowledge about the grades/percentages you ride? - or to measure and document the grades on given routes?
If the latter, PLEASE, come ride with me for a month - with an end goal of creating a detailed set of cycling maps Distances and elevations are readily available, but to include all the gradients and flats in those climbs is more important to many than the elevation change. Or is that already on cycling maps/apps?
There used to be a great cycling map of the Santa Cruz Mts.
What a great app! Better than GPS.
Expired Member
Liked 5,427 Times
[QUOTE=Wildwood;21984704] Distances and elevations are readily available, but to include all the gradients and flats in those climbs is more important to many than the elevation change. Or is that already on cycling maps/apps?/QUOTE] RWGPS is free unless you want some extra features. You can make your own map or look at maps other folks have done. You can move your cursor along the gradient display at the bottom to see how much you'll suffer (in %.)
Likes For shelbyfv:
Why I was asking
MSU: Thanks, this is perfect. Just exactly what I needed.
I see that people curious about what I'm doing with the data and where I see it. I'm working on strengthening my riding (and I'm a map nut, too), so I'm conscious of the grades I'm riding, always trying to bump up my threshhold.
In the process, I have discovered that cyclists and SOME maps talk about %s. But vehicles and signage and OTHER maps tend to use degrees. When I have used my pickup truck to scout routes, the truck records slopes in degrees. Because of the track, I now can more or less recognize a 3 degree slope from a 5 degree slope. But when I look at a cyclist's notes, they use percentages. But these are very, very different: a 5 degree slope is killer (for me) and a 5 percent slope is just hard. Eventually, I'll develop a gut instinct, but I'm a data-to-gut person, not a gut-to-data.
You have all given me just exactly what I need. Thank you.
Likes For Elbeinlaw:
In the wind
Please show an example of a road sign indicating slope in degrees.
Quoted: 4806 Post(s)
Liked 3,928 Times
For while you ride math in your head:
25% = 14 degrees. (Very near exact!)
10% < 6 degrees (5.71)
0.56 % per degree Edit: I got these mis-labeled!
1.78 degrees per %
The plot between percent and degrees is nearly a straight line between 0 and 30 degrees.
Edit: this is trig. Past 30 degrees and the conversion becomes less and less linear. (Down to 0.45 degrees per % at 45 degrees and 0.35 degrees per % at 60 degrees. Good thing is that we don't spend a lot of time riding at those angles.
1.78 degrees per %
Last edited by 79pmooney; 03-27-21 at 05:48 PM. Reason: Small but crucial labeling mistake
Might've put that backwards. Anyway, though, my truck measures slope in degrees, which is what started this whole thing.
Liked 2,969 Times
kick it in the 52/11 with a 10 mph or higher headwind to simulate the climb.
-Oh Hey!
-Oh Hey!
Quoted: 765 Post(s)
Liked 1,735 Times
When I saw this question, this is exactly what I thought about, roofing. I used to do roofing in the summer as a teenager, suck job, but it taught me this stuff.
Quoted: 1572 Post(s)
Liked 643 Times
What Iride said. Everybody way overestimates the number of degrees in a hill slope. 10% is a pretty serious hill when you are riding up it but it's only 4.5 degrees.
Quoted: 896 Post(s)
Liked 2,063 Times
I used to have a carpenter buddy who'd say he didn't understand math, but flawlessly calculated construction dimensions. He's shrug and say it was just numbers.
