Explain ENVEs tire compatibility list
So I have a set of Foundation 45s that I really like so far. Fully aware and on board that it requires a hookless tire and that there is a compatibility list. With the wheels being new, tires are added to the approved/not approved list as time goes on. The SES AR also require a hookless tire, and the Michelin Power Road TLR is on the approved list, but that is a hooked tire as far as I can tell. I presume these tires will also be added to the approved list on the Foundations as they are eventually tested. My question is, why would some hooked tires work on these wheels, and some don't?
www.mp-aviation.com
www.mp-aviation.com
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Quoted: 20808 Post(s)
Liked 9,450 Times
That I'm aware of, there's no such thing (in the road tire world) as a hookless tire, there are simply tires that are compatible with hookless rims.
As far as why some tires are compatible and others aren't, I assume that it's mostly a matter of tolerances - bead diameter, how much the beads will stretch after use, sidewall stiffness, etc.
Likes For WhyFi:
I emailed Enve the other day
Pirelli P Zero was on the foundation list but not on the 4.5AR Disc list but they replied saying they passed the internal testing so were fine for my 4.5s, it was too late and I had already ordered Schwalbe Pro Ones.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
I can repeat the benefits of a hookless rim for road, but is a hookless rim noticably better in practice?
Is a cyclist measurably faster or more comfortable with the smoother interface and ever so slightly different tire shape?...or are those benefits more theoretical because they can't be measured or noticed by amateur enthusiast cyclists and the real benefit is easier/cheaper manufacturing?
Liked 9,450 Times
Anyway, my overall take is: if you've bought in to wide (28mm and up) and you've bought in to tubeless, seriously consider them. If you're against or on the fence for either, then sit it out and don't worry about it.
Likes For WhyFi:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Aero is like weight, any one point of savings doesn't make any real difference, but it all adds up when you have dozens or hundreds of points of savings. In this case it moves all the numbers in the right direction - more aero, lighter, AND cheaper with few if any tradeoffs. That's pretty unusual, and personally I think this is why hookless is the future.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Comparing the Enve SES 3.4 regular to the AR, the weight savings for the AR seems significant (rims for the wheelset about 130g difference). Does that little bead hook really weigh that much? Here's the diagram of the 2 models, with the AR of note also a good amount wider and a tiny bit deeper. The AR would be more aero with a wider tire (eg. 30mm), but would this be more aero than running the nonAR with a 25mm tire? On Enve's site at least, the cost is identical.
SES 3.4
SES 3.4 AR
SES 3.4
SES 3.4 AR
Quoted: 6177 Post(s)
Liked 4,794 Times
We went through this stuff in the 70's and 80's. Must we go through this again?
I have a set of SES AR 4.5s. My understanding is this has to do with bead diameter, profile and stiffness. Giant, Zipp and Corima all sell hookless rims and all have published similar lists. I'll bet you can use any tubeless ready tire you want without issue, Enve just wants to ensure 100% safety. I blame tire manufacturers far having varying bead dimensions and not sticking to ETRTO more than Enve for being picky here. Personally, I wanted to use Gravelking slicks anyway and they're on the approved list.
I have multiple sets of both hooked and hookless wheels. They are functionally the same in terms of mounting tires and maintaining pressure reliably. All things being equal and if the industry could settle on a bead standard here, I think hookless is a superior setup to hooked beads:
1. Hookless is likely stronger than hooked beads with the same amount of material as it's just a thick wall of carbon instead of an cantilevered hook. This is really tough to prove in the real world, but certainly the hookless walls on the SES ARs are reassuringly beefy.
2. Allows a noticeably broader / more straight-walled tire profile at any given internal rim width. This is both cushier and (slightly) more aero. This is not just theoretical, the 32mm GKs I'm running measure at 34.5mm on the rims and have a very broad profile. The resulting ride is terrific.
3. Significantly cheaper to manufacture, although this doesn't really matter with Enve. Zipp does credit the price drop on the 303 with moving to hookless.
4. Can be significantly lighter. Zipp has said their hookless 303s are apparently 300g lighter than the hooked version.
One thing to note is you can't run anything close to a high pressure on hookless rims. The SES ARs have a max pressure of 80 psi (I run about 40 psi on the 32s) and Zipp has a maximum of 72 psi on the 303s.
Likes For Hiro11:
Liked 9,450 Times
I wouldn't go this far and the Conti GP5000 TL is a notable example - they've been explicit in stating that they're not to be used hookless. Basically, I'd want to see confirmation from the tire manufacturer that a particular tire is approved in hookless applications and then I'd only use sizes that are reasonable for a given rim width. There are enough of these out there currently that it's not terribly hard to find good options for whatever kind of tire you have in mind.
That 72.5psi (5 bar) figure is the most common spec that you'll see, from both tire and wheel/rim manufacturers, because it's the proposed ETRTO hookless spec (or maybe it's finally been made official, I'm not sure). Regardless, given the rim and appropriate tire widths, this really only comes in to play for quite large roadies.
Likes For WhyFi:
Imo hookless is a spiel to market cheaper carbon rims and make ppl think they are somehow "better", even if they are not really, and come bundled with a lot of drawbacks and limitations.
Liked 9,450 Times
Advocatus Diaboli
Liked 1,531 Times
There are no hookless road tire available. Every road tire out there has a side wall and bead shaped with a hooked rim in mind. A grove for the hook to fit with - Making all the marketing claims rather nebulous. Just inspect any road bike tyre you may have on hand, including any appearing on the "approved list". I cant imagine this situation changing anytime soon either, as there are also no hookless alloy road bike rims and likely newer will be as they are either incompatible with most tires or place severe pressure limitations on them
I thought maybe this was the case, but another thread had me looking at the Cadex wheelsystems/tires (Giant owned). Evidently their race tires are intended/optimized to be run hookless, and their race wheels are all hookless. And their 28mm tire has a max sidewall PSI of 115psi, fwiw.
Liked 9,450 Times
We get it. This is a cloud that you like to shake your fist at. Now can we move along?
Advocatus Diaboli
Liked 1,531 Times
Sunshine
Liked 7,473 Times
Mitochondriac
Quoted: 18883 Post(s)
Liked 10,646 Times
Liked 10,646 Times
Once you find tires you like, how often do you try different ones? Either the wheels work with ones you like, or they don't.
Quoted: 741 Post(s)
Liked 412 Times
To the previous post; If trying out different tires is of high importance, Stick with with tubes. Do know that others might have a different need from their wheels than you and limited tire selection is a trade off they will accept.
Liked 9,450 Times
I ride with tubes, so I try out different tires all the time.
Likes For WhyFi:
