Now's your chance to make a difference in the world & help this fat Dude find a bike
Hi guys,
My first ever post on a Forum (thank you thank you)
I'm looking for a bike and the struggle is real. I'm 6 foot / 6 foot 1, 350 pounds.
I'm struggling trying to find a good bike (schwinn bonafind, merax....) or should I just buy a regular bike and get some heavy duty wheels and tires ?
I'm stuck and any help would be greatly apreciated, im in canada so preferably canadian dollars if you have any reccomendations.
Thanks a bunch in advance,
Cheers!
Cheers!
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
You don't have classified ads in your area? Find a 1980s/90s steel rigid forked MTB. 26" wheels with 36 spokes. Your frame size will be 20 or 21" (in MTB parlance). There were plenty of brands with this product in that time period. 3 x 7 speed will be the gear set, with twist grip shifters, or if you're lucky, trigger shifters. V-brakes, but sometimes cantilevers. This bike is your ticket. When you find it, come back, and we'll help you fix it to your tastes.
Phil_gretz Thank you so much for the time you took to reply ! really appreciate it. Let the hunting begin...
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Everything Phil said but I might add not to rule out disk brakes and 3x8 drive train. Stay away from suspension bikes. Good luck,
You can post links (once you have 10 posts) to this board and we can give you our opinion as well.
Where are you located? Some of us like to search and make recommendations.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
You don't mention what part of Canada you are in, but if it is the part that is in "The Great White North" (AL, SK, MB, etc.) you might want to consider getting a fat tire bike that can be ridden year round, even when there is snow on the ground. I found mine to be a blast down here in tropical, sunny, warm Fargo North Dakota...
If you are over on the left coast, then that older mountain bike sounds like a good idea.
Quoted: 822 Post(s)
Liked 1,955 Times
Your other option is a steel touring bike with 36 spoke wheelsets. Fuji, Surly and Trek are examples of manufacturers that have produced steel LHT bikes for decades and would have gearing to carry weight.
You may want to check this thread on occasion:
https://www.bikeforums.net/classic-v...t-ii-2433.html
Likes For CAT7RDR:
Quoted: 522 Post(s)
Liked 227 Times
If you go searching for a used bike, enlist the help of someone who is already an avid cyclist to help you sort out the trash from the treasures. There is a lot of overpriced crap on CL in my location. Most of the decent ones are $$$.
The fact that you even considered the Schwinn Bonafide tells me that you aren't familiar with what to look for. That bike comes in just one frame size. If someone offered to sell you clothing in "one size fits all" how good do you think it would fit you at 6'1" and 350 pounds? The other thing that screams out to me is the cheap front suspension on that bike. Stick with a bike that has a solid front fork and NO suspension. I'd rather see the manufacturer use better components on the rest of the bike than sell one with nearly worthless suspension. It's a sales gimmick.
If there is a bike club in your area, contact them and ask if there is anyone willing to help you make a good choice.
Likes For VegasTriker:
Quoted: 6934 Post(s)
Liked 10,940 Times
Lots of good advice here. PoorFatBiker might also be interested in this subforum. ("Clydesdale" is a larger than-average cyclist.)
Likes For Koyote:
Clark W. Griswold
Quoted: 4332 Post(s)
Liked 3,955 Times
Hi guys,
Cheers!
Cheers!
https://bikeclydesdale.com
Unfortunately the bikes you listed wouldn't work well for your height and wouldn't last long for anyone but especially someone with some weight on them. Never heard of Bonafind but the other two brands are pretty low on the quality scale.
If you are looking to go cheaper find a larger sized bike and get someone to build some custom wheels for them for your weight and what you are doing with it. Try and find a touring bike or similar that can handle lots of weight.
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
You are in Canada like me so I will suggest a local store selling the Opus bike brand. This brand is quite popular here north of the border and has a style for just about every rider. But at 350 pounds you may break a spoke or two during use, does not matter which brand they all have similar issues with heavier riders.
Quoted: 61 Post(s)
Liked 164 Times
Hi and welcome! As was mentioned, you may want to check out the Clydesdales/Athenas sub-forum for those of us over 200lbs. There are also several of us have lost or are in the process of losing weight, if you're interested in discussing that. I'll also answer questions if I can.
If it helps, in May, 2018 I weighed 440lbs. I'm currently at 212lbs (6'2" man). If you have any questions about the process let me know.
As for bikes at your weight and height, I'll defer to others. I waited until I was under 250lbs to finally buy a bike. Before that I spent quite a bit of time on an exercise bike (mostly at a gym, pre-pandemic) and a lot of hiking/walking.
Likes For Sertsa:
Quoted: 529 Post(s)
Liked 255 Times
There are people making electric bicycles using motor bike wheels. I think it would be a good business if someone made a pedal version. These would be good for heavy people, cargo bikes, and those who wanted to ride in really rough conditions.
Bikes: 2021 Kona Sutra, Ragley parts-cycle
Quoted: 128 Post(s)
Liked 1,242 Times
I am close to your size and can echo what some have said...you might want to consider getting a steel mountain bike frame and building that up. My bike shop built this out of parts they had around the shop that probably wouldn't have gotten sold otherwise.
They started with a simple formula:
-steel MTB frame
-cruiser handlebar
-26x2.1 tires
-1x10 drivetrain
-mechanical disc brakes
I added:
-Brooks B17 saddle
-handlebar riser
-ESI Chunky handlebar grips
It has logged around 3100 miles and only left me high and dry twice.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
Just throwing this out there. I'm not sure of the brand but a gentleman in my town who was 350-400 pounds bought a electric bike. Just getting his body moving everyday with the help of the electric bike he dropped over 100lbs and some say 150lbs over the course of the riding season. The bike looked a little bit like a motorcycle to be honest and it had some beefy fat tires on it. If you can afford it I think it's something to consider.
Likes For cbrstar:
You guys are great ! I'm in Montreal Canada (east coast).
i started looking and found a lot of 1990s MTB on facebook marketplace.
Ranging from 150 to 250$ which I think is very reasonable. I'm going to try to make post post so I can share links and pictures.
I'm really happy with everyones feedback especially the tip of "staying away fro suspensions" since it's a sales gimmick. It's tough because I find those big suspensions so beautiful.
Another off the rack bike was the "Mongoose Malus" 7 speed fat bike any thoughts on that? (Alot of videos about up grades to it to make it better)
I was hoping to put under 1000$ on this bike and mainly use it in National parks here to lose weight and get my heart rate up.
thanks again guys really appreciate everyones help!
Likes For PoorFatBiker:
I don't mind if I need to drivtoup to 150 km away to pick up a bike.
Quoted: 1034 Post(s)
Liked 1,289 Times
Best of luck and whatever you find, enjoy riding!
Quoted: 529 Post(s)
Liked 255 Times
Unless you go for something heavy duty, I have found my fat bike to be stronger than regular mountain bikes. I am amazed I have not broken a wheel. I am heavy, and ride rough tracks.
Quoted: 529 Post(s)
Liked 255 Times
My bike is an X-treme 26x4.0 fat bike. It has 36 spoke wheels. I believe it was manufactured in Taiwan. I bought it in S E Asia. It has a steel frame. I cannot find pictures of this model on the internet. A lot of X-treme bikes on the internet are electric. I don't know if it is available in Canada. Just look for a decent steel framed fat bike.
Last year I weighed 130 kg (287 lb). I am now down to 111kg (245 lb). When I have time, I may start a topic on how I lose weight. I ride on a lot of very rough tracks, so my bike gets much rougher treatment than those who ride on smooth surfaces. I have broken the rear axle in the back wheel on this bike, but not spokes. I have broken spokes in other bikes.
I am the same height as you. Be aware that a regular sized mountain bike or fat bike is too small. I have raised the handlebars. I also have a long seat post and a large seat. A regular seat is just too uncomfortable for me.
If you will only ever ride on hard surfaces, a regular mountain bike may be ideal (particularly if you get one with heavy duty wheels). For mud, sand and snow, the fat bike leaves the others behind.
I also buy things based on value for money. If you come across a good fat bike at a good price, buy it. If you come across a good mountain bike at a good price buy it.
Others have said don't get suspension. I like suspension, but you need suspension that can be adjusted up to take your weight.
If you find that you break spokes, I suggest looking for stronger spokes to replace each one when it breaks. I like to learn and do this type of thing myself. If you break a spoke and don't replace it, the wheel becomes weaker, and it is not long before another one breaks, then another, and the wheel becomes unusable.
If you read some of my other posts, you may realize I often do things differently. I have mentioned using motorbike mirrors on my bicycle, and motorbike tubes, and these are only the things I have had time to write about. In the future, I am thinking of experimenting with motorbike spokes in bicycle wheels. I have not done this yet. It is just an idea I have been thinking about.
