Any sense in upgrading OLD Yeti ARC 26"?
Quoted: 2236 Post(s)
Liked 1,314 Times
^^^^ That wasn't me (the original poster). I like the bike and I don't want to get rid of it. Just need to figure out what to do with it. Part of why I do want to upgrade it is because I don't really want it hanging on a wall collecting dust. No real sense in that to me. Feels like the best course is the RockShox Rekon silver TK with the brake bosses. Then I can ride it and enjoy the upgraded fork and decide what to do next.
Tempted to get the Markhor fork, hydraulic front brakes, but it is a little bit of a can of worms. I'd need a new front wheel and new front shifter since the shifters and brake levers are integrated. Planet actually has a decent $99 old stock 26" front wheel which is disc compatible. https://planetcyclery.com/component/...em-whl1425-146
Its a bit of a rabbithole if you want all new all at once.
The saddle is easy as it is transferable bike to bike. Tires are consumables.
Bars are tricky. If you find some that fit fine but you may wind up needing to recable your brake/shifters if you go too wide. Also, does it have an older quill integrated steerer/stem or more modern threadless and is it 31.8mm bar diameter? All can be worked around but need to be considered- and how that changes if you go for a new suspension fork. Why a new bar?
You begin to get into another quandary when converting to disc. A set of mechanical brakes is a pretty cheap upgrade but the accompanying wheelset is not.
If you keep your eyes out for a donor bike for a suspension fork it may come with a disc compatable wheel. Or, worse case, you buy a front disc wheel and keep the rear V brake.
There is really no sense in buying 1x. You can convert your 3x by just using the middle ring and taking off the other two plus the front derailer but if you have rf type shifters the brake/shifter may be integrated. In the end you get no benefit over the current 3x so converting should be low on the need list.
Likes For Happy Feet:
fair weather cyclist
The Manitou, probably a few others, has a straight steerer tube which is what i needed. Also, AIR, it weighed four pounds which wasn't too punitive. Sometimes shifters accumulate gunk which gums up the internals. I've found that this can be removed by spraying WD-40 into the mechanism and letting it drain out. May need two applications..
I'm not interested in the folks that designed this bike, rode the bike or won races on the bike or if it was a pink and purple color.
What I'm asking is was there anything that set this bike apart from any other bike in that era? One the outside it just looks like many other mountain bikes of that era...26" tires, Rim Brakes etc.
Likes For pjcampbell:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Treat the bike to new cables and housing, and get some good brake housing, like Jagwire Pro compressionless.
If the Issue with the shifters is that when you push the lever it moves freely without pulling any cable, it is most likely just hardened grease clogging up the notches that the shifter needs to catch to pull the cable. This is common on old Shimano shifters. I have resurrected three sets of shimano shifters (LX, XT, and Ultegra) by flushing out the hardened grease with WD40.
Get some Kool Stop Pads for the V-Brakes.
If you want a new saddle and bars to change the fit... go for it.
Keep the rigid fork around. The bike may make a cool town bike someday.
Post pics when you are done.
Liked 1,314 Times
I had the opposite brake issue. For years I've had a disc compatible wheelset but no frames with caliper mounts. When I got the Bomber fork, which has disc mounts, I was like "finally, I can put a rotor on this thing!" Still V's in the back.
Quoted: 883 Post(s)
Liked 823 Times
Good advice from Happy Feet IMO. The bottom line is do you enjoy this bike, and if so it's worth reasonable changes. I've been on many different bikes, but ride my 2005 Santa Cruz Superlight three times a week because it's the one that I have the most fun on (1500+ rides, 23,000+ miles in 16 years). As you know, your bike is designed by an MTB innovator and constructed by a legendary welder, so you'll be piloting a classic.
Frank Waddleton aka FTW aka Frank the Welder an absolute legend who designed the ARC. Not to mention John Parker who started Yeti and some of their early riders like John Tomac, Juli Furtado, Missy Giove, Myles Rockwell...
Plenty of other really cool bikes in that area but Yeti had a cool logo and really helped a lot of talent get started and made some cool bikes with some cool colors in the process.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Maybe you are having a laugh or something or just don't understand bikes, I don't know, but the Yeti ARC was a special bike that is and was well respected and loved.
Could Lewis Hamilton have won 6 F1 championships without Mercedes AMG, probably! He is a great driver but the fact is he did it with that team, those engines and those cars (technically you could say 7 championships as one was done with a McLaren car but Mercedes engine).
Likes For veganbikes:
Liked 1,314 Times
I think it's just a disconnect that occurs when you have a wide forum with enthusiasts who come from different angles.
If one could take muscle car fans as a "loose" analogy:
You have some who appreciate the 69 Camaro. Some of those will argue about the benefits of keeping them stock, some the benefits of hot rodding them. Some others will go for the modern design and say the older cars do not hold a candle to the 2021 Camaro in terms of performance. Usually those genres create their own individual "sub" clubs where they champion their particular ethos and encourage each other. Outliers are quickly chastised and made to feel unwelcome.
Here, adherents of each sub ideology post into the same general threads and try to relate or influence the conversation from their own perspectives. Argue argue argue...
Thanks all for the suggestions. I decided to start with the new RockShox Recon silver TK fork and then see what I want to do from there.
https://planetcyclery.com/rockshox-r...hoCjnoQAvD_BwE
Probably a dumb question but although I know it is heavier than the old Judy SID SL - will the RockShox Recon silver TK have very different shock absorbing characteristics?
Quoted: 1944 Post(s)
Liked 2,164 Times
My advice is to buy a new bike and take your time upgrading the Yeti. Also build it the way you want. If you want to go 1x then set it up that way. But do the research first. Google as much as you can and make decisions based on the research. I built my 2 hardtails in 2013/14 after I had done months of researching.
I love this video. It is the reason why you want to ride an old 26er and the reason why you don't want to ride one.
https://www.bikemag.com/videos/old-bike-psyche/
John
John
Likes For 70sSanO:
First upgrade arrived today, just waiting on a Park star nut driver to throw it on there.
I ordered new wider 725mm bars, stem (because 31.8mm bars... ) and lock on grips also which come today, so I can measure the steer tube length with the new stem.
I couldn't quite tell which fork weighs more, my gut is the RockShox is a little heavier. I may throw it on the scale out of curiosity. The air pressure guide on the fork shows settings for 80mm travel as well as 100mm, so I think it will work just fine on the Yeti frame meant for 80mm travel. The Recon silver tk solo air was about $225 fwiw.
Quoted: 2975 Post(s)
Liked 1,182 Times
I guess nothing will convince you of anything here. You seem to be skeptical. It was a winning bike made by a well known designer in the U.S. out of good quality custom designed tubing. I guess you believe every single bike on the planet must be almost nearly the same and nothing could differentiate it, which is just silly. I would fashion a guess that because the bike below has a marginally similar idea in 26" 3x rim brake mountain bike with colors (ok the front is a disc, I didn't want to spend a lot of time searching so I took the first one) that you would also class that in the same realm as the Yeti ARC.
From the reputable manufactures of that era...such as Specialized, Trek, Giant...unless I'm missing something...nothing about that bike stands out to me that's any different than this one...
Clark W. Griswold
Liked 3,994 Times
A bike from a reputable bike company as Yeti can't be compared to department store bikes.
If the wins on NORBA and the World stage, being designed by the legend Frank the Welder with high end parts from a much smaller company doesn't set it apart from Specialized why should we set either bike apart from that Huffy?
Liked 1,182 Times
What sets it apart if nothing will set it apart from the Specialized (a mass produced bike)?
Frank seems like a great guy though...
https://mmbhof.org/frank-wadelton/
Liked 1,314 Times
I am not familiar with the Yeti but some bikes from that era, while looking similar to others, had far lighter frames and component materials.
The whole reason I bought my Marin at the time was simply how light it felt when I picked it up. Noticably so. Later, this was confirmed when removing components like the bars and seat post. The bars at the time (Al) felt as light as carbon bars.
While you could put it side by side with similar bikes, there were subtle build differences that added up to a slightly better bike.
It's the same today with FS bikes. They all sort of look the same but some are just better than others.
Liked 1,182 Times
The inexorable march of progress. Bikes change. In general, they always get better. It’s hard to deny. Overall I see the "better" changes in the mountain bike industry more so than the road bikes.
Clark W. Griswold
Liked 3,994 Times
Because huffy / department store bikes from that era, just like now, are made with inferior components. It's not an apples to apples comparison.
That's what I've been asking all along.
As is the case with any bike in a race...it's the rider (motor) not the bike. Whoever won NORBA on THAT bike could have done the same on a different branded bike as well. At the time and now...Yeti, Specialized, Trek, Giant, Cannondale etc. all use high end parts. That's what sets them all apart from a Huffy.
Yes it is the rider but those riders got their start with Yeti and it is possible without sponsorship from Yeti they may not have the careers they did, things could have turned out much differently.
Frank is awesome.
Liked 1,314 Times
Like road bikes and racing design, mountain bike changes are being driven by the extreme edge of the spectrum in terms of frame design, gearing, suspension and braking. That is a positive if one is always seeking to push the envelope of what is possible with a bike (big air, drops,) but not for those who fall into the less extreme end of the pool. Many people, as we see here with new people seeking a simple basic trail bike, would be better served by a more moderately designed, basic and cheaper bike. Some features like lower gearing and 29" tires translate well down the chain but others (quad piston hydraulic brakes) do not. At one time it was possible for a lay person to service their bike - now, for many, it is not. They have become dependent consumers of both parts and service which is nuts for a simple trail bike. You wouldn't believe (or maybe you would) the number of middle aged, cautious riders I see on trails riding expensive FS bikes way beyond what they need. A family going by on a summer ride on 10-15000 worth of bicycle. Many would be just as well served on technology like the Yeti if the geometry and old gearing were better. They will never approach the capability of their bikes but are being sold them anyways.
So back to the Yeti and why it may be worth fixing up if the conditions it is intended for match the design. Yep. For some trails/riding that is all one needs. Just like a Honda Civic may be all one really needs if commuting. And that's not a knock on Honda Civics. Amazingly designed machines that easily reach 500,000 miles if cared for just like that era of highly developed rigid/hardtail mtb.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
You have a valid point in that my old school Yeti , or the OP's ARC i posted a pic of earlier is not that far removed from Happy Feet 's MArin or any number of old hardtails in theory. Simply swapping framesets back then with all other things being identical would not make you 10 seconds a lap faster on your favorite trail --
So why? I dont know -- why is a 1963 Split Window Corvette worth more money than a '72 Mustang notchback? They are both just old cars right?
I raced mountain bikes and motocross concurrently in those days and YEti was one of the first avid and outspoken cross-sports marketers. They knew that MTB's in that era were popular cross training options for motocross athletes and supported several athletes like Johnny O' MAra, - who went on to become a pro mtb racer (XC) after retiring from motocross. O'MAra riding for YEti along with the likes of JEff Stanton and moto journalist Zapata Espinoza running Yeti logos on their helmets made people in the moto community curious about the brand
Jody Weisel, editor of Motocross Action magazine, even had a hand in designing the YEti Ultimate raised chainstay bike. This cycling and moto crowd inter-mingled quite a bit in those days , with Richard Cunningham even being the man behind Mantis bicycles. (not to mention, Horst Leitner, MErt Lawwill, PAul Turner, Jim Felt -- among others)
But where a lot of mountain bikes resembled road bikes with knobbies and flat bars, the YEti's borrowed design cues from old school BMX (looptail chainstays ) and cyclocross bikes (top tube cable routing)
This along with the founders vision of how he wanted mountain bike racing to be. John Parker was an oddball compared to the cycling mainstrem then. When John Tomac was hitting the Nationals for Yeti, PArker made sure he pitted out of a box van , just like the motocross teams did. HE tooled around the pits on his clapped out Indian himself , and he gave a lot of young, unknown talent their first shot.
Juli Furtado had the MTB experience of a cat 5 beginner when she won the world championship race in 1990, but she had a motor and was aboard a Yeti . Would she have achieved success elsewhere? MAybe, -- but Yeti gave the beginner with the big motor a shot. Very similar story with Missy Giove. Cross marketing by giving bikes to PAul Tracy (Indycar guy ) helped plus the early innovative ideas (carbon tubes, bonded aluminum, too many kooky downhill bikes to count , etc etc. ) plus the distinctive team color schemes and their strong ties to the moto community made YEti the bike to have for a lot of people .
Plus limited regional marketing made the bikes hard to get. There was not a dealership east of Colorado
Eventually . PArker sold out - In the very late 90's /early '00s they were swallowed up by the Schwinn wrecking ball (like Trek did to Klein, Bontrager and Fisher ) - but Schwinn had a lot of problems of their own and thus failed to really grow the brand any further . Other brands became the hip, cool and edgy face of mountain biking (Santa Cruz is the first to come to mind, but there were others )
So in answer to "why" regarding Yeti
Exclusivity
hand built and hard to get
grass roots race effort - almost like a guerilla marketing campaign
anti-establishment
pushed design limits for the time
moto community tie ins
stylish (for the time) design cues and colorways
not to mention fostering a FUN aspect to mountain bike racing
But yes - there came a time when geometry settled in to what worked on NORBA style trails and there were many similarities between brands.
Playing devils advocate, id venture a guess that the same imaginary rider , hypothetically , could pull the XT or XTR build kit and wheels off a YEti, (or S Works or Fat Chance, DeKerf or whatever ) and build a generic Supergo or Nashbar cromoly frameset from the period and have almost identical results by the stopwatch
Likes For DMC707:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
The C&V community just has to come to terms with MTB suspension forks so things like this can stop happening. It can't just be about derailleurs any more
Genesis 49:16-17
Genesis 49:16-17
Liked 2,164 Times
John
Disco Infiltrator
Liked 2,105 Times
That’s what I mean, though. No one makes NR RD’s any more either but there’s loads of them already in the fleet. This bike didn’t need the cheapest simplest 6lb fork from 2021, it needed the coolest one from Y2K. When it was made, MCU forks were mostly gone, everyone loved Bombers, and Fox was about to enter the market.
Liked 2,164 Times
I’ve got Bombers on my bikes, and a couple back-ups, but it’s over. You can make almost any component fit on an older bike, but you can never fit a larger steerer into a smaller head tube. That is where it ends.
John
John
Here is my new old Yeti current progress:
It got the new RockShox recon silver tk
New old stock RaceFace bar, stem and grips
Microshift 1x 11-48t drivetrain with Garbaruk XTR 30t chainring.
New Conti Mountain king tires
Rides pretty nice!!!
