Should I shorten chain?
Hi all
Should I shorten chain? On smallest chainring and 3-4th cog on back it skips under load, on big chainring this is not an issue.
Quoted: 809 Post(s)
Liked 1,023 Times
This problem can occur when the cogs on the freewheel are worn. This tends to happen when you get a new chain and it doesn't mesh right with the worn cogs on the freewheel. Is that a new chain? Did the problem occur after you put the new chain on?
If the freewheel cogs are worn, the best bet is to simply replace the freewheel with a new one. SunRace freewheels are relatively inexpensive and good. There is a technique to file the teeth on the cogs so that they engage on the chain better, but it is not a technique that I know about.
Let us know what you find.
Quoted: 1872 Post(s)
Liked 692 Times
You have the gear combos backwards in your photos for showing chain wrap. Show one pic of big chainring + big cog, and another pic with small chainring + small cog.
2019 Salsa Warbird
2019 Salsa Warbird
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
Likes For SurferRosa:
Quoted: 1372 Post(s)
Liked 1,751 Times
señor miembro
Liked 6,485 Times
Quoted: 206 Post(s)
Liked 460 Times
Looks fine to me. Your Derailleur still has a good amount of recoil on the small cog. It's probably a worn freewheel.
Edit: your photos are backwards. You need to have the chain on the small ring / small cog to tell for sure.
Quoted: 4806 Post(s)
Liked 3,929 Times
There is one simple reason for ensuring that big-big always works. This is especially true if 1) you ride hills and 2) if you like to ride hard up hills. Because if you do 2), you arrive at the top in reduced mental status and that first shift isn't always well thought out. If you have too short a chain, hauling that left lever back first can be very expensive. It is possible to kill the rear derailleur, dump the chain into the gap between biggest cog and spokes, damage, even break spokes, even damage or break the hub flange, scrape the chainstay with the chain, bend or break the dropout, bend the chain beyond use and probably a few more things. I've done my best to keep my research to a minimum but I've done most of these.
Too long a chain can get you in trouble but that is not common. More likely, you will hear the chain rubbing on itself or the derailleur cage and sag onto the chainstay when you ease up. I've often set up triples to too long a chain in the small-small and use it without second thought on the level stretches of long climbs rather than do two double shifts.
señor miembro
Liked 6,485 Times
Biggest issue with my bikes -- and they all have some form of Campy short cage derailleur on them -- is the jockey wheel spacing to the big cog. I just have to make sure that the chain is short enough that the upper rd wheel doesn't interfere with the big cog ... when on the small ring, of course.
Quoted: 767 Post(s)
Liked 1,898 Times
señor miembro
Liked 6,485 Times
Sorry, should have clarified that. Yes, that's right. Only one is 13-25t, the rest are 14-28t. I seldom ever use the 28t. But, when I have to, they all work reasonably well. If I ever have a problem going that low, it's with the NR ones, not the Victory or SR.
señor miembro
Liked 6,485 Times
^ Rear derailleur cage looks a little wack in that top photo of post 15. Is that the cage limit where it's hitting the stop pin/grub screw? In other words, why isn't it keeping better tension on the chain? Using a finger, can you push the idler pulley up from that position?
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Chain is at least a link or two--- too long. See how it droops in the small sprocket/small chainring combination? Remove a link and try again in that combination and the large sprocket/large chainring combination.
While we are not supposed to ride in those combinations, it is helpful to make these mechanically safe when we accidently shift there when not paying close attention, i.e. when we're exhausted from a long ride, etc..
For instance, my '71 Paramount set up for long steep climbs needed to handle a 38/50 and a 16/31, "just in case" I accidently shifted to either of those positions.
Bob
Bob
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
And the mounting pivot is fixed so no movement there while riding.
Your Campy derailers of course have plenty of offset between the cage pivot and the top pulley so respond well to shortening the chain to clear bigger cogs.
Now I'm officially lost - photos with my bike on MBK catalogue - they clearly have much shorter chain
señor miembro
Liked 6,485 Times
^ Just because they're marketing folks, doesn't mean they know everything about the product they're selling. Bike setup in vintage catalogs is often kludged.
And quite a lot of informed people, either to avoid a big double-shift, or because they're 3/4ths of the way up a climb in 95-degree heat and pushing 180bpm and find themselves in need of another gear and just don't think the shift over very carefully. The latter happens sometimes even to people with too-short chains who, were you to ask them in other circumstances, are completely aware that the attempted shift would make their drivetrain explode.
