Seat cover using truck tube
Quoted: 529 Post(s)
Liked 255 Times
I have large bones, and need a large seat/saddle. Regular seats are too uncomfortable for me. Just after buying my bike, I bought a long seat post and a large seat. After a few years, the top of the seat began to crack. This created a problem, as when I sat on it, the cracked part would push down and together, and pinch my sensitive parts. I looked for another large seat, and was unable to find one.
I bought some tape, and taped it up. This was good for awhile, but the tape would slide a little every time I rode the bike, eventually exposing the cracked part again. I also tried a plastic bag over this, but it became necessary to replace the plastic bags every few days.
I decided to try a piece of old truck tube over the seat. I tied a piece of old bicycle tube around it, around the seat post. I may secure it in a better way in the future, but this works well.
i was concerned about the rubber making the back of my pants black, but this does not seem to be a problem.
With many regular seats, you slide on the seat. I found the rubber does not slide on the seat, and your pants don't slide on the rubber. Which I like better than regular seats.
If I come across something I can use for padding, I may even put that under my truck tire seat cover, to make it even more padded. If the padding goes across the top and down the sides, it will effectively make the seat even a little larger.
I don't expect the truck tube to wear through or tear, but if it does it is easy to replace. It may become brittle over time.
It does get hot when exposed to sunlight.
I have only been using this for a short time, and may have other ideas in the future. But my first impression is it is a good idea.
I know most of you are comfortable on regular sized seats, so it is easy to buy a replacement. But this information may be useful for those using less common seats.
I may even use rubber over good seats in the future, as I like the idea that it prevents sliding on the seat. For example, if you tend to slide forward on the seat, some of your energy is used to continually push yourself back on the seat.
Somebody wanting a good business idea, could make seats with a non-slip rubber, or rubber like surface.
Likes For alo:
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,987 Times
What size do you need in terms of a saddle? What are your sit bone measurements and are you in a more upright or sporty position? There are still tons of excellent saddles out there in various widths so I would get measured if you haven't already and we can certainly help find something in width. I have a feeling if you need a longer seat post maybe the bike is a bit small for you (or you just want more seatpost in the tube for safety as a bigger rider).
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
A saddle needs to fit, but the more you ride the more you realize that padding is the opposite of helpful, since it moves pressure from your sit bones which can condition to take it all day to your soft tissue which really can't.
Also a sticky seat isn't good, if there's any movement it should be between your shorts and the seat, not you and your shorts.
Pushing some back into the seat can be a good thing as it means that some of your weight is on your arms rather than your seat. Also pedaling harder gearing gets alittle weight on your legs and off your rear end.
Quoted: 529 Post(s)
Liked 255 Times
No doubt I will come across another large seat in the future. After all, I found the one I have.
I am in a place where most people selling on the internet don't deliver to.
I am also in a place where things are cheap. I can buy a new regular seat for less than $2, but they are too small. The large one I have, I bought for less than $10 used. It probably came from a used bike. They import a lot of used bikes from Japan.
What I have done with the rubber works well, so I am happy to continue using it. I actually picked up a damaged tube from a place that replaces truck tires. It was free.
It is not sticky, but it is not slippery either. Where you sit, you stay. I like it. I may do the same thing with good seats in the future, because I like the idea of not sliding on the seat.
I have only used this for a few days. In the future I may have other ideas.
I am a person who experiments with new ideas. Some things I try, and find out they are not good ideas. Other things work well, so I continue to use them. I posted recently about putting motorbike mirrors on my bicycle, and using motorbike tubes in my bicycle. The mirrors, motorbike tubes, and rubber on my seat all seem like good ideas during the short time I have used them. See what i think about them in a couple of years time. In most cases I am saving money. But it is not just about money. For example, motorbike tubes are more expensive than bicycle tubes. But I like the idea that they are tougher. It will probably be much longer before they become unreparable, compared to bicycle tubes.
Some things I have done, and am planning to do with my bicycle, I have not shared yet.
What you can do with your bicycle is limited only by the creativity of your imagination.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Do you mind telling us where?
Quoted: 529 Post(s)
Liked 255 Times
S E Asia
A lot of things being delivered have been stolen. People have not received them. So most people refuse to send things here. There are a small number of companies that deliver here, but the cost is very high, which normally makes it not worthwhile.
The things available in shops are very cheap. The only difficulty is with things not available here.
Quoted: 930 Post(s)
Liked 393 Times
If you end up trying to ride more, you'll eventually come to understand why this was a bad idea, and why the things you are trying to avoid are actually important.
But you seem uninterested in the explanation of why, so that will be for you to re-discover the hard way.
Likes For UniChris:
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
