Can one tell a frame is bent by riding no hands on the bars?
Dopamine Junkie
Hi all, I have a friend who is looking at a 2003 steel framed bike to purchase. The description looks good. If the bike is still available, we are going to go look at it tomorrow. I will inspect the frame for cracks, of course, but I'm wondering how to check to see if it's bent. I found this thread on BF. The consensus is to measure both sides with string but I don't want to get into that if I can avoid it. One comment was that one can ride the bike with no hands on the handlebars and, if it won't track straight, then the frame is bent. Is this a reliable measure?
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
No that is not a reliable measure a reliable measure is using proper frame tools tools that are made for this very purpose. You could use string and that will be a lot more reliable than taking your hands off the bars and taking a wild guess.
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
The reasons why "riding no hand is not reliable".
1) If the headset is loose, the bike might be twitchy and you won't be able to ride no hand
2) If the headset bearings is too tight, the bike will want to pull in one specific direction
Neither of these poor ride feel actually lets you know whether the frame is true or not
Also, I once repurposed a vintage Specialized Crossroad from the original flat handlebars into drop handlebars with STI controls and that bike, no matter what I did was very difficult to ride with no hands. So, the test riding it with no hands on the bar method wouldn't let me know whether the frame was okay or not.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Dopamine Junkie
Thanks, everyone, for your comments! Thus far, though, the impression I'm getting is that riding no hands, if the bike won't ride straight or is too unstable--that tells you there's a problem, bent frame or other problem. But what if the bike rides straight and is not unstable. Does that tell you the frame is not bent? Let me put it a better way: Has anyone had the experience of riding a bent frame that did ride straight?
Clark W. Griswold
Liked 3,994 Times
I don't ride bent frames and wouldn't suggest anyone else do the same. I would at least use the string and ruler method and double check or just pass on the bike. Why are you trying to not do this? Are you afraid of string or frame alignment tools or are you too cheap for string or do you just want to sing Flobots-Handlebars while actually doing that?
Sr Member on Sr bikes
Concur with above. Just because you can’t ride with no hands doesn’t mean the frame is bent. Once on a rebuild I inadvertently replace the top and bottom bearing races for the headset inverted (top on bottom, bottom on top). That caused the bike to no steer properly, and couldn’t ride with no hands. Once reassembled it correctly...steering was fine and I could ride it no hands.
Dan
Dan
Friendship is Magic
Bikes: old ones
Quoted: 26423 Post(s)
Liked 10,380 Times
It's not a good test because it doesn't really tell you much. Compare it with taking your pulse and blood pressure, then trying to diagnose an illness.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I had a older Nishiki 80's road bike like this. It wasn't until I was putting on a nicer upgraded set of wheels that I realized the new wheel simply didn't want to align. I realized the previous owner had offset the dishing of the old wheel very slightly to compensate. Most bikes don't need to be perfect and the beautiful thing about steel is it's easily repairable. One possible sign is poor shifting but there's lots of other things that can cause this.
Very glad for the confirmation that the inability to ride “no hands” is NOT the go to test for a bent frame. I have one bike that I find very difficult if not impossible to ride “no hands”. Until now, I’ve been convincing myself that it was due to a bent frame. I will definitely be looking into the other potential culprits in the near future 👍.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
The first thing I would check is the headset.
Quoted: 4208 Post(s)
Liked 3,874 Times
Most of the bikes I've owned and made have had me have to slightly lean to the left to track straight. I consider the likelihood of all those bikes all being off in the same direction rather slim. Instead I assume it is me that is not even side to side (leg length, spinal curve, overly dominate side).
I would also consider removing and reinstalling the front wheel "backwards" (if no disk brake) to see if it settles into the fork symmetrically. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 252 Post(s)
Liked 67 Times
Is the bent frame problem because it is no longer safe to ride? Because if it rides straight with hands off, it 'works as it should' and 'what more can one want'? You won't end up with un-ridable bike if you bring it home. But I surmise it is the safety issue.
I think OP doesn't want to use some measuring so as not to offend the seller by being too suspicious, to keep the bike inspection meeting amicable so to speak. Can always say, he is checking the bike for fitting, it could pass if the seller is not too knowledgeable when it comes to bikes.
I would look at overall setting of the seller's place, if it raises or allays suspicions. Just general advice for any secondhand buying. The bike's paint shouldn't look newish (I assume bent frame might show some signs in the original paint or the newish re-painting might indicate there was a trouble with the frame. New paint finish is always suspicious.
+1 riding with no hands is not a reliable way. Road crown alone can give a wrong impression. If that is your only viable way then find the flattest piece of pavement, a playground might be a good option. The down and dirty home-brew way is to "string" the bike and take measurements. If the seller gets miffed at you stringing the bike, maybe yoiu shouldn't be buying that bike. If they have nothing to hide they should not object.
Clark W. Griswold
Liked 3,994 Times
Likes For veganbikes:
Dopamine Junkie
Many thanks to the experienced many who kindly took the time to give feedback. My buddy bought the bike without even riding it because the bike had no brake pads and the tires were flat! Hopefully the seller was not lying about having never crashed it. We shall see. For the benefit of those who took an interest in the question, I will post an update once he has ridden it (with brake pads, that is...)
Clark W. Griswold
Liked 3,994 Times
Quoted: 194 Post(s)
Liked 204 Times
I used to ride no hands a lot. I mean the handlebars were there to hold the brakes, or something to pull on for really steep hills - that kind of thing.
You can tell a lot by riding no hands, but it is much simpler and quicker to learn to use a piece of string and how to examine a bike than learning what your bike is doing no handed. Bent frames tend to lean, because you need to shift your position to compensate. Loose or stiff fork bearings should be felt before getting on the bike, as well as wheel alignment in the forks and stays. My folders are *****y no handed as their forks are relatively straight, and will snap to the side with little warning unless the surface is really smooth.
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 252 Post(s)
Liked 67 Times
If a seller has issues checking the frame for not being bent, then that is not a seller I want to deal with. If they are trying to hide something, why would I want to buy that bike from them. A seller should be upfront and honest about the bike or you shouldn't buy it.
Clark W. Griswold
Liked 3,994 Times
That is one valid interpretation, what I had in mind is that the buyer doesn't want to make the seller look like a crook, showing him that he is suspicious of him by taking measurements. There are people like that who want to be nice to others. Not the way to do business but here you are.
Quoted: 14 Post(s)
Liked 37 Times
Never would work for me. I have a crooked spine and when I think I'm standing equally on both feet, i have 70 pounds is on my left foot and 90 on my right foot. I have to adjust for weight imbalance when riding with no hands.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Riding without hand will tell you if one of the following is off:
1. Frame / fork alignment.
2. Wheel dish.
Which one? Requires further inspection.
=8-|
2. Wheel dish.
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Liked 2,974 Times
better to determine it by the psi on the right side of the rear's tire looking at it from the left chain stay with a L.E.D. light.
-Oh Hey!
-Oh Hey!
