Chain Falls Off
Old 04-09-21, 09:43 PM
bikehoco
Quoted: 180 Post(s)
Liked 85 Times in 53 Posts
Chain Falls Off
I have a 3-year old Trek hybrid. When starting up a hill, I downshifting from 3 to 2 on the front chain ring and the chain falls off. Is it because I'm not pedaling fast enough or an indication something mechanically is wrong?
bikehoco is offline
Old 04-09-21, 10:21 PM
MRT2
MRT2's Avatar
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times in 146 Posts
Does the chain fall off when shifting from the big chainring to the middle one when you are peddling on flat ground?
MRT2 is offline
Old 04-10-21, 01:37 AM
alo
Quoted: 529 Post(s)
Liked 255 Times in 185 Posts
There is probably something out of adjustment.
I suggest you be more specific. When you say the chain falls off, do you mean it goes to the inside of the small chain ring, or something else?
alo is offline
Old 04-10-21, 09:12 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
Which cog are you using in the rear when you make this shift? If you are on the largest rear cog with the chain on the large chainring you should shift the rear a couple of cogs smaller before you shift the front
alcjphil is online now
Old 04-10-21, 10:26 AM
bikehoco
Quoted: 180 Post(s)
No
bikehoco is offline
Old 04-10-21, 10:41 AM
MRT2
MRT2's Avatar
No
If the chain only falls off when going uphill, it might be something to do with your shifting technique. Maybe try easing off the power as you shift, or better yet, get in the habit of shifting to the smaller chainring before you get started up the hill.
my wife had this problem on her triple. We went so far as to replace the front derailleur with a better one, but she just couldn't get the hang of it. I "fixed" the problem by removing the big chainring and putting a chainguard on, forcing her to ride in the middle chainring all the time.
MRT2 is offline
Likes For MRT2:
Old 04-10-21, 03:59 PM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
It's something mechanical, unless you're back-pedaling a little when you shift.
wphamilton is offline
Old 04-11-21, 09:34 AM
MRT2
MRT2's Avatar
My wife had a knack for throwing her chain when trying to shift going uphill. She insisted there was something wrong with the bike. I rode her bike uphill and couldn't replicate the problem. Took it to the shop and had the bike mechanic take a look at the shifter and derailleur. Eventually they did replace the front derailleur mostly because the shifting was clunky, and they replaced it with a Sora, which shifted better. But even then, it was like clockwork. At least once a ride, she would throw her chain, and we could have to stop so I could put the chain back on the chainring. I think she is more of a masher in her peddling technique. I asked her how she rode up hills, and she said she hung on the biggest gear possible until should couldn't pedal anymore, then she would shift to the smaller chainring.. I told her that isn't how you ride up hills, but trying to coach her up didn't work. Honestly, she probably would be better off going with a 1 x setup, but that was a bit expensive to do on a (then) almost new bike, so we effectively turned it into a 2 x,by removing the big chainring, and also switched up the cassette from 12 - 26 to 12 - 32 so basically she almost never has to use the left shifter. It is a hack, but at least I am not getting my hands dirty every ride fixing her chain.
MRT2 is offline
Likes For MRT2:
