Vintage 'Winchester' roadbike help required please.
Hi all, I wonder if anyone can possibly help me with some, if any, information about my vintage roadbike ?
It's got a 'Winchester' emblem on it, but it's not the gun company emblem. This one has what looks like a 'Roebuck' and a Crown in diagonal corners and Winchester across diagonally the respective corners.
it's a very light frame, 2665g to be exact. The frame is constructed of Nervex lugs that are all brazed into the tubing.
it's a very beautiful bike and has been commented on many times, and is lovely to ride. Unfortunately it's started to rust out, so I want to restore it back to its 70's look, however I'm really struggling with info on what it is, who made it and when. But most of all, quite frustratingly, what colour schemes they were released in and the ancillary equipment?
Please can anyone help as I've spent hours and hours on the net researching and the only thing I've ever found was 3 photos of 1 yellow bike on this forum some years ago, which was identical to mine ! But there was no info other than it might be Japanese in origin.
kind regards Steve
kind regards Steve
Quoted: 3803 Post(s)
Liked 6,626 Times
Steve, some years back I bought a Winchester from a local seller. Pics below. You can see it had a "Made in Mexico" decal and consensus was that it was a Windsor-Mexico/Acer-Mex product.
Likes For nlerner:
Quoted: 3463 Post(s)
Liked 2,826 Times
Looks like a private label Windsor - close to the Carrera model.
braxton might have been the importing shop.
Likes For repechage:
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
With a white example... your color choices have doubled! Looks like a cool project, as I like the weird off brand stuff... I'm sorry I can't help you out, other than some encouragement.
Liked 6,626 Times
Likes For nlerner:
Likes For Sluggo:
Winchester starting to make sense !
OMG !! Thank you so much nlerner! That is almost identical to my bike! Same Emblem and lugging.
I just received a post on another site saying that he also thought it was a Windsor and made in Mexico!
I can't believe it. I've spent so many hours on the net trying to find just a scratch of info about this bike and come up with nothing.
I stripped it last week ready for a restoration as it had previously been sprayed to a poor level and rust was coming through. On shot blasting I came across a metallic purple colour underneath so now I have somewhere to go with. I'll see if Windsor had this colour in there inventory.
You can't believe how much you've helped and pleased me.
many many thanks to you.😊
Likes For Stevewinchester:
Who is 'Winchester '
So again many thanks to nlerner for his enlightenment on the origins of my bike !
But the question still remains 'Who Are Winchester' ??
I live in Dorset UK, and down the road is a town named Winchester! This may have thrown me off the rite track when trying to identify my frame etc ?
I know in the US you also have a Winchester?
But if my bike is a Windsor Mexico, then why does it have a Winchester emblem. Who are they? Why was Windsor selling them frames ? Are they like Cosworth are to Ford or Lotus to Ford ? Using a base frame and then custom building for clients or building there own line of bikes based around the Windsor frame?
Someone must know the Winchester branding.
Quoted: 1372 Post(s)
Liked 1,747 Times
A bit off topic and definitely not a road bike but I had this for a short while. Wish I had hung on to it. The bike was extremely heavy but felt like it would just keep going and going, once you got it going...
To nlerner, your bike is a dead ringer for mine, but have you ever got any closer to finding out what the 'Winchester' emblem is about, seeing as the bike seems to be a Windsor-Mexico ?
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Yep, that's an Acer-Mex Windsor. It should use a 21.1 stem. I had one that looked just like it. Although I can't help with the "Winchester" logo, I must say the paint looks almost identical to the patina mine had when I got it.
Likes For Dylansbob:
FAO Trakhak, so if I'm correct in what your saying?
Because my bike has a Windsor labelled bottom bracket spindle. Then it won't be a Windsor bike, as bike manufacturers make the frames but won't fit they're own ancillaries?
Sorry ! I'm a little confused?
Also another bit of info is that I've measured the lower bracket spindle set and my caps measure roughly 36mm/1.4inch diameter, which indicates an Italian lower bracket?? Is that correct ?
Quoted: 3802 Post(s)
Liked 3,324 Times
hello Stevewinchester & thanks for sharing this find!
cycle identical to the Windsor Carrera Sport model of ca. 1973
lug pattern is not NERVEX but rather one from Agrati
it is shown on the right in this triptych illustration -
the seat lug was offered in three configurations:
a) bare, without binder ears or Malaguti plugs
b) without binder ears but with Malaguti plugs (as shown)
c) with binder ears and without Malaguti plugs (as on your cycle)
fork crown is from the Agrati "BRIANZA" pattern lug set nr. 000.8030/U and is item nr. 000.8038
the frame has two slightly odd measurements:
a) the steerer and stem size is .833
b) the bottom bracket shell is 68mm in width but is Italian threaded, 36.0mm X 24 TPI
missing pedals were KKT RTSF
missing rear mech was Suntour VGT Luxe
handlebar stem is Gran Compe
original brake calipers were DiaCompe centrepull
Likes For juvela:
Veteran, Pacifist
Quoted: 3895 Post(s)
Liked 4,822 Times
My 25" Carabella SemiPro looked nice with chrome lugs, but did not suit me as a road bike.
Wow ! All that info is amazing !
Many thanks 😊
I had an inklin it might be a Windsor, but couldn't pin the model down. My bike has a mix of dérailleurs on it which I'm gonna upgrade. Unfortunately I used the Pro model as an idea for restoration and have already ordered a Campy Nuovo Record front derailleur instead of the Suntour which I knew had been fitted to other models. Damn !
Mine has still got the original pull Dia Compe brake calipers and Compe Stem fitted.
I'm just spending a little time polishing them up to see if they are save able. Seems they are and looking 👍
Would you scrap the Campy dérailleurs and opt for the Suntours ??
Many thanks 😊
Hi all, I think that there maybe some confusion with who's bike is who's, as being a newbie, I've not been able to post photos of my bike. But now I can.
so here they come...
Liked 3,324 Times
Many thanks 😊
Many thanks 😊
apologies for the brake caliper error
me "mind" confused images contributed by nlerner with your example
stock (default) wheels were built with Sansin Matsumoto "Sunshine" brand hubs of large flange QR with small round holes in flanges
rims were Windsor - Ukai tubulars
tyres were Soyo cotton tubulars
gear block was Suntour Pro Compe
your gear mech question -
its your bike - do whatever you wish
one advantage of the original rear gear mech is its much greater capacity
keep in mind that the stock Suntour Compe V front mech operates "backwards", i.e. it is "top normal"
It has always baffled me that an Italian-style bike manufactured in Mexico was given a British name. And I would guess that it is not because the royal family had a majority share of stock in Acer-Mex. And the similar alternate name, also British, but sounding like a rifle in the US, is just confusing.
My previous post about REI was based on my unreliable memory of an unreliable comment from a bike shop colleague in 1980 or so when a Winchester came in for service. We were close enough to Seattle to see some dispersion of goods, but not close enough for good information.
We later (or maybe contemperaneously) sold Windsors for a while. Their lower- and middle-tier bikes were a solid C- for QC and workmanship.
I'm glad that I'm not the only one who is finding this whole Acer-Mex / Windsor thing very confusing ?
Especially for novice like myself. However I have learned so much in knowledge and bike structures from my efforts and all the help from the group. 👍😊
Liked 3,324 Times
thanks so much for these pictures; excellent job with them!
they show bicycle to be a model below the Carrera Sport
it looks to be the base model termed the Carrera
is the chainset it came with cottered steel?
this would explain the Windsor marking you found on the spindle centre
great to see it "in person" at last
Yes it is, Windsor written across the crank pin.
I know it all looks a bit tatty at the moment.
And the derailleur set is a mix match of rubbish! so I've ordered some Campy nouvo record dérailleurs to fit in with the build era
But in the next couple of weeks I'll get to paint it and tidy it up and will post some images once done.
I just wanna get riding again!
Once back in the saddle, I'll start to replace the non era parts peice by peice.
I'm lucky in the fact that it does have original stem handle bar and calipers, which have all polished up lovely , so only a few bits to replace really.
Liked 3,324 Times
bar tip -
in this image provided we can see that the left trail of the bar has been bent inward as compared to the right trail -
bar tip -
