Why is this sound happening in my rear wheel?
youtu . be/wcDseFuvZFk
youtu . be/ljoLdVD43Ec
I also noticed the chain starts moving slightly when the wheel starts slowing down.
Quoted: 513 Post(s)
Liked 445 Times
Please post a valid URL. Preferably, one that links to the correct video.
Quoted: 529 Post(s)
Liked 255 Times
It seems like the freewheel. It seems unusual. I can't say for sure.
I would start by running oil into the freewheel, and see what happens.
Does it function 100% while riding, apart from the noise. If it does, and oil doesn't fix it, you could pull apart the freewheel and have a look, or replace the freewheel, or just ride it as is.
Quoted: 513 Post(s)
Liked 445 Times
Is this a new freewheel? What alo said, run some light oil into the freewheel. Also remember that freewheels, freewheel cogs, and chainrings are not perfectly round, especially at lower price points. Try running a slightly looser chain just to see if that reduces noise.
Quoted: 513 Post(s)
Liked 445 Times
Explains the twitching transferred to the cranks. Cheap freewheels work fine with a spring-loaded chain tensioner like a rear derailleur, which, of course, is unnecessary with a single speed. But chain tension binds against the out-of-roundness. I worked in a shop that sold tons of these. Apparently customers knew they were getting cheap bikes so they didn't notice. Loosen the chain or get a better freewheel.
Liked 2,946 Times
Time to take it apart & look for a bad bearing race.
-Oh Hey!
-Oh Hey!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 695 Times
Perfectly normal for a cheap freewheel. The bearings aren't the best quality but then they don't have to be- when you're coasting there's no load on the bearings.
Put the chain back on, make sure it's not too tight (a little variation is normal when pedaling) and ride the bike. It should quiet down as parts wear in.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 43 Post(s)
Liked 58 Times
Lube the freewheel by oiling through the gap between freewheel cover and teeth ring, "run it backwards" with finger to help coating everything inside ( I would continue oiling 'til it runs from the backside gap, but you may stop when/if the sound diminishes; it will not be muted as it being a cheap frrewheel) and test. While you're at it, check the hub for grease; there is this sound like "dry" ball bearings falling onto each other and I'm not sure if it comes from the freewheel or hub.
Likes For Juan el Boricua:
