View Poll Results: What shifting method?
Brifters 105 9 speed
12
21.43%
DT Dura-ace 9 speed
17
30.36%
Barcons Dura-ace 9 speed
24
42.86%
Hybrid of barcons for the rear, DT for the front.
3
5.36%
Voters: 56. You may not vote on this poll
Barcons, DT, brifters, ???
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
Rebuilding my Fuji and I have a nice set of 105 yellow label shifters, derailleurs, cranksets, & brakes. I know the frame is not vintage but the group set is. Trying to decide a couple of things. 1, Do I go with the matching 105 brifters, a nice set of Dura-ace 9 speed DT levers, or Dura-ace 9 speed barcons? 2, I have both the 2x and 3x cranksets, I have the 2x installed, not sure I need the 3x here.
I have the long cage RD and have a 12-36 cassette.
Likes For fabiofarelli:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
Quoted: 3810 Post(s)
Liked 6,699 Times
I vote for one brifter, one barcon, and the set of downtube shifters mounted but not hooked up just because.
Likes For nlerner:
Quoted: 235 Post(s)
Liked 349 Times
DT because of Aristotelian Telos. Those mounts were designed for shifters. I know they have their destinies twisted into serving as cable stops at times , but they want to be shifter mounts.
Do you really want to take the chance of relying on existetially frustrated braze-ons?!
Quoted: 3359 Post(s)
Liked 3,638 Times
I've really come to like bar-ends.
My two multi-speed road bikes have 11 speed 105 STI levers and 10 speed DA downtube shifters on bar-end mounts, respectively, and in a lot of ways I prefer the bar-ends over the STI levers. I sometimes feel like the STI levers take too much force to use especially on longer rides. My STI levers are the more contemporary versions with all cables routed under the bar tape so I know they will feel different than your 9 speed 105, but you might want to consider the actual shifting motion of your hands anyways.
I've tried to love downtube shifters, but they're just sooo far away from me on 64cm frames. You may not have that issue, though.
(I'm also a little biased towards bar-ends in this scenario because I just don't find the early STI shifters attractive in any way...)
Quoted: 1872 Post(s)
Liked 692 Times
HA! You know you're in the C&V forum when DT Dura Ace shifters are leading the vote for a bike like that. Those would be my absolute last choice for a no name gravel bike.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Assuming you're keeping those tires and that rando bar (i.e., OG flared drop), and assuming you're going to be hitting some rough stuff, I vote for barcons. Might be parallax from the photo, but the caliper clearance looks a little tight.
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,898 Times
For me, since everything else seems like modern, I'd go with the STIs. I don't mind using DT shifters on bikes with 6 or 7 speeds, because it's part of the aesthetic, but 8 and up and I like brifters.
YMMV.
YMMV.
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
My 2c: downtube shifters for riding smooth roads, otherwise barcons. As mentioned above, those tyres would imply barcons. The brifters might come in handy on windy days for propping open the screen door.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Downtube, because that's all I've ever used, except for brief forays with bar end and brifters. I will say that with my current gravel bike, a Trek 414, the dt shifters are not ideal.
Quoted: 1372 Post(s)
Liked 1,751 Times
For me, the best choice would be Brifters every time unless I was seeking to keep a bicycle as original as possible.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
If you “like” Brifters, toss a coin for Brifters vs Bar Ends for x2 in the front.
Bar Ends if going x3 in the front.
I’m just not a DT shifter guy.
Commence to jigglin’ huh?!?!
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,526 Times
I actively and very much dislike Shimano's insistence on indexing their left-hand brifters, so that is a no-go as far as I am concerned. I have nothing against their right-hand brifters except a mild dislike for the aesthetic of a cable sticking out the side.
I am also too old, fat, tall and inflexible to want to deal with DT shifting any more, so those are out.
So if it were me, I would choose: (1) barcon for the left-hand (FD) shifter; and (2) either the barcon or brifter for the right-hand (RD) shifter. Probably the brifter as I do like the right-now hand-on-the-bar, but Shimano barcons are great.
Now if you were talking Campy, I'd go with the brifters and never look back. Campy doesn't index their FD shifting, and that is worlds more flaxible and better than the Shimano system. At least, that's what I think.
Keep in mind that my opinion is worth exactly what you are paying for it.
Likes For bikingshearer:
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
I really like barcons, particularly a rough road / gravel or in a crosswind or with a somewhat twitchy frame. Otherwise, I appreciate the responsiveness and clean lines of downtube shifters, which are what I have used most of the time over the years.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
1. Barcons
2. Downtube
3. Brifters
4. Hybrid
2. Downtube
3. Brifters
4. Hybrid
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Liked 1,700 Times
I didn’t see the poll when I posted...
the bar end rear/DT front doesn’t make much sense- Brifter rear/DT or bar end front makes sense with indexed front shifting on brifters.
The way I’m seeing it- going with whichever method is more comfortable to you in the rear, but going with the friction method you’re most comfortable with (especially with 3 chainrings) in the front.
Is there a reason one would wish to go with a combination of bar end/DT shifting?
Quoted: 366 Post(s)
Liked 457 Times
A couple of reasons. First the bike already has them and I like the aesthetic. Second is I am experienced with downtube and barcons so familiarity with the system. (Actually just got my first bike with brifters yesterday..... I know, welcome to the 90's. )
If pure performance were the goal brifters would clearly be the choice.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 2338 Post(s)
Liked 2,822 Times
as always big personal choice and how what your are riding
I have gotten to wear I really like Brifters, super efficient and make my ride fun.
I still use and like DT but I ride differently with them, and of course is de riguer for heroica which I am planning on doing this year
I simply don't like barcons, first I am always hitting them with my knee at rest and then starting out trying to shift and second they have always seemed more awkward to shift than going to the DT
two wheels only
I have a sneaking suspicion that is the case for most folks in this subforum. Nothing wrong with it but having ridden proper gravel with all three of these solutions I can 100% say that brifters, then Barcons, then dt shifters, are the best experience, in descending order. If the OP is just putting around town with occasional bike path rides then yeah any of them will be fine. But if it's going to be a proper gravel bike and ridden like one, then brifters all the way, it's not even close. Just depepnds on the usage, which we have no info for yet.
Liked 1,700 Times
Command Shifters for the win.
IMG_2402 by Dave The Golden Boy, on Flickr
Command Shifter + RRL Lever by Dave The Golden Boy, on Flickr
Likes For The Golden Boy:
