Bianchi Serial Number Identification
#1251
Bianchi Vittoria
Hello folks i am new member here i got this bianchi last month any idea what year is this just finish cleaning ,polishing and replace the seat and chain.
#1252
Strong Walker
Victory group means 1985+; also see https://www.bikeforums.net/classic-v...h-bianchi.html for a sibling
#1253
Quoted: 4722 Post(s)
Liked 3,036 Times
It's a 1985 Bianchi Vittoria. 1985 was the only year for the Bianchi Special by Columbus tubeset.
#1254
Liked 3,036 Times
Hello and welcome to the forums. Tells us a bit more about it. Is there a tubing decal? What brand and model components are on it?
Does it look like this? It is around an '83 and made in Taiwan, they were pretty nice bikes and I am looking for it's '94 purple sister
This one is heavily modified.
#1255
Strong Walker
Also it seems to be a very original specimen in very good condition, so congratulations are in order i wonder how many survived with the blue rubber rings on the brakes intact?
#1256
Liked 3,036 Times
Unfortunately, the tubeset decal didn't survive the repair stand. However there are aftermarket replicas available.
Likes For T-Mar:
#1257
Liked 3,036 Times
Here's a few pictures of my 81/82 Bianchi SPORT SS - It's in Metallic Copper color. Nothing has been done to this bike except dusting it off! Notice it has original Bianchi labeled tires that still have lots of tread life in them. I plan on using this on my trainer stand, but will remove the rear tire and save that for real road driving only! I live near Chicago so it may be a couple more months before this sees the outdoors
Any help identifying the tubing label "AR" in my previous posting please let me know.
Attachment 435848 Attachment 435850 Attachment 435851 Attachment 435852
Oh BTW, I removed all the reflectors and bagged them. I'm not a reflector person.
I believe that AR stands for Alta Resistenza, which translates literally to high resistance, which means high tensile steel. Rinforzati translates to reinforced, which means butted. Manufacturers started using butted, high tensile steels in the mid-1970s on upper entry level models and lower mid-range models. It was lighter than plain gauge steel, but less expensive than chromium-molybdenum or manganese-molybdenum alloys. They started to disappear in the very early 1980s with the advent of butted, carbon-manganese alloy tubesets. The 1982, Japanese manufactured version of the Sport SS used a butted, carbon-manganese tubeset.
If you still have the bicycle, it would be interesting to know the seat post diameter. It may raise the confidence level in my theory. Also, I don't believe that you ever posted the serial number, which I would appreciate having for my database. TIA.
Likes For T-Mar:
#1259
Location: Milwaukee-Chicago (Last stop on the North Shore Metra Line)
Bikes: 1975 Fuji 'The Finest', 1975 Fuji Super Road Racer S10-S,1980 SR 10-Speed, 1980 Fuji Newest, 1984 Araya 14-Speed, 1985 Bridgestone 500, 1986 Fuji 'Sekkei Series', 1995 Gary Fisher Kaitai MTB
Quoted: 131 Post(s)
Liked 12 Times
Don, I know you're still around, so I thought I'd resurrect your post from my sabbatical period. I think you'll agree that the subject bicycle is pretty basic for the era with stamped dropouts, no shift lever bosses, brake safety levers, 27"rims, swaged crankset and a rear derailleur with a steel parallelogram. In other words, it's fairly typical of upper entry level.
Thanks again for the details on the bike. It may not be the lightest, but it is indeed nicer than the 30+ lb Sears/Penny's variety
#1260
Liked 3,036 Times
Oh my T-Mar I'd written this question off many years ago and it was one of my early bike purchases before I had established a decent understanding of what I was really looking for. Thanks for the information of the tubing. Yes, even at the time of the purchase I didn't even consider the stamped dropouts being a major indicator of placement in the quality hierarchy. I've learned a great deal since then Thankfully I do keep spreadsheets on all my bikes so getting information on everything is easy. The S/N is BS18874 and the seat post is 26.8. Today I knew it was most likely hi-ten steel as the base bike came in just under 27 lbs. Early on I did upgrade it to the 1st Gen Suntour Cyclone line and changed to a much better SR Aerox crank set. However, I haven't really ridden the bike in the past few years and do plan on selling it. I kept all the original components and will return it to that setup (Suntour 7 series and that cheaper SR crank) and sell it off this Spring. Since it's still like new condition I should be able to get my original expenditure back on it, as it sure is a pretty looking bike for the casual user who want a nostalgic bike from the past.
#1261
New to the forum and I'm trying to put together a bike my son got that had been made into a cycle cross bike. There is a 2L stamped on the right side of the seat tube, and 466 on the left side. There is also "GIPIMME" on the dropouts. I am curious as to the year etc and what type of bottom bracket threads it may have.
Thank you for any suggestions.
#1262
#1263
Liked 3,036 Times
#1265
Bikes: Colnago CT1 Colnago Master Olympic Colnago Tecnos Colnago C40 Breadwinner Lolo Tommasini Prestige Rourke 953 Strong XCR Richard Sachs SL Canyon Ultimate 7 Bianchi Limited 84 Dean El Diente CTI Malvern Star 5 Star
Quoted: 7 Post(s)
#1266
Quoted: 7 Post(s)
#1267
Quoted: 7 Post(s)
Quick call out to TMar and co, Its an 89 model and I think it may have been a custom made frame due to the extra code on the BB. does anyone have any ideas of its background ?? cheers Cam
#1268
Liked 3,036 Times
As stated in your other thread, this appears to have the engraved/etched head emblem and other traits that are consistent with an X4.
#1269
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,925 Times
Was it the one on the 'drive side' aka right side? They are called fixed cups and are torqued on pretty tight. They can come loose if not properly re-tightened when installed.
Sugar "Kane" Kowalczyk
#1270
Bianchi Goddess
Liked 2,925 Times
The TSX decal is dubious as well but the only TSX reference I know off the top of my head is from the '93 Reparto Corse catalog and has completely different frame features.
RATZ! I was going to say something else but I was proof reading it got lost.
Of course just after I hit post. To my knowledge the only customizing Bianchi ever offered to individual buyers was a change in top tube length on the early Columbus MAX frames but IIRC it might added like 6+/- months to delivery time. Customizing may have been different when they had sponsorship agreements with local shops and teams and they ordered a large number of frames.
#1272
sn number
Hi I own a bianchi Reparto Corse with a very similar s/n number mine is 0901340101 and wondered if you found any details on the cycle as the s/n deos not conform to what other forums say
regards neill mackay
I've got an Alloy/Carbon Fork Reparto Corse I bought in 2004 off my neighbour who had too many bikes and he said it was pretty good although I didn't pay much for it. I've used it off and on and replaced various components but I'd be interested to know what the original spec is and if I could get replacement decals for it.
SN on the bottom bracket is 0901340315 - stickers say handmade in Italy but various internet forums say this might not be the case.
Another sticker says: "Advanced Aluminum Technology Lite Alloy Double Butted Bianchi Engineered Heat Treated Mega Pro Concept"
It's getting a bit like Triggers broom - Its had new shifters, rims, spokes, chain, cassette, handlebar is chopped and bull horned and spd pedals on it now - but apart from that its all original!
Any info you might have on the origin/spec/value would be appreciated.
Cheers Pete
Cheers Pete
#1273
Bikes: Specialised HydroDisc Crosstrail 2019 Black/Blue
bianchi model and age identification
Hello everyone,
I am new to this forum, so forgive me if I am doing something wrong.
I am in the process of buying my first road bike and I am hunting for a vintage Bianchi.
I have found something which I would probably buy, but before I do that I would like to know what is the model and year of production for this bike.
Thank you in advance for your help.
I am trying to upload pictures from my hard drive not urls and I cannot do it. I am getting message that I cannot post urls until I have 10 posts.
The serial number from what I can see is B*9 (top row) 1282 (bottom row)
Can someone help?
Can someone help?
#1274
Liked 3,036 Times
Hello everyone,
Can someone help?
Can someone help?
Link to the OP's photos: https://www.bikeforums.net/g/picture/17581570
#1275
Welcome tot he forums. Based in the serial number, in conjunction with the Columbus Cromor decal, the subject bicycle is a 1989 mid-range model. I don't know the name as this is a European model, based on the decal style. The equivalent USA model was the Campione d'Italia, though the only thing in common is the frame. I'm not aware of Gian Robert still being in the derailleur business in the very late 1980s. and these look like earlier derailleurs, so I suspect the bicycle has been rebuilt at some point.
This puts some light on it.
The current owner claims that it's the 1982 model. If anyone else has some more ideas please feel free to share it.
I have updated the album with pictures, so the link above might not work. Please check my album for reference.
bikeforums.net/g/album/17581421
Thank you!!!
