Question for ENO ECCENTRIC users ???
Old 09-07-06, 08:07 PM
MtbVA
TreadHead
MtbVA's Avatar
Bikes: '95 Klein Pulse, '98 Klein Pulse [Single Speed], Mosh (Gaint) 24" bmx cruiser
I have a question for anyone using the eno eccentric hub.
Do you think the eccentric hub will work with a frame with rear facing dropouts?
- look at rear drop outs-
Does the eno hub clamp to the frame dropouts the same as a geared hub?
This frame doesn’t have ANY movement like a forward facing dropout would.
Thanks.
MtbVA is offline
Old 09-07-06, 08:54 PM
Kaibot
faster and dangerer
Kaibot's Avatar
Bikes: Benotto w/Chorus and stunty parts, Giant ranier w/XT, Rossin Fixie w/campy, stronglight, ambrosio
Yea man an ENO is what you need and it will work seamlessly with that frame, it tightens to the frame with allen bolts that screw into the axle of the hub.
Kaibot is offline
Old 09-08-06, 03:22 PM
SirrusPackage
Dirty White Boy
SirrusPackage's Avatar
Bikes: 2004 Specialized Sirrus Comp, 1984 Raleigh Gran Prix fixed gear conversion
Ditto. You should be fine.
SirrusPackage is offline
Old 09-08-06, 04:07 PM
MtbVA
TreadHead
MtbVA's Avatar
Any guesses on spoke length? I plan on using a Mavic XC 717 with the ENO.
I would like to order everything at once.
MtbVA is offline
Old 09-08-06, 04:18 PM
sbornia
That's the rim my ENO wheel uses. I didn't build it, so am not 100% sure of the spoke length, but they measure *about* 260mm. The guys at Webcyclery should know for sure.
sbornia is offline
Old 09-09-06, 01:25 AM
LóFarkas
LF for the accentdeprived
What's the point of that dropout on the Klein??? It just looks so wrong.
LóFarkas is offline
Old 09-09-06, 02:05 AM
roadfix
hello
roadfix's Avatar
Quoted: 196 Post(s)
Liked 130 Times in 58 Posts
They sure are weird looking...
roadfix is offline
Old 09-09-06, 04:49 AM
Aeroplane
jack of one or two trades
Aeroplane's Avatar
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
I remember reading their blurb on it back when they made those... they actually claimed weight savings was one! Another reasons were the wheel drops out easier (I didn't really get that one) for tire changes. In fact, if you think about it, it would make removing the wheel a pain in the ass.
Aeroplane is offline
Old 09-09-06, 05:28 AM
chinitonorte
Bikes: Salsa La Cruz, Fat Chance Kicker, 29SS
Liked 4 Times in 1 Post
+1 for the ENO. Sweet simplicity.
chinitonorte is offline
Old 09-09-06, 06:44 AM
LóFarkas
Come to think of it, how the hell do you remove the loop of chain from the cogs when the wheel can't move in front of the der.??? Sonds like a sure way to get your hands very dirty and maybe damage the der. and chain.
And then.. weight savings???
LóFarkas is offline
Old 09-09-06, 07:09 AM
Aeroplane
Aeroplane's Avatar
Klein was also a huge proponent of internal cable routing... They had some wacky ideas in the late 90's, early 00's, that's for sure.
Old 09-09-06, 09:11 AM
MtbVA
TreadHead
MtbVA's Avatar
The main benefit of a rear facing dropout is the wheel can't be pulled out while pedaling if the skewer isn't tight.
The wheel comes out easy, just different. I have a harder time with forward facing dropouts now that I'm used to the rear facing dropouts.
MtbVA is offline
