What Type Of Under Shorts Do You Wear?
Bikes: 2015 Specialized CrossTrail Sport Disc
I don't know if I am using the correct terminology or not, but I am looking at "compression" type shorts to wear under my basketball shorts when I ride.
What are the under shorts called if they are not called compression shorts?
What do you all recommend?
Bikes: Trek Domane 5.2, Trek 520, Surly Straggler, Trek Roscoe 8, Fisher HK2
I wear padded cycling shorts so it is not an issue. There are cycling style shorts liners that are padded and made to be worn under other shorts or pants.
Mike
Mike
Don't basketball shorts get caught in the chain? <g>
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 849 Times
The quick answer is "none" or you're going to get some sore spots in the worst spots. Get some cycling specific shorts, they come in many styles, offer the right features in the right places. You don't have to spend a lot. Start by checking out mountain bike shorts with liners if you want to avoid the tight Lycra look. Google these...
Bike Nashbar
REI
JensenUSA
Bike Nashbar
REI
JensenUSA
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I've worn compression shorts for all kinds of athletics since the mid 1980s. That was when we went from leather chamois to synthetics. At first, Bike was the brand we used. These came from a baseball/football heritage, ironically. Their stretchy weave was unsurpassed by anything today. Alas, they're not made anymore.
UnderArmor stuff is pretty good. Minimizes friction and allows perspiration to wick away. The extra compression helps with fatigue.
the Boxers or Briefs question, returns?
So how far are you riding? tried any actual bicycle racer shorts yet?
You could just wear regular, padded cycling shorts under your basketball shorts. Also you could just go with mountain bike shorts which are baggy but with a padded liner inside. However if you are planning on actually playing basketball in such an outfit, the padded shorts won't work all that well.
Quoted: 5227 Post(s)
Liked 3,599 Times
I prefer thin lined "triathlon, aka tri-shorts" bike shorts under my mountain bike shorts aka MTB shorts. I have a 38" waist but prefer the XXL size in these. this newer model is better than their original cuz the leg opening now has a wide soft band instead of a tight narrow band. I buy mine from amazon. they're not cheap, but they are perfect for me. I even use them at the gym for workouts and running. they do have the sensation of "compression" shorts, but they have that moisture management liner that we need for duration sports
Amazon.com: ZOOT SPORTS Men's Performance Tri 8-Inch Short: Sports & Outdoors
aka Phil Jungels
"Athletic compression shorts" from Walmart. Cheap, lycra, do a good job. I even wear them for long days in the motorcycle saddle.
Of course, when in bike shorts, commando!
Bike Nashbar
REI
JensenUSA
Bike Nashbar
REI
JensenUSA
But yes, I need a under shorts (under my basketball shorts) for when I ride. Like you said, to minimize friction and to wick away perspiration! I'll have to check out UnderArmor.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 286 Post(s)
Liked 74 Times
"Basketball shorts" is a contradiction in terms. Though it wasn't always that way:
scott s.
scott s.
Quoted: 3352 Post(s)
Liked 1,056 Times
Ordinary Sears briefs. Since I ride a recumbent I dont have to buy expensive shorts etc to protect me from my seat.
This is going to sound stupid but I have riding shorts and mountain bike riding shorts both with butt pads. I was not aware that they were designed to go commando in? I have been wearing compression shorts under them when I wear them. You guys are wearing nothing at all under your lined biking shorts?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1352 Post(s)
Liked 1,246 Times
Fred "The Real Fred"
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
When I'm riding with a social group I wear Zioc mountain biking shorts. They're two piece, a padded liner anda groovy/hip plaid shorts. Can't tell I'm wearing bike specific clothes and I'm comfortable for the 20 mile ride with a stop for lunch.
If you already have a nice pair of shorts then consider buying a pair of lycra padded cycle shorts and wear them underneath like underwear.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
what kind of duration and distance are you riding? my commute to work is about 10 miles and takes about 45 minutes and I do not wear cycling-specific anything for that ride. if it is really hot, Iwear a cycling jersey but otherwise I just wear normal "athletic" clothing. if you are going to ride longer distances or longer amounts of time, I suggest cycling shorts.
avoid cotton! I don't even own cotton socks anymore. for shorter distances, boxers made from synthetic materials work great. I hav a few pairs made by Addidas, Puma, etc that I bought cheap at discount stores like Marshalls. for longer distances, any brand of padded cycling shorts will work and you might try a few before you find that one works better than another. I think you can get some Pearl Izumi shorts just about anywhere for cheap. unless you ride long distances every day, you can get away with one pair and just thoroughly hand-wash them after every ride. they dry quickly. take care of them and they will last you many years.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
n00b
Quoted: 428 Post(s)
Liked 466 Times
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
In many situations I wear loose mountain biking shorts with a separate chamois liner (like this) underneath, though this sort of liner would work fine with basketball shorts. I've bought a number of the liners so they can be washed after every ride, but the shorts don't really need to be. If I'm doing any sort of serious ride, I've got proper lycra shorts & bibs that I'll choose depending on the weather & distance.
I never wear normal underwear under my cycling shorts. I did do that years ago on a long ride and I'll just say that I learned my lesson: sandpaper would have been more comfortable against my skin than the cotton underwear I had on.
I have 2 pairs of riding shorts. One pair of tight shorts with a pad and a pair of MTB shorts with a padded liner. I guess I had no idea.
