Bike out of storage. Take out old sealant or just top up.
Bikes: Specialized
Quoted: 145 Post(s)
Liked 54 Times
Just took my bikes out of Storage. I never bothered to drain the sealant out prior. I guess that old sealant is not as effective now. Do you ppl change it out completely or just top it back up.
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,448 Times
If it formed a dried-out blob, peal it out. If it is still liquid, top it off. It is likely still as good as the day you put it in there.
Likes For Polaris OBark:
Liked 3,448 Times
You could also try what I do:
Don't even look. Just put in more sealant.
Likes For Atlas Shrugged:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12791 Post(s)
Liked 7,699 Times
If it's been in storage for a year or so (6 months or so in arid climes) I'd expect it to be bone dry.
I'd first check to see that all beads are still set by putting some air in there. If a tire only kinda holds air dry but the beads look mostly set I'd go ahead and add sealant and do extra thorough Stan's shakes (and bounces, you know the whole Stan's dance).
If a bead won't even come close to setting dry you may have to peel off the tire, clean the tire bead and rim, and unfortunately there's a good chance new tape will be needed if you have taped rims.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I i just top it off if it needs it. You can pull the valve and check with a dipstick, or take the wheel off and give it a side to side shake and see it you can hear anythjng sloshing around.
I’ve never bothered removing dried sealant, but I seldom have a tubules tire on a bike for more than a year of two before it is worn out anyway.
You are not seriously considering riding on last season's air, are you?
I like to start each season, or a long tour with fresh air.
Likes For Pratt:
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I prefer to not take tires off unless I have a little time to clean the beads and take off any dry sealant. Then I use soapy water to re-seat the beads, Usually, I just put new sealant in. Your old sealant is completely dry, in all likelihood.
Bikes: Specialized
Quoted: 145 Post(s)
Liked 54 Times
So today I just deflated the tires, pop one side and topped it up. I have a bad habit of overuse of sealant so it's never dried out completely.
Quoted: 1088 Post(s)
Liked 1,028 Times
I think it would depend on the type of bike, road bike where you could have a dried clump it might effect the ride at higher speeds, mtb where a clump wouldn't have the same effect I'd just add more and move on. Our house we mix the type of rides we do a lot so MTB tires can last 2 years, I just add more when I think it needs it through the valve stem and don't touch the tire.
Likes For prj71:
