Replacing a spoke on older wheel
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 922 Times
I have the original wheels on a 72 Schwinn Super Sport that I'm trying to make road worthy. Since I've personally never replaced a spoke or trued a wheel I wanted to reach out as to what might be my best and least expensive options to make them right.
Both are true and spin great. The problem is I have 2 very loose spokes and 1 that is bent. I did try to tighten the loose spokes but it appears that after 47 years of sitting and doing nothing they're not going to budge. I'm not looking to dump too much money into this project but I would like to retain the original wheels in order to keep the bike as period specific as I can.
Since I'm sure the other nipples/spokes are siezed just like the ones I attempted to adjust I'm guessing that these wheels would require a complete respoke(?) I'm looking for options and ideas since I've never been in this situation before.
Quoted: 18350 Post(s)
Liked 4,502 Times
You are using a spoke wrench, right?
You might remove the rim tape, and spray WD40, or your favorite penitrant onto all the nipples, top and bottom, and let it sit overnight.
New spokes and nipples (stainless/brass) aren't that expensive, but relacing a wheel is a bit of a chore, especially if you haven't done it before. Still, a very good learning process.
Really Old Senior Member
I'd get new spokes & nipples.
1. Loose spokes are a bad indicator of how much life your 47 year old spokes have.
2. Old parts just won't give you the "feel" when bringing up the tension.
I used to salvage wheels when I flipped bikes. I had more time than money.....
Even then, I'd use NEW nipples and wire brush the spoke threads. It still didn't come close to the SMOOTH, progressive "FEEL" as using new spokes & nipples.
One advantage you have, is that you still have "intact" spokes you can measure for the proper length.
Rear spokes may differ in length. Fronts will all be the same as each other, and MIGHT be the same length as your rear NDS spokes. Then again, it depends on what hubs you have. So, you need to measure 3 different spokes. 2 rear & 1 front.
I'd use a vise grips to "strip off" the old nipples. The right tension and it just cuts them open.
Quoted: 522 Post(s)
Liked 227 Times
You are lucky in that the wheels are already true. That means you can get away with buying 3 spokes and just replacing the ones that are loose or bent. Take a wire cutters and cut one of the loose spokes somewhere in the middle. Work the spoke out of the hub and take both pieces to your LBS. They can match the length of the spoke with a new one. Cost will probably be under $5. Last time I bought a couple of spokes it was $1.25 each.
Liked 4,502 Times
If one tightens loose spokes without compensating with other spokes, it is easy to end up with a wheel out of true, which is a problem if the other spokes can't be adjusted either.
One other thing, it would be a good idea to start by carefully checking the rim for damage, dents, flat spots, etc. It is possible that you have a bent rim, and the reason a couple of spokes are loose is that someone loosened them all the way as part of trying to get the thing true again. And, rebuilding a wheel with a bent rim can be a nightmare, especially if you're new at it.
Quoted: 1438 Post(s)
Liked 1,092 Times
I second CliffordK's suggestion to check the rim; if it true with 3 loose spokes I think it will be difficult to keep it true when you bring them up to tension.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
Those spokes are likely loose because the rim was bent at one time and someone got it true by adjusting spokes. If spokes on the opposite side of the loose spokes are too tight, that's your sign of a bent rim.
I agree you should not just tighten loose spokes because they're loose.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I've never had any trouble caused by bent spokes.
A 1972 Super Sport had steel rims, right? I can't see respoking these wheels being worth the money and time, unless you're also upgrading to a set of new aluminum rims. There are a few options that have the shiny vintage look. Call me an elitist if you'd like.
RUSA #7498
Liked 922 Times
Thanks for all the input. I'll probably just replace a few of the spokes, tighten them gently and keep my fingers crossed for now.
Half way there
Quoted: 985 Post(s)
Liked 879 Times
Great strategy. Let us know how it goes.
