Modern OEM Rubbery Handlebar Tape, Where Can I Get Some?
Old 08-16-19, 10:07 AM
audiomagnate
Bikes: 1990 Cannondale 3.0 RS400, 1994 Bianchi Kodiak converted to Urban Assault Vehicle
Quoted: 32 Post(s)
Liked 17 Times in 14 Posts
I checked out the 2020 Trek Domane yesterday and was blown away by how thick, rubbery and comfortable the handlebar tape was. Is that something the manufacturer specifies and/or supplies? I don't think I can swing a new SLR but maybe that handlebar tape is within my budget.
audiomagnate is offline
Old 08-16-19, 10:14 AM
tagaproject6
tagaproject6's Avatar
Quoted: 484 Post(s)
Liked 92 Times in 59 Posts
You were already there...why didn't you ask?
tagaproject6 is offline
Old 08-16-19, 10:37 AM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6814 Post(s)
Liked 634 Times in 403 Posts
Not sure if it is the same stuff as the Trek tape but...
Zipp Service Course Bar Tape - $17.99
https://www.jensonusa.com/Zipp-Service-Course-Bar-Tape
Zipp Serivce Course CX Bar Tape - 19.99
https://www.jensonusa.com/Zipp-Servi...se-CX-Bar-Tape
The CX version is textured while the other is smooth. They are both rubbery and thick but not sticky like the other popular yet insanely expensive rubber tape brands.
I'm in Cobb County by the way.
-Tim-
TimothyH is offline
Old 08-16-19, 10:45 AM
MattTheHat
MattTheHat's Avatar
Bikes: '20 Specialized Roubaix Expert, '18 Specialized Diverge Comp
Quoted: 236 Post(s)
Liked 105 Times in 82 Posts
I like Supacaz gel tape. Nice and grippy, but just a little padded too.
Supacaz Tape
MattTheHat is offline
Old 08-16-19, 10:48 AM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1736 Post(s)
Liked 137 Times in 100 Posts
Or, for very little money - old inner tubes.
Having said that, I might just do my first wrap with innertube. I've been riding doubled up cloth tape the past few years. Did once wrap a bar with innertube and tried it. Liked the feel but too much grip for me. I want to be able to quickly slide forward to the brake, always. But cloth over the innertube should solve that nicely.
Ben
79pmooney is offline
Likes For 79pmooney:
Old 08-16-19, 11:02 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 8501 Post(s)
Liked 439 Times in 264 Posts
Most bike shops and the internet sell silicone bar tape. You can use it for an emergency roadside breast implant too.
Seattle Forrest is offline
Old 08-16-19, 12:38 PM
tagaproject6
Quoted: 484 Post(s)
Old 08-16-19, 12:40 PM
Dean V
Quoted: 846 Post(s)
Liked 51 Times in 34 Posts
^ This.
It is a Bontrager tape. So any Trek retailer should have it or be able to get it.
Dean V is offline
Likes For Dean V:
Old 08-17-19, 05:05 PM
canklecat
canklecat's Avatar
Quoted: 2901 Post(s)
Liked 241 Times in 183 Posts
Arundel Synth Gecko. 100% silicone. Stretchy, durable, can be washed and reused indefinitely with reasonable care. Doesn't take a set or permanent curl, so it can be rewrapped without regard to how it was wrapped before. No adhesive, the soft, gummy wrap adheres to itself. Really grippy and soaks up road vibration.
Not cheap at $35 but a good value considering I've rewrapped it several times this year. Even $10 Eclypse or similar cheap foam wrap would have cost more by now (and it's not good tape).
And I'm about to rewrap it again, over a second wrap of cheap bar tape (I'll probably recycle the cheap Eclypse wrap since it won't show).
canklecat is offline
Old 08-17-19, 05:24 PM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 936 Post(s)
Liked 248 Times in 179 Posts
Ben
I also tried inner tube as bar tape, and was OK with the stickiness, but found that the rubber did not hold up well under sweaty hands, and that it will rot and fall apart after a month or so. But if you cover it up with some other tape, you should be fine.
I've been using inner tubes covered with cork ribbon for several years. Another thing I do is get rubber vacuum tubing from the auto parts store, and tape it to the front and back of the bar tops, to create a flat spot for my hands, then tape over that with cork ribbon.
Lemond1985 is offline
Old 08-17-19, 05:28 PM
canklecat
canklecat's Avatar
I used inner tubes cut into strips to wrap like bar tape, for practice and added cushioning. It seemed to last a long time, but the carbon black made a mess. And as Lemond1985 said it gets slick with sweaty hands. I've used it as a base layer under the cosmetically nicer wrap.
Old 08-17-19, 06:13 PM
thenewjs
Quoted: 23 Post(s)
I've been looking for the specific tape used on the Domane for sometime now, but can't it. I
Originally Posted by Dean V View Post
^ This.
I've been to many Trek shops and none sell the specific tape used on the Domane.
thenewjs is offline
Likes For thenewjs:
Old 08-17-19, 06:41 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2289 Post(s)
Liked 45 Times in 43 Posts
Fizik Vento Solocush
Sy Reene is offline
Old 08-18-19, 03:52 AM
audiomagnate
Quoted: 32 Post(s)
Found it! It's new and called Bontrager Perf Line Bar Tape. $29.99 https://www.trekbikes.com/us/en_US/e...olorCode=black
Old 08-21-19, 10:11 AM
Jax Rhapsody
Rhapsodic Laviathan
Jax Rhapsody's Avatar
Bikes: Rideable; 83 Schwinn High Sierra. Two cruiser, bmx bike, one other mtb, three road frames, one citybike.
Quoted: 80 Post(s)
Liked 6 Times in 5 Posts
My ratrod cruiser has innertube wrap for grips. Have not had any of those problems mentioned. Maybe it depends on the brand and type.
Jax Rhapsody is offline
Old 08-21-19, 10:15 AM
audiomagnate
Quoted: 32 Post(s)
Found it
https://www.bikeforums.net/showthrea...1&goto=newpost
