Apartments and tubular tires
Short version of my question: is it safe to glue tubulars in an apartment?
The long version is that carbon wheels will be the second major investment in my road race bike after a power meter (already decided which one to get there). It's a rim brake frame, with clearance for 25mm tires maximum. I could always go with carbon clinchers for convenience, but I'd really like tubular wheels for a variety of reasons. Chief among them is that I'd like to learn the art of gluing tubular tires - part of the allure of cycling culture, I suppose - and because I'd like to experience the ride quality for myself and see what if any difference I can discern from good clinchers (currently on Conti GP4000s). It does seem like there are many more choices in rim and disc brake carbon clincher wheels these days, compared to rim brake tubulars.
I live in a one-bedroom apartment though, so I'm quite concerned about the safety of gluing tubulars in such a small space. My apartment is also constantly full of dog hair despite frequent cleaning, haha. Is gluing on the balcony a potential option, or would the heat and humidity wreak havoc on the curing process? I could pay a local shop to glue them, but then I wouldn't learn anything.
Opinions and advice gladly welcomed.
Old fart
Quoted: 3571 Post(s)
Liked 3,368 Times
I've used a lot of different tire cements over the years and not one of them has been as noxious as other things commonly used in apartments, e.g. oven cleaners, roach sprays, wall paint, cigarettes, vaping, and dare I say it, essential oil atomizers and so-called air fresheners.
Bikes: Shmikes
Quoted: 10104 Post(s)
Liked 5,784 Times
If your concern is organic solvents, they're nasty, but you need a fair amount of exposure to begin to really cook your neurons. I built lots of models as a kid and still grew up to have a titanium bike. Open a couple of windows or, if you want real safety, buy a $40 respirator at any good hardware store. Just check that it's rated for organics.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 135 Times
Heck they aren't even that much you can get one on Amazon for under $20. May have to get a specific type of cartridge for vapors (which is what I used when spray painting in a tiny enclosed space), but that should eliminate any concerns over fumes.
Quoted: 4746 Post(s)
Liked 3,861 Times
I suppose it's possible to hurt yourself with tire glue but I had no issues gluing my tires over 25 years and 70,000 miles except very sticky, hard to clean fingers. (Tubasti - several boxes worth and Clement for my race tires plus another glue or two over the years.) And that's from a guy who sensitized himself to a wide variety of solvents building fiberglass boats. Now, the solvents some use to clean the rims is another story. I don't think I ever did more than scrape off old, hard glue and never saw the need to "clean" the rim, seeing a clean rim as inferior to a rim covered with really stuck old glue. That glue isn't going to care about your dog's hairs; they'll just be part of your ride. You might notice them first stop (in your brake pads). Humidity isn't going to affect the glue. All the high outdoor temperature will do is thin the glue a little and make it messier to work with as well as probably making it harder to stick the tire down properly but easier to move if it is not quite right.
Ben
Ben
Thanks everybody! Tubulars it is, then. I suppose I can use solvent to clean rims, if needed, on the balcony but do the gluing in my living room.
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
Fine. I glue from can. I'd put the lid on when done.
The cleaning solvent - depending on what you use, how much and where the rag goes - not so good for an apartment.
RacingBear
Those advantages are over blown. Sure you can ride with a flat, but in a crit it's a short course and you can get back to wheel pit quickly enough even without riding. In Road Races it's miles to finish line, either you get wheels from follow car or chill for neutral vehicle. That assumes racer has spare wheels. If not whole thing is moot. The race is over, might as well just chill out. The heat thing is again over ratted. In crits you rarely use brakes, in RR same.
Now days between tubeless and latex tubes clinchers are not that far off in weight and rolling resistance from tubulars, and there been studdies that they are actually more aero when right tire is paired with wider rim.
Chases Dogs for Sport
Yes, there's a reason the choices of tubular wheelsets are diminishing. Ten years ago, it seemed that half the aftermarket wheels were for tubulars. Nowadays, it seems less than 1 in 20. They've become pretty rare. Clinchers (especially tubeless) are easier, less messy, and a lot of them perform just as well as a set of tubulars. A few perform better. Even in the pro peloton, tubulars are headed toward extinction. But they could be pretty cool as a kind of vintage, throwback option.
I realize he said he is going to race. Overwhelming majority of amateur racers are on clinchers now days, and I think pros are doing it mostly for historical reasons.
Mainly I would like to become proficient at gluing tubs before they (inevitably?) go extinct in a decade or so. I feel like I need to see what all the fuss is about over ride quality. Some people have said they don't notice a difference compared to quality clinchers with latex tubes, others do. And as conservative as the pros can be, I doubt they use tubs mostly for historical reasons. They probably do it because they don't have to glue the tires on themselves!
After doing some searching, it looks like a set of lightly used carbon tubular rims might be the smartest way to get into this. Plenty of choices compared to new wheels and somewhat cheaper too.
Should Be More Popular
Quoted: 22514 Post(s)
Liked 8,843 Times
Agree. But its a free country so OP can try and reach his own conclusions.
There is a reason why really good, gently used tubular wheelsets can be found for cheap.
Likes For datlas:
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I've used all kinds of chemicals in enclosed spaces and I don't remember having any troubles.
I also don't remember my birthday, what I had for dinner last night, who is the current president, or my parents' names.
Who are you people and what am I doing here?
Likes For ksryder:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 413 Times
Yes. It is safe.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Old fart
Liked 3,368 Times
There's no compelling reason to remove old glue from the rim bed. If it gets on the sidewalls and you have rim brakes, then you might want to clean that much off.
Quoted: 1103 Post(s)
Liked 1,824 Times
OP, the good news is it's safe to glue tubular tires in your one bedroom apartment. The bad news is the cost of running tubular tires will keep you in a one bedroom apartment
Likes For nomadmax:
Liked 3,861 Times
I didn't actually cite racing performance as my top two reasons for trying tubulars in the OP, but I would very much appreciate the ability to finish a lap in a crit on a flat tubular. Easier than changing a tube just to get back to my car. That said I really don't have anything against carbon clinchers - I'm not worried about braking heat. There isn't a descent within hundreds of miles of me that would challenge rim brakes.
I am looking at going back to tubulars in the not so distant future for the peace of mind. That and for enough money I can ride those magic carpets again, a nice bonus. Good race silks or modern synthetic equivalents. For a while I commuted on Clement synthetic Pari-Roubaix's. 290 gram tire and tube on 400 gram rims. Completely race worthy (for poor pavement; a little heavy for the smooth). All weather, sturdy tires and what a ride!
Ben
Liked 371 Times
Just converted a few bikes to them. I've ridden for years, but my issue was flats. Not that they flatted more, they flatted less, but when they flatted they were a pain. I found some better routes with fewer goat head thorns and less glass and they are easily worth the flat/season I expect. I went to heavier (lighter setup than clinchers or tubeless) ones too, so I have not flatted.
Liked 371 Times
Some of the better clinchers perform as well as some of the lessor tubulars. Many clinchers seat better.
I know of no clinchers that perform as well as the best tubulars. All are 400g heavier, more flat prone and less responsive.
Here is my ready to ride set all built up 1370g. Those are road tires G+ and hold up well.
The best 23mm clinchers/tubeless are going to be a few hundred grams more and subject to breakage these are not. But those 23 clinchers are not the handlers of these.
To get the air above the rim and and feel of these 23mm you'd need about a 25/26mm tubeless.
The general population does not race. Nobody cares. I get that.
But for those that do, and buy the good stuff, the difference is significant, which is why the good wheel sets are not cheap, nor are the tires.
Two at same PSI. One a tubular of silk casing. The other a "25" Veloflex Master. The tubular has the air of a 28 meaning you need 2-3mm more width in a clincher to get the same feel/bump protection. I'd put 23mm tubulars on the tandem, when for clinchers I want 25s.
I was taking slomo video of how these grip the road and deform on a corner. My kid saw me taking that video and laughed why I'd even bother. The difference is so stark, it is silly.
