What exactly will happen if your hubs have a little play?
#101
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Except SKF states in they own manual:
"Although all bearing types can run with some
preload, SKF recommends a positive operating
clearance. This is particularly important for
roller bearings such as cylindrical roller, needle
roller, spherical roller and CARB toroidal roller
bearings."
bearings."
Googled their site:
" As a general rule, ball bearings should always have an operational clearance that is virtually zero, or there may be a slight preload. Cylindrical, spherical and CARB toroidal roller bearings, on the other hand, should always have some residual clearance - however small - in operation."
The link:
Bearing internal clearance
#102
Enjoying the ride
#103
Roller bearings are different from ball bearings (mostly used for bicycles). They produce more drag and are better suited for heavier load applications. One roller has more surface contact with races than all the balls of a ball bearing together provide.
Googled their site:
The link:
Googled their site:
The link:
#105
Why not? Its referencing ALL bearings with special emphasis on rollerbearings ect. The second sentence does not contradict the first sentence or negate it.
#106
Calamari Marionette Ph.D
Pairs of ball (like on a bike) bearings should be preloaded before being put into service.
One of the final steps in the bearing manufacturing process is the assembly of the individual bearing components: the outer ring, inner ring, balls and retainer (or ball separator). When the bearings are assembled, it is necessary to have a controlled amount of internal clearance, or looseness between the rings and balls. This is referred to as radial play in most bearing catalogs.
In certain applications, this internal clearance must be removed for a pair of bearings to operate properly. The application of an axial load across a pair of bearings – for the purpose of removing free internal clearances – is called preload.
Benefits of preloading ball bearings include:
- Rotational accuracy and precise shaft positioning
- Elimination or reduction of ball skidding
- Control and reduction of axial and radial deflection under applied load
- Noise reduction
- Load sharing between bearings
It appears that AST Bearing Company agree with Jobst Brandt.
I would think the third bullet point would be of significance on bicycles considering their service environment, which includes impacts caused by riding surface imperfections and the fact that they lean in both directions.
Preloading Ball Bearings: Full AST Guide - Bearings : Blog : AST Bearings
#107
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
#108
Mostly harmless ™
Liked 216 Times
Have you run hubs with play (after they are mounted / QR tightened and closed) and gotten away without pitting after a few thousands of kilometers?
#109
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
Preloading bearings !?!!! Slowly I turned...
...inch by inch.....step by step.
#110
Sock puppet
It appears that you one again ignore that the text you quoted says "In certain applications ... ". We already covered this. A bicycle is not a lathe or truck wheel.
#111
Apart from other links and quotes provided by other participants, I can only refer you to the SKS quote I provided - that mentions ball bearings explicitly.
"" As a general rule, ball bearings should always have an operational clearance that is virtually zero, or there may be a slight preload."
contradicts this:
""Although all bearing types can run with some
clearance. "
Imo, it does not. It states that some, very little or more, positive clearance is recommended as a general rule.
#112
Bicycle wheels don't spin in a vacuum.
That's the same reason SKF preloads their bottom bracket bearings.
Without preload, the balls are free to bash back and forth, up and down, over and over, repeatedly making blunt force impacts with the races.
With preload they are forced to stay where they belong and ROLL in between the races.
TOO FUNNY. SKF has design software that assists engineers in determining the proper amount of preload.
You can find it here, on their "Selecting Preload" page.
Selecting preload
#113
An empty wheelbarrow has no load.
A wheelbarrow containing a single feather has a load. A very light load.
It's a matter of degrees.
Bicycle mechanics with sensitive fingers can achieve feather-like preloads.
That's direct from the SKF website.
#114
Quoted: 659 Post(s)
Liked 7 Times
#115
Enjoying the ride
...I honestly don't know, but there was quite a back and forth over that one, too. Proof that a QR compresses the axle?
Best Regards
Rod
#116
https://www.sheldonbrown.com/brandt/...djustment.html
#117
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
#118
Enjoying the ride
Best Regards
Rod
#119
Enjoying the ride
#120
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
#121
Blind dudes are the best at setting preload, obviously.
#122
Quoted: 980 Post(s)
Liked 582 Times
Steve
#123
Also, the other theories for the elimination of play caused by closing the QR have gaping holes in them.
Bowing of the axle? No way. The cups and cones would then be misaligned and you'd never achieve a good preload setting. And things would wear in uneven ways, at an accelerated pace.
Slack on the axle between the lock nut and cone? Nope. They are locked together after all, immobilized. The fact that they don't move on the axle is clearly demonstrated when you crank down on a axle nuts of a solid axle wheel with a big wrench and the preload adjustment remains unchanged.
#124
Quoted: 980 Post(s)
Liked 582 Times
You don't have to "believe" this... you either accept it as a fact or you don't!
/PreachingToChoir Mode
The rails trains run on are deformed slightly under the weight of the train, and the wheels are slightly flattened.
Also, bending does involve compression and elongation at the same time, but in different places: a cylinder (or rod) that is subject to bending forces is under tensile loading on the outside of the curve and compressive loading on the inside of the curve.
Agreed, but when the axle is loaded there is probably some bowing which is nevertheless tolerated by the bearings.
/DevilsAdvocate Mode
Exactly!
Steve
Steve
#125
Quoted: 1814 Post(s)
Liked 923 Times
I believe that hollow axles compress when the QR is closed. Steel expands and contracts from mere temperature changes. How could it NOT succumb to physical forces? We can bend steel. Bending is compressing and stretching at the same time.
Hmm...
