For the love of English 3 speeds...
Old 01-27-20, 11:47 AM
  #22176
BigChief
BigChief's Avatar
Quoted: 1299 Post(s)
Liked 103 Times in 85 Posts
Originally Posted by Salubrious
Someone hinted at a possible problem. Check your end float on the hub. The cones must have ever so slight amount of slop. You can check this at the rim- it should be able to move ever so slightly from side to side. If there is no play in the bearing cones the hub will not shift correctly and can be damaged!
Also- do not throw the old toogle chain out. The damaged links can be repaired using a nail of the right size as a rivet. I think the original rivets are harder, but in practice they don't have a lot of tension on them. I've been running a toggle chain repaired in this manner for the last 12 years.
Now that's a frugal New Englander! I just bought a package of 10 HSA 125 indicators from some guy on eBay.
Inflate Hard
BigChief is offline
Old 01-27-20, 12:46 PM
  #22177
gster
gster's Avatar
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times in 288 Posts
I guess it depends where you live....
My LBS has lots of these NOS
gster is offline
Old 01-29-20, 07:05 AM
  #22178
PeterLYoung
PeterLYoung's Avatar
Location: Southport, North Carolina, USA & Pevensey, East Sussex, UK
Bikes: 1)1992 Trek 970, 2)2010 Trek 6500, 3)1973 Colnago Super, 4)1955 Freddie Grubb Meteor. 5)1993 Airborne Ti-Hag Titanium. 6)1936 BSA 602DX Roadster. 7)1957 Philips P2 Sports. 8)1955 Dayton Roadmaster. 9)1948 Humber Clubman. 10) 1949 Sunbeam WA3 Wayfarer
Quoted: 157 Post(s)
Liked 85 Times in 34 Posts
Sunbeam W3 Wayfarer No S48571 1949/50 Part 3
I have now ridden this Sunbeam Wayfarer a few times and it has proved to be a very nice ride. I have also added a 1950's NOS Lucas Challis Bell and a NOS 'Ever Ready' Rear Lamp which I have converted to 9Volt LED running from a 9Volt 6LP3146 Battery (type fitted to Smoke Alarms). Also a Vintage Front Lamp of unknown make which I have also converted to 9Volt LED utilising the same battery as the rear lamp. See photos below:-
You can see other instalments regarding this rebuild at: Sunbeam W3 Wayfarer No S48571 1949/50 & Sunbeam W3 Wayfarer No S48571 1949/50 Part 2
NOS Lucas Challis Bell fitted.
Front Lamp, switched on, illumination is quite bright.
Close up of front lamp.
Top of Front Lamp showing dual voltage switch ie. 4Volts or 8Volts.
Ever Ready Rear Lamp. Had this in it's original box priced at 4/6d in the 40's/50's.
Lamp again is pretty bright
Bike in it's current state.
Cuius summa inventa
PeterLYoung is offline
Likes For PeterLYoung:
Old 01-29-20, 09:00 AM
  #22179
gster
gster's Avatar
Very nice.
4/6 in 1945 is worth about 8 pounds today....
Your BSA trigger looks NOS as well.
gster is offline
Old 01-29-20, 10:56 AM
  #22180
PeterLYoung
Quoted: 157 Post(s)
Originally Posted by gster
Very nice.
Thanks your comments. Yes you are correct it is NOS and I think probably middish 1950's (there is no date on it) as also is the 3 speed cable which came in a sealed Britax (famous for seat belts) greaseproof bag.
I think the Challis Bell is probably much later than the bike and there is no date on it.
Cuius summa inventa
Old 01-29-20, 11:42 AM
  #22181
BigChief
BigChief's Avatar
Great job on the bike. A classy ride. That front lamp reminds me of those old ww2 military lanterns. I think it might be one. Dual use because of the handle. And that looks like a spring loaded suspension. Designed for a heavy battery perhaps? Very cool.
Inflate Hard
BigChief is offline
Old 01-29-20, 12:19 PM
  #22182
PeterLYoung
Quoted: 157 Post(s)
Thanks your comments. Got the lamp in mixed box of vintage battery lamps at an auction. It has a dual voltage (4 & 8 Volts) switch and probably had two batteries but no idea what the batteries were. It is on spring suspension which clamps to the bike lamp bracket but I doubt it will operate much as my battery does not add sufficient weight. Overall it is in excellent condition so probably been in a cupboard somewhere and kept dry. Like you I think probably 1940's but yet to find it in a catalogue anywhere. Never seen another. Gives a good light though with the 9Volt LED lamp.
Cuius summa inventa
Old 01-30-20, 03:51 PM
  #22183
Salubrious
Salubrious's Avatar
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times in 119 Posts
I got a weird one. I recently picked up a 1949 Royal Enfield rod brake machine ('Lightweight Sports'). It seems to have really unusual wheels- 650b instead of the regular 28" rims usually seen on rod brake machines. The rims appear original and no rust only on account of being worn by the brake action. The original finish appears to have been black paint. Anyone heard of something like this?
Salubrious is offline
Old 01-30-20, 04:27 PM
  #22184
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2298 Post(s)
Liked 2,054 Times in 1,254 Posts
CCM also made models with these. They were 26 X 1 1/2" Canadian designation. I think I've rims and Dunlop white walls in the cave although the rubber may be too far gone.
clubman is offline
Old 01-30-20, 08:27 PM
  #22185
nlerner
Quoted: 3810 Post(s)
Liked 6,690 Times in 2,610 Posts
Yeah, 597mm/EA1/26 x 1 1/4” rims were popular in that era, but 584mm/650B?
nlerner is offline
Old 01-30-20, 10:19 PM
  #22186
clubman
Phyllo-buster
clubman's Avatar
This Dunlop chart shows the British size was 26 x 1 1/2 or F9. It shows a bead circumference of 72.25, just under the EA3 value of 73.0. I think that works out to the difference between the 590 and 584 beads, especially when you compare the numbers between the EA1 and EA3.
clubman is offline
Old 02-01-20, 09:03 AM
  #22187
gster
gster's Avatar
Here's a good looking Canadian Superbe for sale in Hamilton, Ontario
Very complete with 2 keys.
Pre 1961 with reasonable paint and decals.
Seller is asking $185.00
gster is offline
Old 02-02-20, 08:24 PM
  #22188
bluesteak
Quoted: 118 Post(s)
Liked 91 Times in 52 Posts
Very interesting bike. I never saw paint like that on a Raleigh. Reminds me of my Hercules tourist.
bluesteak is offline
Old 02-03-20, 05:31 AM
  #22189
bluesteak
Quoted: 118 Post(s)
My 39 elswick has 26 x 1 3/8 westrick rims, chrome with painted centers.
I also have a couple 20 inch kids rod brake bikes.
Old 02-03-20, 01:52 PM
  #22190
jackbombay
Quoted: 457 Post(s)
Liked 462 Times in 270 Posts
I picked up a 1974 NOS S3C coaster brake Sturmey, the plan is to build up a drop bar "brakeless" bike with it, it'll obviously have the coaster brake, but it will look like it has no brakes. I'll buy some cheap ergo drop bar brake levers to use for more hand positions and I'll figure some way to install the shifter into the right brake lever so I won't have to move my hand from the hood to change gears. So, I am on the lookout for an older horizontal dropout bike around 56-58cm in size if anyone knows of one, I'm 5' 11"...
I will build this up with a 32 hole rim as I did with the other 40 hole S5 hub I recently built into a wheel.
jackbombay is offline
Likes For jackbombay:
Old 02-03-20, 08:44 PM
  #22191
jackbombay
Quoted: 457 Post(s)
Originally Posted by brianhamp
So how do you go about lacing a 40 hole hub into a 32 hole rim? I have alot of 40 hole hubs I would like to lace up but short on 40 hole rims..
Please share!!
https://www.bikeforums.net/classic-v...-hole-rim.html
Let me know if you have any questions on this :-)
Old 02-03-20, 08:51 PM
  #22192
nlerner
I have a Jeunet w/ horizontal dropouts and no derailleur hanger that might fit the bill. I need to measure when I’m back home, which won’t be until next weekend, but iirc it’s a 58cm frame (I’m 5’10”, and it fits me well).
Here’s a pic of it built with 650b x 38mm wheels and an AW hub.
nlerner is offline
Old 02-03-20, 09:14 PM
  #22193
jackbombay
Quoted: 457 Post(s)
I will give it a go tomorrow... Thank you so much!!
Glad it can help you out!
That bike is a beauty!
I actually took a look in the "Pass it around frame doesn't fit" thread and found a Schwinn Premis (columbus tubing) that Mad Honk was looking for a new home for so that will be on its way to me when he gets it boxed up, he even has the 32 hole wheels it came with so I can use the front as is and take apart the rear wheel to use the rim with my sturmey hub. I'm really looking forward to the build, its going to be laughably simple with only one cable to run!
Old 02-04-20, 04:42 AM
  #22194
gster
gster's Avatar
Someone, wiser than myself, pointed out that it's a good idea to install a front brake on a coaster bike.
Very important if you plan to ride in the city.
I've got two coaster projects (Perry and a Duomatic) and they both have a caliper up front.
Raleigh/Glider w/ Duomatic hub.
The drop bars have been swapped out for uprights since this picture was taken.
gster is offline
Old 02-04-20, 06:30 AM
  #22195
clubman
Phyllo-buster
clubman's Avatar
+10 I don't think SA coasters work well enough to trust one's life with. Duomatics are very good but still...
clubman is offline
Old 02-04-20, 06:41 AM
  #22196
gster
gster's Avatar
Yes, the Duomatic brake works quite well.
You can lock it up if you want to "lay a patch".
Something like 70% of your stopping power is
from the front.
gster is offline
Old 02-04-20, 10:42 AM
  #22197
jackbombay
Quoted: 457 Post(s)
from the front.
I know just a coaster brake is not the safest way to set up a bike, the front brake is absolutely the boss when it comes to dumping speed NOW!
I will ride the bike accordingly, I can always add a front brake easily at a later date.
Old 02-04-20, 01:08 PM
  #22198
julius rensch
Bikes: 1972 Raleigh Tourist
Quoted: 27 Post(s)
Liked 14 Times in 10 Posts
Coaster Brake..
Years ago (in the 1950's) a 14 yr old friend was riding down a steep hill on his Schwinn Phantom equiped with only a Bendix coaster brake. ...while coasting at high speed, upon hitting a bump, the chain jumped off...resulting in no brakes, into a busy intesection...he died there after being hit by a car.
I loved my English Indian Scout with front and rear handbrakes even more after that, so did my Mom & Dad.
Jules in Ohio
julius rensch is offline
Old 02-04-20, 01:58 PM
  #22199
clubman
Phyllo-buster
clubman's Avatar
Yah, I just like to hear myself saying the same things repeatedly.
clubman is offline
Old 02-04-20, 10:48 PM
  #22200
jackbombay
Quoted: 457 Post(s)
Jules in Ohio
My bikes are always maintained quite well, there is always a chance of failure of any system, but the bike won't have fenders so I will have the secondary option of a foot on the rear tire behind the seat stays, or, a foot on the tire behind the fork crown, not a conventional means of stopping the bike, but as an old BMX rat its not totally foreign to me. Sorry for the loss of your friend :-(
I realize that this is an unconventional build, but it will be mostly ridden on quiet country roads/paved trails/small town...
