Trouble with triple
Quoted: 644 Post(s)
Liked 1,542 Times
Trouble with triple
I have a used 2009 Specialized Roubaix with Ultegra shifters and fr. The cables were not in great shape so Installed new ones. Since then when I shift from the big ring to the middle it goes straight to the little ring. Before the cable replacement it worked fine.
Is there a ratcheting mechanism or something in the shifter itself that needs attention? What keeps it from doing this in normal operation?
Expired Member
Quoted: 3736 Post(s)
Liked 5,604 Times
Disconnect the cable, click the small paddle until all tension is released, then start over. Find your instructions Manuals & Tech doc
