Half a bike for the price of a whole one!
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
Wow, such an incredible idea! And what a bargain, too!
https://www.honeybadgerwheel.com/collections/options
Quoted: 18507 Post(s)
Liked 15,821 Times
Except they are not bicycles. They are basically wheel barrows with front platforms instead of barrows. They are propelled by walking.
Likes For indyfabz:
Lopsided biped
Quoted: 316 Post(s)
Liked 160 Times
https://www.lowtechmagazine.com/2011...eelbarrow.html
which describes the invention as an adaptation to decaying infrastructure. The roads got so bad that two-wheeled carts became useless on them. None of which explains why someone thinks they're worthy of a modern reinvention.
Quoted: 18424 Post(s)
Liked 4,544 Times
Interesting device.
I could imagine they missed their calling 20 years ago before POT legalization.
I'm trying to imagine if they'd be useful for hiking/camping.
If I was going to build one, it would be primarily for access to flat-land camping sites. So, folding and compact would be a MUST. Perhaps design it around the Schwinn 16x3 tires.
However, the E-Cart could be handy for more rugged terrain. It mentions hunting.
Interocitor Command
There's actually an e-bike version?! At only $1,800 on sale I should get TWO!!!
Half way there
Quoted: 990 Post(s)
Liked 884 Times
Interesting take on the venerable wheelbarrow. Unlike a wheelbarrow, though, this device balances the load over the axle, which likely allows better control with less of a workout. One of their models can carry 250 lbs. I imagine that's possible to handle on a smooth level surface, but probably a bit tough on a rough uphill route. A small trailer might be more suitable in that situation.
Liked 15,821 Times
Likes For indyfabz:
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
At least a wheelbarrow can be rested on the ground without having to unload it first.
Likes For FiftySix:
Liked 15,821 Times
Quoted: 1227 Post(s)
Liked 637 Times
Yeah, I forgot to install the snark. They're a modern version of the Chinese wheelbarrow. I got the link from this article,
Likes For GrainBrain:
Quoted: 507 Post(s)
Liked 237 Times
https://www.google.com/search?q=hone...wheel&tbm=isch
This actually looks more useful than other bicycle-like 'inventions'
https://www.google.com/search?q=treadmill+bike&tbm=isch
https://www.google.com/search?q=fliz+bike&tbm=isch
https://www.google.com/search?q=half+bike&tbm=isch (the REAL HALF bike)
https://www.google.com/search?q=elli...+bike&tbm=isch
And so on.
Likes For autonomy:
Lopsided biped
Quoted: 316 Post(s)
Liked 160 Times
Liked 4,544 Times
The Kickstarter Campaign. They sold:
9 Fattie II
2 Fattie II electric
1 Personal Operator Hunt Adventure
They've posted a few photos of the thing parked on the Kickstarter Campaign. It does look a bit awkward.
The photo with the coolers looks a bit odd. Did they tie the coolers on strange for the parked photo, then tie them on again fro the carrying photo?
I'm not quite sure how to deal with those issues. Perhaps stands that would drop down.
9 Fattie II
Likes For CliffordK:
Quoted: 1324 Post(s)
Liked 927 Times
Now if it had a single center handle and a means to attach it to say a bicycle seatpost then it might make a decent bicycle trailer.
Cheers
Cheers
Quoted: 1586 Post(s)
Liked 1,219 Times
Pfffft. Not interested. For one thing, it doesn't have illusory drop bars. And then there's the question whether one gets the same 'workout' with a digital barrow as with an analog barrow.
#realwheelbarrowist
#realwheelbarrowist
Likes For badger1:
Liked 4,544 Times
I wonder if there is an issue with too little handle weight.
So, say one encounters a rock or log to push the thing over. Would the pushing force tend to simply revolve around the axle rather than lifting the load over the obstruction?
Pull? Walk backwards?
Handle height?
Handle height?
9 Fattie II
9 Fattie II
First, the load would need to be balanced or it would tip.
Second, I question the ability of one being able to push a 50lb+ load on one tire through soft (dry) sand. I believe it would likely sink enough to make pushing the load too difficult.
Third, once the load tips about 30+ degrees on either side, she's gonna topple, and there's not much you could do but watch her fall and crash.
Liked 4,544 Times
Poor idea, too be sure.
The Kickstarter page says 150 to 200 lb capacity. Not unexpected, but that is a big load.
Nonetheless, in my younger years, I carried a load of about 130 lbs (backpack + shoulder strap luggage). WHEW!!! Getting the big loads onto a wheel makes a lot of sense. Nonetheless, it would still be a big problem in rugged terrain.
Even getting a 50 lb load off the back and onto the ground would be a benefit. Toddler stroller?
Quoted: 17 Post(s)
It seems poorly thought out, especially considering the price. A single wheel would make sense if it had linkage to a ruck frame and trailed behind the hauling hiker. You could even route the braking cable and a lever by the hiker's hip. Otherwise it's a lot more energy to keep upright over rugged terrain. Something like a ruck frame attached unit could have potential. It would offload a lot of the weight on the hiker compared to the traditional ruck.
FWIW, the closest thing to this I've seen is a pole and belt system offered as a "jogger" kit by Burley for their trailers.
There's a reason the ubiquitous wheelbarrow has a small wheel, legs, and a low center of gravity. Balancing that on a traditional bike wheel would take a lot of energy and upper body strength. One thing would be certain, it would be an excellent upper body workout.
Likes For Jeff of Vt:
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
Another solution in search of a problem.
Destroyer of Worlds
So was just at "Cycle Mode International" here in Japan last weekend, and they had some of these bike things. They had them in all shapes/sizes from just "normal" bikes with a cutout in the middle for "utility boxes", all the way to more wheelbarrow looking ones. Most of them were e-bikes, and overall, it was just an odd sight.
Liked 15,821 Times
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Wait, what? Is it April already?
Up to 200+ pounds balanced on a single wheel with a center of gravity that high and anyone expects stability and usefulness?! Riiiiight. Fools and their money...
-Kedosto
-Kedosto
Liked 4,544 Times
