So disappointed by Cycliq
I bought a Fly6 CE from Cycliq a while back. Seems like a cool idea and I wanted a rear cam after getting hit and run. My first Fly6 didn't work. It would record a few minutes and turn off mid ride without explanation, usually after 2 or 3 five-minute segments. I tried everything I could using their support website, and then eventually it bricked itself. Great. I contacted their support and was able to get them to send me a replacement after about two weeks of back and forth (time zone issues as their support is in W. Australia vice me in the US).
I got my replacement recently and today I took it on my commute. On my way into work, it seemed like it worked as expected. It stayed on the whole ride and seemed like it worked fine. I turned it on when I left work, and when I got home... it's off. I hook it up to my PC, and the SD card is corrupted. None of the data can be read at all. It makes me do a full reset and format of the device and SD card, respectively.
At this point, I'm just OVER it. All in, this is a $200 device, I'm on my second one, and it's never worked right. I can't understand how they were able to bring something so flaky and unreliable to market. I reached out to their support to ask for return shipping information and a refund because I'm tired of being out $200 for something that doesn't work.
Has anyone else had a similar experience with their Cycliq gizmos?
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
Are you using your card or theirs? Mine did not come with a card, and I found out that if you don't use one of the "high speed" type mini SD cards, you can have problems. I used the card out of my phone and had problems until I replaced it.
Could be your card is not high speed, or not compatible, or damaged.
I had one that didn't hold a charge... but it was going on 4 years old.. so not totally surprised.. I picked up the current one and it's been fine.
I quadruple checked the settings and the card compatibility last night. I set it to beep for status every 5 minutes. It switched off every 17 minutes or so. The first couple of times, I was able to page into the app and reactivate it. The last time, it froze and wouldn't turn back on. Last reported battery was 77% so it's not dead.
The recordings from when it was on are there today, que milagro. It recorded 2x 5 minute segments each time. I was tracking the beeps and was definitely getting a third one before the light shut off, but that would be 15+ minutes and there's no footage to reflect that.
I'm going to try a different SD card this weekend but I'm not optimistic given the circumstances.
Sophomore Member
Liked 1,057 Times
You're using the software, right? There's a little Cycliq program that's used to adjust resolution, beeps, etc. If none of that works, I would guess you have a bad unit.
https://cycliq.com/software/
Quoted: 1020 Post(s)
Liked 463 Times
My Cycliq Fly 6 now works fine. Initially, however, it had problems. After a FW update it now works fine.
If you go to DCRainmaker, you will read many posts expressing your same frustrations.
Try the FW update and see if it helps.
BTW, I only using the camera feature and not the light. I use something else for a light.
Hi OhLylo,
I am a representative from Cycliq and I am so sorry to hear you have experienced these troubles. Without your name I'm unable to look up your support ticket, may I have this please?
In the mean time, I would definitely try another SD card. It could be the SD card itself - might just be dodgy, even if it is on our approved list. I would also ensure that you have the most up to date version of firmware. You can learn how to update your device at cycliq.com/software. This will fix any known bug we have had reported to us.
I apologise for making you take the above steps. If they don't work, definitely get back in touch with our support team at cycliq.com/support. I can also have them reach out to you if you provide me with either your email address, full name or last ticket number.
Thank you for your patience and cooperation, I assure you will make sure you have a working device as soon as possible.
Claire - Cycliq marketing assistant
Quoted: 18374 Post(s)
Liked 4,509 Times
Where did you purchase your SD card?
Never purchase any SD card (name brand or not) online from China via E-Bay (and probably not ali-express, Amazon, etc).
Quoted: 4559 Post(s)
Liked 2,802 Times
Try reformatting the card in the camera a few times. Seriously, some action cams can be very picky about media cards, regardless of brand and class.
Over the past couple of years I've gone from 8 GB to 16 to 32 GB cards, some SanDisk, some no-names, with my Ion Speed Pro. Each time the cards had to be used, reused, and reformatted a few times to clean up any glitches. Otherwise the camera would record only a few minutes and quit. But after a few uses all of them were reliable.
Before your next ride, try just running the Cycliq around the house until it's full. Check the files, then delete, recharge and run again (or run continuously from an external battery if you have one). Try that a few times and see if it clears up the glitches. That's what I do anytime I use a new card.
Sophomore Member
Liked 1,057 Times
Yeah, those mini SD cards can be really finicky. Once I have one in the camera and working properly, I don't like to take it out unless absolutely necessary. When you think about how much bulk data they can hold, and how small they are, it's pretty amazing they work at all.
Liked 463 Times
That a tiny SD card can store 32, 64 or even 128 gigabytes of data is nothing short of a miracle.
Liked 4,509 Times
One other point about the microSD cards is that there apparently was a change at 32 GB.
I think the first generation Cycliq Fly devices only go up to 32GB.
I'm not sure about the 2nd generation Fly CE devices.
Liked 463 Times
8" floppies, 5 1/4" floppies... or those tiny 3 1/2" floppies that the Macintoshes used (with a huge 1.44 MB capacity)?
Liked 463 Times
Yes, I have the software. The first cam wouldn't talk to the software, at which point they sent me a new one. The second one can talk to the software (if the mood strikes it - it's fickle), but doesn't solve the problem; it doesn't do anything the app can't do, anyways.
Worth a shot, I suppose. That said...I'd be annoyed if I had to use two devices because the light and camera won't work together. Defeats the purpose IMO.
Amazon, not from a third party seller. I don't do eBay or Ali Express.
I use the Garmin Varia RTL510 and I prefer using its built in light. Prior to that, I used the Cygolite Hotshot 150, it is far brighter than the Cycliq Fly 6 light.
I think that combining a light and a camera was a bit of overkill. I would’ve been happiest with a camera-only device.
Today's update: I did the firmware upgrade last night. That worked fine. I fired it up this morning for my commute, and it shut itself off before the 15 minute mark. Thankfully, I remembered to attach my other rear light so I wasn't invisible on the road.
Did you get in touch with the Cycliq person how reached out to you above? Get a different unit.
Liked 4,509 Times
Your Fly6 is mounted vertically, right?
Yep! Vertical mount on my rear pannier rack with their optional rack mounting thingy.
I didn't, but only because I filed a PayPal claim for a refund. This is my second one - what are the odds that I got not one, but two factory defective units? I had a support ticket with them already and requested a refund after my second unit didn't work, and they wanted me to ship it to Western Australia from the US, which is ~$85...
I just received a Fly6ce and installed a 64GB Samsung Evo 32GB UHS-1 card and it worked perfectly.
J.
The odds on that are extremely low. I know you don't want to hear this, but I'd bet it is something you're doing. With outgoing quality levels on electronics being what they are, that's is the more likely outcome.
J.
J.
