I'm sorry...some modern drivetrains are stupid
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,828 Times
Not only ugly, but contrived, heavy and fragile.
Derailleur so far offset from axle looks like a poor engineering decision analysis effort, especially given gravel riding and the bumps and pounding it takes. Fat and almost flat probably cushions much of the blow.
The future of road bike cycling = mechanically challenged, but fat and nearly flat will absorb the lack of sophistication (and make us all faster in the long run?). Probably applies to sub-900gm CF frames, as well.
?How large a spoke protector is needed? Maybe the gravel wheel spoke protector is a disc wheel. The next great product in the evolution of 1X drivetrains = tough gravel disc rear wheels! Made out of lightweight CF = the newest $5000 component.
Likes For Wildwood:
Quoted: 964 Post(s)
Liked 1,451 Times
I thought Olivetti made typewriters.
Quoted: 1372 Post(s)
Liked 1,749 Times
A bit of a challenge to the eye, first time I took a look at this style of bike. Now, I have no issue with the appearance and cannot help but wonder about ride quality. Perhaps, this summer the guys at Fresh Air Experience will let me try one out for a bit.
Señor Member
Quoted: 1491 Post(s)
Liked 1,089 Times
Those transparent pedals are super light and awesome!
Likes For USAZorro:
Veteran, Pacifist
Liked 4,828 Times
Give me a lever long enough and I can shift the position of the Earth. Assuming the lever is sufficiently stiff and durable.
small ring
Quoted: 437 Post(s)
Liked 925 Times
anyone care to explain the fork?
72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
Clearly, it takes some of the some of the stress and loading off that one fulcrum point right below the lower headset and shifts it instead to the steerer tube on top. Since stress and loading on that point isn't a problem for other off-road bicycles, no, I can't explain it.
Likes For Headpost:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
That frameset having slider dropouts--you could change the wheel/axle to a fixed SS or IGH or just about anything. It is a very flexible platform.
Spoke protectors are great...if you're the sort that ignores your low-limit screw.
Quoted: 1635 Post(s)
Liked 824 Times
"Olivetti" a cool brand name from the past for me! Reminds me when my Dad brought home a wide carriage Olivetti typewriter from his office, for me to use when I was doing book reports in gradeschool. I felt superior to my classmates knowing that they were using "regular" typewriters to do their homework. They do their stuff on Remingtons and Royals, I do mine on an Olivetti! I guess it was like I was driving a Ferrari for me. My dad got worried when he noticed me one day admiring the IBM Selectric on his secretary's desk though, he did not take me to his office on weekends that much after that......
Regarding modern drivetrains, just looking at a modern cassette freewheel shortcircuits my C&V senses. Soooooo many cogs and teeth! Could I really use all that? Wouldn't that weigh too much on a race bike? The bicycle had totally totally lost the beautiful, efficient and elegant simplicity it had in the 80's. Heck, I would not be surprised these days if modern bike actually has "Non user servicable" components on them.....just like our mostly plastic and over-teched cars today.
Quoted: 4722 Post(s)
Liked 3,036 Times
They're called truss forks. The earliest example is likely the mid-1890s Pedersen bicycle, though these did not catch on. The style was subsequently used on early motorcycles and the bicycle industry took their lead from that. They were popular on American bicycles from the the Great War period though the 1950s, when it was popular to have bicycles styled like motorcycles, with faux gas tanks, double top tubes, axle mounted kickstands, etc. The leading truss strengthens the fork while allowing blades of smaller diameter and thinner material, without the forks collaspsing. Basically, it gives the best strength to weight ratio.
Likes For T-Mar:
Quoted: 1136 Post(s)
Liked 650 Times
No offense Wildwood but is your off-the-cuff rant against the Shimano MTB drivetrain motivated by experience, or speculation? Having used the 1x Deore XT drivetrains in the past on both mountain and "gravel" bikes, it works quite well and I don't think anybody reports any issues with fragility. The designs have been OEM on mountain bikes for many years now and I'd think if the issues you're bring up are real, the many hundreds of thousands of people who have actually ridden the components off-road would have mentioned them.
Likes For TenGrainBread:
The truss fork is fixing a problem that does not exist, however it is great product differentiation, and I suspect that is the sole reason this company uses it. As for direct mount derailleurs, I suspect Shimano has something up their sleeve in the future to make use of the "superior" properties of the direct mount. If it is just to create a new standard, then it, too is fixing a problem that does not exist.
Likes For TiHabanero:
Likes For Brad L:
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 433 Post(s)
Liked 3,443 Times
Chuck Norris wouldn't need a lever.
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Likes For SpeedofLite:
Liked 406 Times
The RD hangar isn't even really a "standard". You bend a hangar-what do you do? There are ten million and "n" different hangers for every different frame ever made through all time that hangars are replaceable and all of them are unique snowflakes one-offs for one specific make and year and tier and model--and none of them put the RD in the same exact spot WRT the axle and cassette. The only thing "standard" about it is that the bolt threading for the RD is the same--otherwise it is a free-for-all.
The DM standard is very precise about where things goes, it also apples-apples shifts better. I've used it on the same frame with the same RD. Don't take my word for it--I asked Paragon Machine Works about this and this is what Mark Norstad of PWM said:
Our Direct-mount hanger specs are taken directly from Shimano's
standards. The difference in position you're seeing is probably a
result of where the conventional hanger is located. Standards for
conventional hangers are not as well defined, and typically have a lot
of leeway, sometimes as much as 6 mm total tolerance, depending on which
standard is being used.
True, it is a longer lever arm, but it's probably still stronger than
the link that Shimano supplies, and DM eliminates the link and extra
bolt for what could be considered a stouter hanger.
My personal experience with DM is that it is a big improvement over
previous systems.
previous systems.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
So did I. And although the font style looks similar, I don't think there's a relationship between the two. The bikes are from Boulder CO, and bear names like "Thunder Pig".
That Valentine, BTW, was designed by Ettore Sotsass, and came with a beautiful case as well:
My very first computer was also an Olivetti. An M15 laptop with a detachable keyboard and two 3.5" floppy disk drives:
OK, back to American bikes.
Liked 3,036 Times
Actually no, this is just a Shimano "direct mount" RD. that ends up about in the same physical alignment as a traditional RD with hanger (and mounting knuckle). The DM mounting is stiffer and more precisely standardized than RD hangers to boot. The odd visual is purely camera alignment and gearing. Sadly the DM standard hasn't caught on, but it is superior....so it is probably going away in the dustbin of history.
Likes For T-Mar:
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 427 Times
https://www.jonesbikes.com/
- Jeff Jones uses a truss for, along with fat tires, for "suspension" ~ sorry, that's not the right wording, but in lieu of a spring / damper assembly, he's selling a truss fork and fat tires.
Oddity Cycles
- another purveyor of modern day truss forks.
- as to the OP, I prefer a more traditional 2x8 or 3x8. Maybe the new 1x ZY set ups are better than the old stuff. I don't know. It seems like the rear ends of the modern bikes keep getting wider and wider to accomdate a 1 x 13? 1 x 20? when they gonna stop? how wide a rear-end on a bike? 200mm?
I would love to get something like a 135mm rear hub with a 3X5 gearing and a lot less dish on the wheel. Wouldn't that give a long lasting durable rear wheel set up? I think so. It's OK to say tell me how I'm wrong. (and yep, I'm still talking rim brakes....)
ciao!
Oddity Cycles
ciao!
Likes For mrv:
That said, the standardization of DM placement is an improvement, and the placement is probably better insofar as having a derailleur's upper knuckle start behind the rear axle sort of makes sense.
small ring
Quoted: 437 Post(s)
Liked 925 Times
I'm waiting for chainrings and cassettes to be mounted on universal joints to straighten the chainline
Veteran, Pacifist
Liked 4,828 Times
Are you attempting to imply it is a more attractive drivetrain from a different angle?
I have no experience with 1X drivetrains except a 1X1 and 1X5 - definately not an upscale drivetrain.
for the mountain bikes and mountainside off-roaders I do not choose to dictate components. The need for mud clearance and components that do not jam in heavy dust/dirt and withstand a bit of bashing. The Olivetti seems to be in that camp.
If it is not catching on, there are probably multiple issues from various industry camps so 'superiority' may prove elusive. You should collect a bunch for their future value.
Veteran, Pacifist
Liked 4,828 Times
It seems to me the size of the cassette dictates the sliding drop-outs to keep the rd out of the cogs across any range of adjustment (and for disc brakes too)
I do agree with whoever said it's so superior it's guaranteed for the dustbin.
Like OS2 Warp from IBM was better than Windows.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
Tuss frames and forks have already proven to have merit. Moulton's come to mind. Airplanes too (except 'bailout' Boeing)
This police auction space frame sold for $600 in TO.
