FSA crank/bottom bracket creaking
SD
So after 700 miles my FSA SLK cranks/bb has finally bit the dust. Probably just the bb but I'm in no mood to swap out the ISIS for another ISIS. Help me pick the replacement. Looking for the best bang for the buck.
Bike is campy record drivetrain. I'd love to go Chorus or Record UltraTorque but I'm hoping to spend less.
Considering SRAM Force for the quality/weight/price point. Other suggestions highly appreciated.
Here's the bike.
Here's the bike.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
ultegra...
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
I had a similar issue with mine (same crank), the bb could never get tight enough and creaked... FSA replced it for me.
1.9lb/in
Bikes: LeMond, CAAD9/1
Liked 5 Times
or that...
hooray for spring
Bikes: 2008 Look 586
Bikes: 2007 Specialized Tarmac Expert, 2007 Specialized Stumpjumper Carbon Pro
Funny after 2000+ miles my new 2007 Tarmac expert w/ FSA crank has been creaking when I stand or put huge pressure on the pedals while climbing....I tried to tighten the bolt and it got super tight but after one ride it was creaking again....what should I do?
Gear Head
Bikes: 07' Colnago CLX, 04' Allez,03' KHS, 79' super leTour304
Send the bike to me. It is broken and cannot be repaired. I will take it care of it for you.
Gear Head
Bikes: Too many...
Send the BB back to FSA, they're pretty good about replacing crapped out BBs. Once you get the new one sell that bad boy and replace with a Token/KCNC ISIS BB, Lighter and much better quality!
Portland Fred
I had a POS FSA crank that developed a creak after about 1500 miles. Tried all kinds of things including replacing the BB. The guys at the shop thought the noise was probably the splines on the crank arm causing the noise.
I replaced it with Shimano. It weighs a bit more, but I'm much happier.
hooray for spring
Yep I am going to talk to FSA...I am totally bummed though. I am smack in the middle or race season and can't be taking off a few weeks of training while I send out a BB....any chance they would next day one?
Gear Head
SD
Ordered the Crank Brothers Cyan BB, CrMo. $62 shipped, 5yr warranty. If it still creaks it'll be the arms.. otherwise if it fixes the problem it'll be the cheaper route to fixing the issue. I'll upgrade later.
Gear Head
Gear Head
