Replacement Fork
Replacement Fork
What would be recommended to replace an entry level fork? This is for a 2009 Trek WSD 820. Currently has a Suntour M2025 with 63mm travel and is threadless. Wouldn’t mind a rebuild kit but can’t find any. Of course everything is out of stock right now but putting together a parts list for when available. I can find forks with longer travel but don’t want to mess up the geometry. Also I don’t need or want to spend a bunch because it will be lightly used.
I have considered a rigid fork but she wants to stay with suspension. Thanks for your help.
I don't love them, but if it's just a little squish for comfort rather than serious trail riding Suntour XCT/XCM/whatever in 80mm would be a reasonable choice. 820 is pretty far down the line, not sure if I'd advise anything higher end than that.
I know that bike has no inherent value but I can get the powder coating done and still have less than half into what a new bike would cost. Plus there is some satisfaction in keeping it going and out of the junk pile.
I would put a rigid fork on it before I spent money on a cheap suspension fork.
Cheaper, lighter, simpler, better.
If you do want to go for suspension, I can recommend the Manitou Mattoc Comp.
This fork came standard on my Mongoose mtb and has been an absolute beast.
Even after 3 years of drops, big jumps, and rock gardens, it works great and is still on it's first set of seals.
