high end stuff
Quoted: 760 Post(s)
high end stuff
I'm wondering why nobody seems to offer high end stuff for touring. It's possible to spend $10K + on a single bicycle. That puts Co-motion and such solid in mid-range. Folks like Calfee, landshark, don't seem to offer the right geometry with eyelets and such for a real touring frame. The tandem folks do talk about carbon triple cranks, and Di2 derailers, also carbon wheels and some other things.
So is it at least theoretically possible to put together a high end touring bicycle?
What would it be?
What would it be?
Squeezebox, The touring market probably isn't large enough for a manufacturer to offer a really high end model. If one should consider introducing a high end model, what would it be? Look through the photo thread and there is a very wide variety of touring bikes owned by forum members.
There is also a lot of conservatism WRT component selection, to wit disc brakes are fairly new to touring bicycles...not to mention opinions about them, or 2X drive trains, and frame material. If I had to just spend a lot of money on a touring bike I'd look no further than Bruce Gordon. Even then it probably wouldn't cost as much as a high roadie.
Brad
Brad
Someone will build as expensive a Bike for you as Your wallet is ready to absorb.. custom frame and His racks from say Bruce Gordon in Petaluma*
You can even Order a custom frame from say a German Framebuilder and Fly to Germany and get on it and start your trip.
Or Order a Custom assembled Bike Using the NL Koga Company's Signature program of parts Menus, and fly to Shiphol, the AMS airport
Specify it sent to one of their Dealers in towns Near By..
and do the same sort of Fly and Ride with It. * fly and ride to Petaluma can work too, as there is a 101 Bus from SanFrancisco.
Quoted: 18371 Post(s)
Liked 4,507 Times
Most of the Bike Friday bikes will hit between $1000 and $2000, but as with many things the sky is the limit. So, I'm sure they'd build a Campy Super Record bike if you wish. Di2? EPS?
Mad bike riding scientist
Quoted: 6215 Post(s)
Liked 4,213 Times
What would it be?
What would it be?
As for spending a whole lot of money on a bike, it depends on what you hang on the frame. A set of wheels with Phil Wood hubs, DT Alpine spokes and Velocity A23 rims (with an OC rim on the back) will set you back $900 without labor to build it. A good drivetrain could add another $1500. With assorted gewgaws, it wouldn't be difficult to push that $10k pretty hard.
Stuart Black
Stuart Black
Sunshine
Quoted: 10954 Post(s)
Liked 7,482 Times
Quoted: 77 Post(s)
Liked 19 Times
Go cu$tom and get exactly what you want,
Pricey? Sure . . . but our custom carbon fiber tandem has over 40,000 miles on it so far.
Wheel Builder
Quoted: 17 Post(s)
I've noticed many touring cyclists are very budget conscious. Maybe that's why?
I've dealt with custom tandems and customers have different mindset. For an example, Custom Helix tandem will set you back around $18k with couplers and $20k with Calfee version. A triple tandem that can be double or single will set you back$25k. And these are just for the frame and fork. So with set of Enve's and DI2 with hydro? We are looking at $35k+. I do consider them as touring cyclists as they usually travel a lot.
The common thing about tandem customers are the partners are all equally into cycling and they ride a lot together. Also they want to get it right at the first time and don't want to waste time on wrong equipment.
Why so few $10k touring bikes? Same reason there are so few $1k sandwiches. Not enough dumb asses in the world to support the market segment.
and give us a report on how superior they are.......for collecting
dust and/or drying underwear in the basement.
Quoted: 137 Post(s)
Liked 81 Times
You silly person, "they" don't offer it, you seek it and find it. You seek out $20,000 end tables, "they" don't offer them. You seek out $50,000 watches or $600,000 cars. Where do you get such nonsense ideas. If you want a $20,000 touring bike someone will create it just for you. They didn't offer it, you sought it.
Also in town and both consulting often with Bi Fri, and making his own is Rob English, custom bikes ,
Human powered machines Cargo bikes.. [Winter cycles Bi Fri alumni. left town ] Co-Mo still there.
(I am thinking of a frame swap Pocket Llama for a NWT's, lower BB..in town foot down .)
Quoted: 33 Post(s)
And who really uses their bikes? Pretty common up here to pull a trans-can. That is a whole summer on the bike.
To me the question is are all tourists really cheap, or is the custom segment so ingrained we don't need the upper end. When custom bikes started to be built back in the 60s revival, Mariposa for instance, up here. Touring bikes were a big part of it. Early custom bikes were heavily represented in touring. And boutique parts like Phil also served that market. And today there are tons of people offering frames and parts, so the bikes probably exist, but we just don't see them here. You aren't going to get a whole long thread on Mariposa, but they are well enough known by people in the know for Rivendell to do a profile.
That said, 10K might be hard to hit. If you buy all the most expensive parts, and a frame, it might be hard to get up to that level. Bikes are pretty cheap compared to other products, the market is huge.
Quoted: 33 Post(s)
I am not convinced that touring bikes would be better with a lot of stuff like electric shifting, or carbon. Depends what makes a bike better. When designing my own frames I tend to think along the lines of classic touring bikes, or throwing everything you can for a more modern approach. I have yet to build the later, but there are a lot of technologies that could be added. There is also a lot of custom work that could be done to modify parts so that some of the blind spots like the badly integrated levers, or poorly design handlebar, cockpits could be improved on.
There is very little on current touring platforms that couldn't be improved if you think about it. But marketing down blind social media alleys doesn't usually get you there. It gets incredibly supportive articles about whatever is coming out for some other aspect of cycling and how great it is. Like 4 inch tires, which I think are swell, but what about some better parts for the bikes we actually use.
- Design a carbon touring bicycle with strong & durable yet lightweight components.
- Build a prototype.
- Do a Kickstarter
- See if you get funded for production.
Liked 4,507 Times
Who are those people who take 6 months off and ride cross-country, carrying their own gear, and sleeping in tents?
But, I would imagine they also cover a vast range of people including those on a shoestring budget, and those that bring caviar for their meals.
One of the issues with big business is that their business model doesn't necessarily include low production boutique style products, unless it fulfills a certain advertising niche (pro racing). Someone recently posted some notes about a beautiful Trek Transporter Cargo bike. Unfortunately, I would imagine the sales were low, so they just dropped it, rather than producing and marketing a low volume bike.
Deserved or not, there is some stigma towards Carbon Fiber. Perhaps due to an inherent weakness in road bikes that is not necessarily found in CF MTBs.
Sunshine
Liked 7,482 Times
I am shocked there have been so many legitimate responses to Squeeze asking this question...again.
Quoted: 33 Post(s)
He is just one person, there is an interest in high end touring bikes, someone bought the one Sachs made. I think there are a lot of people who wanted in but couldn't afford it when they were young so they are into it when older, but they don't need to come here for endless discussions of Salsa vs LHT, which are not that interesting since the bikes in question are pretty similar to each other and year over year.
What there are here are a lot of buyers of serial 1500 dollar bikes who could have just splashed out for the Gordon when they started out.
Also, in Europe there are more expensive bikes that are production made like Thorn and Toute Terrain.
+1. The Pocket Llama seems to me to be a very fine touring machine. If you feel like an upgrade, get the Chris King headset, the SRAM dual drive (or Rohloff) for a bona fide mountain climbing gear range, and the pricey touring saddle of your choice, for a total cost maybe $2,800+? (Rohloff would be an extra grand?) Spending more than that to save a few grams (when carrying 20+ pounds of gear) is simply stupid, and uses funds you will need on the road. If you go touring, you will see the truth of that. If you're not carrying gear, you might as well be riding a road bike, and you'll spend the extra money on motels and restaurants.
Nice thing about the Rohloff in a 20 " wheel is the same 2,35:1 minimal gear ratio, in a Big wheel 38/16;36/15
can be the inner chainring of a double.. The 38/16 in a 26" wheel in a 20" wheel I use a 53/16..
Or Speed Drive geared crank, the 36t in overdrive is a '57.6t'
Quoted: 138 Post(s)
Liked 17 Times
When weight isn't an issue then weight isn't an issue. Until tourists get smart and start dropping weight out of there packing setup there's no reason to build an ultra light bicycle for the heavy weight carrying tourist. Talk about stupid idea.
Then take on the simple fact that $10K will take you quite far across the country/around the world, even if you are spending every night in 5 star hotels and eating in 5 star restaurant for breakfast, lunch and dinner everyday. You could live in the lap of luxury and not even anything more than a regular touring bike and wouldn't have to take any extra gear with you other than the credit card. You could last quite a while on the open road with $10K. Spend the money on the lap of luxury instead of on the bike. Better yet don't spend the money at all and then you can last for ages on the open road. I spent $1400 in 3 months and 8400 miles last year on the open road...was in all states east of the Rockies and 20 state capitals. Since I didn't spend the $10K I didn't have to make the $10K to afford my trip so I could stay out longer and not have to be home tomorrow to work so I could afford the the next trip.
Sometimes it just all comes down to using common sense...something most people don't have anymore in this day and age.
The only way I would want an $10K style bike was if I was still 18-25 years old and had a chance to enter the pro racing scene. Otherwise it's a total waste of money. I could spend the money on other things much better and much more wisely.
