Laprade seatpost tilt adjustment?
Bikes: '59 Raleigh Lenton, '86 Peugeot PSN-10 Triathalon, '84 Peugeot PGN-10, 8? Peugeot UE-18, Peugeot NS-540, '86 Giant Iguana (Xtracycle), Holdsworth Gemini tandem, Surly Cross Check fixie, '86 Centurion MV Ironman
Quoted: 11 Post(s)
I'm building up a '87 Trek Elance 400D for a buddy to ride in the MS150 this fall. It has what appears to be the original SR Laprade P5-E seatpost but I'm suspicious of the two top pieces, which appear to have been taken from a different seatpost. In any case, there doesn't appear to be much, if any, ability to adjust the front-to-back tilt of the saddle with this arrangement.
I found this post but if that's the same model of seatpost then mine is incomplete. Does that look like the case here?
Quoted: 11 Post(s)
Ahhhh... bottom piece was stuck in place, quick tap with a mallet popped it out. Makes much more sense now. Thanks Grand Bois.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
The Laprade came in two flavors...the nicer all aluminum model, where the shell halves are cast aluminum, and the one you have which use stamped steel halves. The pics look like it's complete.
HelloClarice
Classic & Vintage
2
10-20-17 01:22 PM
PunkPatriot
Classic & Vintage
38
06-14-10 01:10 PM
