Stiffening Touring Shoes?
Quoted: 235 Post(s)
Liked 349 Times
I have been using my old Avocet Mod 20s "forever". I've loved everything about them for decades. Lately, I seem to be getting some cramping in the sole of my right foot and (maybe my imagination?) I seem to be able to "feel" the pedal pressure more (Campy Records). I was thinking of some type of insert. Any type of insoles I've seen are designed to cushion - not stiffen as would seem to be what I need. Has anyone had a similar issue with Vintage cycling shoes? Have you found some type of stiffening insert that works? I really don't want to replace these shoes because everything else about them rules!
Quoted: 809 Post(s)
Liked 1,022 Times
I work with circuit boards. A .020" circuit board would work well. I have been temped to do this with my street shoes. Just trace the insole and place it in the shoe, then put the insole back on top. I haven't tried it yet.
You might be able to get some material from DigiKey. They have .031" material. You might also find it on Amazon and other suppliers. The copper is anti bacterial. That could be a bonus. Try a search for .031" copper clad pcb material.
Quoted: 18376 Post(s)
Liked 4,511 Times
I thought the typical circuit boards were rather brittle. Are there boards that aren't brittle?
I have a Specialized SPD type shoe around somewhere where the cleat plate (half the insole) cracked. I've thought about trying ABS plastic to replace it. ABS should be fairly pliable and easy to shape with moderate heat.
Quoted: 235 Post(s)
Liked 349 Times
Thanks, good suggestions; maybe I should do some trial and error fabrication.
Quoted: 4560 Post(s)
Liked 2,802 Times
Different pedals? Unless you prefer period and style appropriate quill or other pedals.
Also, check out Profoot Miracle insoles. Only $8-$10, best insoles I've ever used. And with foot problems since I was a kid, I've tried 'em all, including custom made orthotics. The Profoot Miracles are the best. Thin to fit even snug-fitting shoes, ultra-lightweight yet dense and resilient foam, not gel. I have 'em in my Scott and Fizik shoes and bought extras in case Walgreens doesn't have 'em next time I need a set. They're good for at least a year. Prevents hotspots in my metatarsals and reduces arch cramps.
On my hybrids without clipless pedals/shoes, I found larger platform pedals relieved cramps in my arches. Spreads out more of the effort so I could ride with almost any reasonable shoe, even some deck shoes with thin soft rubber.
And looking back at my Strava logs, I'm not much faster now in the two years since going clipless than I was using platform pedals on my road bike. Different technique, maybe a little beneficial over longer rides with hills. I actually do pull up a bit on the pedals for climbs.
Same years ago when I switched from platform pedals to toe clips and cleated Detto Pietros. Didn't really add any power or speed. Just made it a bit more efficient over 50-100 mile rides.
Bikes: Masi Gran Criterium, Derosa, Ron Cooper, Davidson, Miyata 912, Le Jeune, Klein Rascals, AMP Research B3, B4, B5, PX10,Holdsworth, Schwinn Paramount, Frejus, Erickson, Simoncini SLX, Cecil Walker
Quoted: 54 Post(s)
Liked 115 Times
i actually tried making thin hardwood plywood insoles to stiffen. couldn't get them in the shoes because they don't flex. only way they would go in is if i trimmed them down and that would be unpleasant inside the shoe. I need to find just the right plastic i think.
Likes For Salamandrine:
Quoted: 809 Post(s)
Liked 1,022 Times
This is why my first recommendation was for .020" thick board. It is flexible enough to work. .031" should still be flexible enough to work. It might be stiff to walk in. I'm not sure about that.
Perhaps if if you don't have access to thin pcb material, try the other suggestions first.
perhaps I need to try out the pcb material in my street shoes and report back.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
I've thought about something like this
https://steelflex.com/products/soleg...oles-by-stlflx
For riding my fat bike with my mukluks. Looks like it could work for you.
Quoted: 1163 Post(s)
Liked 442 Times
Also, how do you cut it? With a cut-off wheel? Do you glue it to the bottom of your insole?
Quoted: 809 Post(s)
Liked 1,022 Times
At .020" thick, you can use tinsnips. At .030" a Dremel with a cut-off wheel might be better (dust mask required). I would cut it to fit the entire insole. If needed later on some more material can be added under the ball of the foot.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
I had a set of Cannondale shoes- they had what looked like a wood insole in them and then a separate foam insole to go over that.
Commence to jigglin’ huh?!?!
No one has said it but I will.
BUY SOME NEW SHOES.
Really, do it. There are a lot of great options out there right now (unlike 5-10 years ago).
BUY SOME NEW SHOES.
Likes For Bad Lag:
Likes For Bianchi84:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Try Kydex, maybe 1/8". Flexible but not too flexible. Easy to cut with tin snips. Can be heated and shaped if needed to fit into the shoe.
Takes a lickin' and keeps on tickin'.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
so you could get some hard plastic orthotic inserts. I have these in my cycling shoes. They are custom made. I think they cost about $400 bucks.
they really help !
Mark Petry
Bainbridge Island, WA USA
they really help !
Mark Petry
climber has-been
Quoted: 3430 Post(s)
Liked 3,566 Times
How much are you willing to spend on a stiff insole?
If the answer is “plenty”, then consider the Solestar BLK. Carbon fiber from heel to toe.
Review here
Review here
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,483 Times
Hard to believe there's not a $10 cut-to-fit solution out there.
Liked 4,511 Times
My guess it is a fairly narrow market.
Nobody will do anything custom for 30 year old shoes.
There might be some market for stiffening non-cycling shoes for use with flats. But, since cycling shoes can also be used with flats, there would be no big need to do it.
And, for cycling shoes, one likely chooses the shoes with the desired characteristics.
Quoted: 767 Post(s)
Liked 1,898 Times
Review here
Review here
The insoles clearly need to be made from a high grade chrome-moly or manganese-molybdenum alloy steel!
In all seriousness, I'm a pretty thrifty guy, but even I would bite the bullet and buy some new shoes. New shoe day is, after all, usually a good day.
Quoted: 1949 Post(s)
Liked 2,010 Times
I used some Kydex to stiffen my Vans thinking they might be the ticket for toe clip shoes. There was not enough height in the shoe for the 1/8 inch kydex insole and my foot was cramped. If I find a wide shoe with room for them, I still have the kydex onsoles. Kydex can be purchased on eBay for about $10 for two 12x12 inch sheets. Try it. Before that I tried 1/8 inch plexiglass and it broke after about 35 miles.
to the op: will your feet bother you on any ride, or only the longer slow ones? I find that my feet will be bothered if I just cruise.
Liked 1,700 Times
I wish I could find some of the old 5-10 Dirtbags in my size.
Personally, I prefer a steel shank in the sole instead of any of the plastics or fiber composites mentioned.
Quoted: 235 Post(s)
Liked 349 Times
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
This thread certainly makes me miss my old Avocet Touring and Touring II shoes, which are still my favorites among all I have ever owned, although my Giro Rumble VRs come pretty close.
