Repainting a newer Trek kids bike
Just call me Carrie
My cousin is giving me a Trek bike that her daughter outgrew. But it's pink/white and my son would like it a different color. The bike is from 2014.
Best paint to use? Advice on prep? Do I have to disassemble it before painting? There's no rust and the current paint is in good condition. He'd like it to be orange.
Quoted: 1062 Post(s)
Liked 665 Times
Almost 50 years ago, my dad used Rust-Oleum, with a brush. The bikes that my brothers and I rode were probably second-hand. I kinda doubt that he stripped the bikes down to the brass tacks before repainting them.
Now, my feeling is that it doesn't have to be a pro job, because the bike will be outgrown soon, and handed off to someone else.
Just call me Carrie
Steel is real
Easy to dismantle it, wipe over the frame with a acetone damp rag so the paint sticks, I agree with others..just use spray cans.
Put it back together
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I would disassemble as best you can, slide some abrasive paper across the whole bike, and spray with a few coats of the color you like. You can wet sand between color coats and after the last color coat and add some clear if you like. Just be sure to let the paint really cure before you handle it and bolt stuff back up. There's nothing worse than smudging your paint job because you rushed it (I know from personal experience).
Liked 665 Times
Whatever you do, make sure your son is involved! These days, very few kids get to see a bike taken completely apart! My dad let me watch while he worked on my bikes. Both of my kids have gotten pretty handy with a wrench. My daughter completely rebuilt a non functioning bike, and now it's her campus bike at college.
Likes For Gresp15C:
Quoted: 2338 Post(s)
Liked 2,822 Times
Normally I would say for a good job strip the paint but with grow out of situation.....go orange fast
Takes as much of as possible and mask what you can't you don't want an all orange bike......and when you put back together use it as an opportunity to clean, adjust, add new cable brake pads good starter project for both
clean and light sand, consider using a primer coat
also a fair number of people have reported good experience with https://spraybike.us/ lot's of info on the site
any paint that is not automobile is not going to be adurable, but again in a grow out of situation not worth going there
Quoted: 1572 Post(s)
Liked 643 Times
The trick with spray painting a bicycle is there are all kinds of awkward corners, like between the chain stays and inside the main triangle. Also, round tubes actually have 4 sides so you have to spray them from all four directions to get complete coverage. Certainly not impossible but it takes practice to do a good job.
If you are contemplating doing the job without completely disassembling the bike, I seriously suggest using a brush. You're not going to get a professional looking job but you probably aren't going to get a professional looking job with a rattle can either.
It's a free bike, right? Until you fix it the most you can lose on this deal is zero. Paint it orange and keep the boy happy until he learns to ride. Get him a nicer bike when he gets a little bit older and a little more picky.
Just call me Carrie
This is the picture my cousin sent me. I'm assuming that the pink scrolls on the white part are decals. Really, I could paint only the front and then my son gets a white and orange bike?
Liked 2,822 Times
also for "non-girly" recommend a new saddle.....black
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I have a biking friend who let his kids paint his frame with acrylic paints, and it holds up well enough, so a rattle can or even appropriate paint isn't necessary.
Quoted: 1002 Post(s)
Liked 237 Times
The pink scrolls may be decals, but they may also be under a layer of clear coat. If so you are going to see them as a ridge in the new paint. But you may not care.
The good news is that the bike is a light color. So choose a darker color for the new paint and go nuts.
I did something similar to my daughter's first bike when my son became old enough to ride it. Here's some photos of the process....
https://www.bikeforums.net/general-c...e-2nd-kid.html
As you can see I took off everything I could except the bottom bracket (because it was just too much of a headache to mes with it and too easy to mask with tape)
Sanding down the original paint and clear coat is critical or the new paint will never stick right.
Hand sanding is a pain in the rump. In hindsight I should have used an electric sander for 95% of the larger sections and just done hand sanding in the hard to reach joints. Would have make it a 2 hour sanding project total.
As for the paint...I used Rustoleum 2X spray from a can. 1 can was more than enough. And it's proved to be very durable in the year and a half since I did this. But...wait at least 2 days between coats. And plan on 3 coats, with some small touch up spots that might need more. The adhesion will be that much better. I topped it off with the same brand clear coat, over top the decals. And did at least 3 coats of it. I'd do the clear coat even if you're not putting decals on it. Minor scratches will scuff the clear coat, not cut through the color paint.
Liked 237 Times
Oh....and pro tip...if you're not experiences with dissembling a bike entirely....just take photos of it as you take it apart.
They do WONDERS for making sure you are putting everything back correctly.
Just call me Carrie
Like most projects, I'll take it apart, do the painting, and then make my husband put it back together. It's our dynamic.
Steel is real
The frame style would still look a bit gay though, Not that there is anything wrong with that
Bikes: trek 720 multitrack hybred, 92 trek 2300, 2010 specialized roubaix, 2014 specialized roubaix
Quoted: 14 Post(s)
Liked 17 Times
PPG certified painter with over 30 years experience.
after dismantling and ready to sand.
a old painter trick to speed up sanding before paint.
get a red scotch brite sanding pad, https://www.google.com/url?sa=t&rct=...uaGRuSxvR9SUlH , wet down the bike with water, take some kitchen cleanser like Comet or Ajax. sprinkle it on where you want to sand and scrub with the red scotch brite. the cleanser will remove contaminates and speed up sanding. after scrubbing rinse well and you are ready to paint.
Likes For mrt2you:
Just call me Carrie
I only ride men's bikes--I'm not sure son would even notice that there's a difference. It's a new bike and it has *shifters*. Considering how fast he can get the heavy little 18" bike going (11mph/18kph), I'm guessing I'm going have one heck of a training partner once he gets this.
Quoted: 35 Post(s)
Liked 54 Times
I recently made a project with spray bike.
https://www.bikeforums.net/classic-v...sions-263.html
(see the "sabine" bike based on an old scott arapaohe).
I must say that the result is really nice, at least in comparison to my expectations.
BUT
It has been a lot of work for wet sanding properly the frame and rebuilt the all thing.
It costed me about 60€ for the paint itself (primar + paint + clear coat)
I am pretty sure that the paint is not as strong as the original one (epoxy cured ??), and it can not be stronger.
It looks really nice for an amateur job, but I am not sure that it suits a kid's bike . The bike must be used with a minimal care.
Just for your information
BUT
Just call me Carrie
Update.
It took a while to get this project completed, but this is the end result. I have a really happy boy who wants to ride his “new” bike all the time now. New saddle, grips, chain, pedals, cables, and brakes. Thank you to the folks who mentioned taking pictures during disassembly, it saved a lot of headaches. And thank you to a certain BF member (Jeff) who helped me take the head tube and bottom bracket apart.
it was primed/painted/clear coated with rustoleum paint. The kiddo decided on the design.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Nice!
I did my kid’s Hotrock in the spring. The worst part for me was getting the decals off. The tear down is a good time to discover any really heavy parts and decide if you’re going to replace them.
Also, I miss Skipjacks :-/
Just call me Carrie
What happened to Skipjacks?
Disco Infiltrator
Liked 2,105 Times
He wanted to talk firearms, was informed of the rules about that, and departed.
Genesis 49:16-17
Genesis 49:16-17
