A little "remodelling" surprise
Quoted: 206 Post(s)
Liked 102 Times
I've been rebuilding a 1974 Raleigh International and things have been going pretty well. I decided to rattle-can it and seal it with 2-part clear coat. Things were going pretty well until I removed the masking tape from the Nervex lugs. I figured I'd have some touch-up to do - both removing and adding paint where it was needed. My surprise came when I started doing some of the fine work and realized that even though the International is an upper end bike, it is still a mass production bike that can suffer from different levels of attention to detail. I know the Nervex stuff is intricate, but the level of finishing of the brazed areas was at best - rough. I don't think there's one part of the joint that is smooth and nicely finished. In the end, I was relegated to getting it finished as nicely as possible (which is still pretty decent from a few feet away). I'm not disappointed - I'm pretty sure the bike will look good and ride very nicely. I was just a little surprised. Here's the head tube prior to doing the final finishing work.
Some days, it's not even worth gnawing through the restraints.
Likes For ddeand:
Some Raleighs were built after a few lunch beers at the local watering hole.
You could try a paint pen to do some lug lining and see if that helps clean it up a bit.
Likes For Narhay:
Quoted: 1303 Post(s)
Liked 1,910 Times
+1 on the lug lining. That should clean it up nicely. Smiles, MH
Quoted: 4510 Post(s)
Liked 6,377 Times
Despite the greatly varying QC issues, Raleigh's production was nothing short of amazing,100,000's of frames flying out the doors and we still have many, many of them to drool, ogle, fawn and obsess over, most being solid, beautiful well made examples very far down the line.
Likes For merziac:
Quoted: 3811 Post(s)
Liked 3,336 Times
paintin' suggestion -
masking something as intricate as the NERVEX Professional pattern with masking tape is pretty tedious
for smallish wiggly bits like this it is easier to use one of the liquid mask products which are made to apply with a small brush
Raleigh QC -
during the boom can recall visiting the showroom o' me local agent. there were Reynolds tubing models on display where you could put your fingernail betwixt the lug and the tube...
Raleigh QC -
Quoted: 206 Post(s)
Liked 102 Times
I did that, too. I taped the head tube lugs and used liquid mask on the fork lugs - both worked about the same. This was the first time I had masked or taped lugs, so a great deal of quality of the results must be attributed to incompetence on my part. Actually, I might be tempted to just do the detail paint freehand next time. The frame and fork are, for the most part, stunning on several levels. I’ve learned a lot doing this project!
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Raleigh QC -
Raleigh QC -
Likes For RiddleOfSteel:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
I’m surprised that the OP is surprised that the finish work on an International isn’t most excellent.
Old Raleighs can look great from 10’. If someone were to give me a set of Nervex lugs today and asked me to build a frame with them, I’d probably quote double and hope the buyer got the hint.
You did a great job, btw!
Likes For gugie:
Liked 6,377 Times
Raleigh QC -
Raleigh QC -
Quoted: 206 Post(s)
Liked 102 Times
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
When it comes to doing repaints, I’m still pretty much a novice. I’m reworking a mystery frame with some high quality lugs but not the complexity of the Nervex lugs, and it’s obvious that they are more amenable to finishing. But those twisty lugs are so pretty! In the end, this bike should look pretty decent from a few feet, and that’s all I want. Thanks!
The paint looks good! Lug lining was often used to hide the excess brazing material you "found".
+1 on the liquid mask.
Can you comment on the 2k clearcoat? Was it applied before the headtube picture? Does fine wet sanding improve it. Does it actually make rattle can harder to chip?
Cheers, Eric
Quoted: 206 Post(s)
Liked 102 Times
Cheers, Eric
Cheers, Eric
