What is the fascination with Torx?
Installed a G2R disc brake yesterday and everything was Torx fitted. This got me thinking what is this fascination with Torx fittings? The bleed ports, which are super low torque fittings and clamp bolts are Torx. Why? What problem does this solve? Or is it a solution looking for a problem? Or is this just some twisted attempt to change the long standing industry standard of using recessed hex fittings or a really twisted way to increase tool sales or inconvenience home mechanics?
Likes For TiHabanero:
Quoted: 1438 Post(s)
Liked 1,092 Times
Torx drive is more resistant to "cam-out" than slotted or Phillips heads, and more resistant to stripping than hex drive. https://en.wikipedia.org/wiki/Torx
I suspect that they tolerate use with worn drivers better than hex, Torx kind of makes sense when reading the numerous posts on this forum asking for help with stripped-out hex drive fasteners.
Likes For dsbrantjr:
Quoted: 1188 Post(s)
Liked 1,154 Times
Automated assembly is easier with torx.
Likes For Trevtassie:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
I'm old enough to remember thinking the same thing when Phillips heads started showing up so much in the construction industry.
Likes For andrewclaus:
For a home mechanic it's way worse having something stuck and the hex becoming rounded than having to buy some torx bits, which are not all that expensive in the first place.
Likes For Amt0571:
Quoted: 4195 Post(s)
Liked 3,837 Times
I'll add that Torx allows a smaller bolt, or a smaller wrench fitting which then allows a smaller bolt, to do the job. Also a softer one, as in Al instead of steel. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2026 Post(s)
Liked 1,095 Times
Allen (aka hex) fasteners are quite sensitive to being damaged by cheap and/or worn hex keys, particularly in the smaller sizes. Torx are stronger and more tolerant of wear and I also much prefer them to allen bolts.
Quoted: 1814 Post(s)
Liked 923 Times
They work pretty well, but I share your frustration toward the proliferation of driver patterns.
With Torx in particular, you can't really tell the difference visually between a T15 and a T20, or between T20 and T25,
and the same fastener in different lengths might take different driver sizes.
I regularly deal with, and often carry in my pocket, T15, T20, T25, T30, PH2, PH3, S1, S2, S3, square/phillips combo, 1/4", 5/16' nut drivers, SAE and metric allen key sets, and 1/4" and 3/16" slotted screwdrivers.
Likes For woodcraft:
Quoted: 152 Post(s)
Liked 173 Times
I wasn't aware there was fascination with Torx fasteners in the bike industry. The only Torx fasteners I've run across in wrenching on my bikes were the chainring fixing screws securing the chainrings to the crank on Shimano cranksets. But I find them superior to hex screws in just about every application I used them.
Non omnino gravis
Likes For DrIsotope:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
As a guy who built his own deck one time, I agree!
you’re also never going to round out the Torx by using the 3/16 instead of a 5 mm because it’s the only one you can find right now
They are all over BMW motorcycles as well.
I am camping right now, so I think to add that our travel trailer is built almost entirely with square head screws. They are basically Phillips without the flanges. They seem to work pretty well, although I’d still rather have the torx
Non omnino gravis
Quoted: 3352 Post(s)
Liked 1,056 Times
That isnt the half of it. As an IBM service rep that started in '61 and worked until 2008 look what I had to work with.
Early IBM machines has standard allen wrenches. Then in the series the Co went to 4 flute bristo, 6 flute bristo, metric allen, and then torx. I had to carry a series of all sizes of all of them depending on the age of the machines. They all did the same thing.
Right now cyclist have to carry both metric allens and torx to be prepared on the road.
Quoted: 6177 Post(s)
Liked 4,794 Times
I've been wondering why the bike industry is still using Philips for tiny adjustment screw so long. Torx is definitely the way to go for small screws. Or even large screws too.
I even found some small torx screws to match the size and threading of the little tiny Philips screws they use in my Garmin HR pod. Makes getting them in and out so much easier. Of course being Torx, you have to be careful not to over tighten since they don't cam out.
A set of Torx driver points doesn't cost much at all.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
Always thought two things:
1. Torx is better at avoiding "cam-out" (fouling the heads' threads) than Phillips.
2. Mfrs, generally speaking, seem to under-spec the size of the bolt (or screw) for the function. Trying to minimize costs, I'd bet.
Much of the "stripping" of the heads could be alleviated by having larger/deeper-headed Torx screws. Always can be less likely to strip things with better, hardened tools.
That said, I've still seen stripping, and occasional breaking, of a bolt/screw head ... even with Torx.
Prefer them, myself, I suppose, all things considered. So long as it's hardened bolts/screws, sufficiently beefy for the application, with a good tool, and so long as precautions are taken with anti-seize on the bolt/screw itself.
Bikes: Historical: Schwinn Speedster; Schwinn Collegiate; 1981 Ross Gran Tour; 1981 Dawes Atlantis; 1991 Specialized Rockhopper. Current: 1987 Ritchey Ultra; 1987 Centurion Ironman Dave Scott Master; 1992 Specialized Stumpjumper FS
Quoted: 209 Post(s)
Liked 178 Times
Thanks, this is kind of a fascinating thread. I've only ever thought of Torx screws as a tech thing, didn't realize they were showing up on bikes. Also never realized their advantages.
Liked 1,092 Times
^ This.
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
You say that like it's a good thing...
Disco Infiltrator
Liked 2,102 Times
I understand why they did it. BMW don’t focus on making their bikes convenient for a shade tree mechanic. They often use three or four parts where a Kawasaki might have one, as well, and they have more sensors and computers. But you can always tell that there’s a reason they did it that way, and the result is better. The expense is expensiveness.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Judging by the comments in this thread, it seems everything should be torx. Maybe Allen Company had better marketing than Torx Company, and convinced the world to use an inferior product.
Liked 4,794 Times
I always love the conspiracy theory folks that think things are done to put a hardship on DIY'ers.
Wait till you learn what a safety torx is! (also known as a security torx)
There are inexpensive driver bits for them too. And they work in a regular torx socket.
Liked 4,794 Times
This soon to be eight year old article popped up: https://www.slowtwitch.com/Tech/Bolt...Win__3170.html
I have used square drive screws for decks and cabinetry and can say they take some serious torque loads without rounding out of the head. I assume that is the reason for using them. The head can also be made very small in relation to the screw shaft size.
One issue I have come into with Torx was the bolts securing a rotor to a hub. Bent the shaft of the driver bit, and rounded out the screw heads. Not sure any other screw type would have made a difference, but for sure Torx did not offer any advantage with those 6 bolts.
