Best 27 inch rims?
Best 27 inch rims?
Hey fellow C&V fans,
I just purchased a 1950s British bike that I'm looking forward to restoring. My goal is not to do an exact period restoration, but to use a combination of vintage and modern components that are reliable and look good to give me a classy bike to ride around town. I do want to maintain the general look of a classic bike (i.e. towntube shifters). While the bike is being resprayed, I am putting together the components.
Because of brake reach, I want to use 27" rims on the bike (I am happy with the Pasela tires). But what are the best 27" rims to choose? I won't be racing the bike, but I would prefer something a little lighter since I have to carry it up and down stairs. Doesn't have to be the same vintage as the bike--so like Araya is definitely in consideration.
There are hundreds of posts about 27" tires, but I haven't found much on rims. Thanks!!!
Quoted: 5888 Post(s)
Liked 3,471 Times
Sun cr 18 27 inch is a pretty nice rim and the price is reasonable.
Yeah, the CR18 is great--I have them on a ladies Paramount that I restored for my wife. Looks nice, easy to fit tires, and no problems so far.
I guess I'm just curious if there are any vintage rims that are considered as good, and maybe lighter, than the CR18s or the M13 IIs? Since 27" was much more common at the time, were manufacturers making higher end rims in that size? Or has rim technology improved so much that CR18s are just better than even the best 27 inch rims that were made back in the day when they were more common?
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I've used both CR18s and M13IIs (albeit in ISO 622). I have a few wheels with vintage 27" Wolber Super Champions, and although nice, I think I like the Suns better. As far as weights go, I think you're looking at maybe 450g on the light side so the M13 IIs are in the ballpark. The polished ones will look great on a vintage bike.
Can you even find classic rims NOS ? like Wolber Super Champion # 58 ..
Consider getting some built wheels bike shops get from their wholesale suppliers. ?
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 1372 Post(s)
Liked 1,751 Times
I have a fairly rare set of Weinmann alloy rims sporting the brake surface pattern. They came to me, recently and are in pretty darn nice shape. The wheels were on a late sixties (1968 I think) Raleigh Carlton. If interested in the rims only, I will post them in the for sale forum.
The wheels were fitted to this special US issue Raleigh Carlton from which I have harvested the components...
The 27" x 1 1/4" Weinmann rims have not been cleaned yet. Too many other projects...
Quoted: 604 Post(s)
Liked 1,063 Times
I don’t know about best, but not wanting to put CR18s on a high end bike, I found these on eBay. Pretty happy with them after a couple of hundred miles, and they look right on the bike.
Tim
Tim
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Probably tough to find, but I’m liking my 27” Ukai rims, which happened to be on Sansin GyroMaster hubs. 36 spokes in front & 40 in the rear, so pretty much bullet-proof, for touring. 😎
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
A good set of 27" aluminum rims with quality hubs that are in good riding condition are getting harder to find. I purchased a set in very good condition a few years back for about $125, then a few weeks later I found a almost identical set at a yard sale for $5.
My only advice ,dont be too particular on a Brand, as long as they are True dont have any flat spots on the rim and the spokes are not rusted thru any aluminum wheelset will do the job. A few minutes on a truing stand and some grease and poilish will bring out the best in a wheel.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
I wouldn't use Araya if you are looking for something proper for a British lightweight. I am also in love with Sun rims, but I wouldn't put them on a vintage bike. My recommendation is to go with Super Champions. The Modele 58 is a clincher, is aluminum, eyeleted, and goes back as far as the early '70's. The Super Champion Gentleman is a little lighter. You want 40H in the rear and 32H in the front.
Be careful of front dropout width and hub axle diameter, which is probably 95mm and 5/16" (8mm), respectively.
The Super Champions were made in great numbers, so some of them, to this day, can be found N.O.S. Cupertino Bike Shop has some 32H, and I have seen some (Wolber) Super Champion 40H on Ebay for a reasonable price.
If you are looking for as light as can-be, then you will want to go tubular, and Raleigh Katsaris has a nice, N.O.S pair of Birmalux Sprint rims. These would be appropriate for your build. If you really want a period look (actually about 10 years prior), then hold out for a set of Constrictor Asp rims. These alloy rims will probably be hard to find and expensive. Your only other option for period-and-place-correct are the Dunlop Special Lightweights. These are steel, British rims that were used on a lot of lightweights from the 50's to the 70's. I do not know their weight, though. Which marque, model and year is your frame?
Standard Member
Liked 940 Times
Yep, the Super Champs are probably the best way for O.P. to go.
Awesome, thanks for the great advice. The bike in question is a 1950s Holdsworth Whirlwind--not exactly sure on the year but it is after the Sirocco (sic) so probably around 1953-1959. It is currently being resprayed and rechromed, which is taking a long time.
I agree that the CR18s and M13 II's, while great, seem a bit out of place on this bike. The Super Champion Gentleman seems like a great choice, so I will be on the lookout for those. Also thanks to 1989Pre for the heads up about hub axle diameter, which I had not even considered. Cheers!
Likes For DanBikeFan:
Quoted: 702 Post(s)
Liked 672 Times
I've only had one pair of sew-up wheels and that was back in the 1970's. Since I never bought tires for them, I have no idea what size they were. Did tubular rims come in 27" size?
Following this thought process, I'm restoring a 1969 Swedish crescent with campy Nuovo record groupset and need some rims, the Weinman rm19's I have are only 36 hole and i need a good 40 hole option for the rear. I'd rather not have two different types of rims and they need to be 17 inch clinchers. I know the sun cr18 are a avalible but i think it will not match the quality of the build.
Thoughts?
Thoughts?
Liked 1,751 Times
The best vintage rims that I would suggest are the Weinmann concave style. A bit heavy but darn near bullet proof and they certainly look the part. I think that I have one, in the shed, but not sure. Took me tens seconds to find this set on Ebay and, in my opinion, the price is more than fair.
Quoted: 1303 Post(s)
Liked 1,910 Times
If you are looking for some rims, I have a pair of Wolber model 58 NOS here in the shop for any BF member that will use for a restore. Cost is $50 plus shipping. I am not trying to turn this into a for sale thread but tossing it out for your consideration. (if interested PM me) smiles, MH
Quoted: 1856 Post(s)
Liked 664 Times
What's the bike, what's the year, and what are you doing to it?
Some 1950s steel rims, such as Dunlop Special Lightweight 27x1 ¼ are VERY nice rims, which are even kinda light for a steel rim. Raleigh, at least, seriously looked at using steel in performance parts.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
The best?
Super Champion / Wolber Modele 58.
Commence to jigglin’ huh?!?!
