Do I need to shorten my chain?
we be rollin'
I'm pretty sure the answer is yes but I want to ask. I installed a Shimano Tourney 46/30 crankset where I previously had a 42/52. By the way this area is very hilly and it's a 30 lbs gravel bike so I couldn't see myself continuing with a minimum 42T chainring. Anyway, do you think I'll need to have the chain shortened? (I can do some things myself but don't have the tools for that one.)
Really Old Senior Member
Does it sag on small:small?
If it doesn't, you don't "have to".
If shifting seems a bit more sluggish, you might want to.
Likes For Bill Kapaun:
Quoted: 2338 Post(s)
Liked 2,822 Times
depends on what your rear derailler is and it's range and what you cassette size is...... not enough information for any sort of definitive reply. (probably but need details)
what ever you do make sure the big/big combo works
one thing you could do is put the bike in low/low and see if the chain drags on the derailler if not you are proabably good.
see this for low/low chain sizing
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I'm with Bill regarding sagging. It's very likely that you have an inch or three too much of chain, since your big ring is now the size of your former small ring. 10 teeth is a lot!
Follow Calvin's advice in this video if you have a chain tool, or bring it to your LBS or Co-op and ask them to help.
