Is there a Copper colored cable guard ?
Bikes: 1984 Sekai 5000 Superbe, 1987 Raleigh Seneca Mountain Tour, 1984 Schwinn World Sport, 1978 Raleigh Grand Prix, 2021 Handsome She Devil, Mystery Vintage purple road bike
Quoted: 99 Post(s)
Liked 124 Times
So this little cable guard was on the 1984 Schwinn World Sport I am fixing up. I am putting copper colored hammered fenders on the bike and wondered if there is somewhere I might be able to replace this original chrome colored cable guard that was on the bike? I think it would look cool to have a copper colored one to match the fenders
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,570 Times
Maybe cover that existing unit with copper colored self adhesive tape.
Likes For cb400bill:
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Good luck finding any metal chain protector these days, much less one that is copper.
Alternatives (use your existing protector as a template):
Copper Tape - https://www.amazon.com/XFasten-Condu...975900&sr=8-15
A piece of copper flashing would do, more expensive to source for such a small end use. Know any roofers who use it? They probably throw out remnants.
Likes For Vintage_Cyclist:
Quoted: 1372 Post(s)
Liked 1,749 Times
Get yourself a piece of 1/2 inch copper pipe. Cut it in half, lengthwise. Expand one half of the copper half pipe over something that you can use as an anvil to shape the inner curve to fit your chain stay. Once proper fit is defined, file or grind the copper half to shape. Clean up with a fine file. Water sand or polish the copper half to a mirror finish. And then, silicone seal the piece to the stay. And Bob's your uncle.
I did this once, many years ago. I found the piece to be a bit heavy but it did work for a while. I say for a while because, as is often the case, the bike got sold in short order.
Likes For randyjawa:
Quoted: 767 Post(s)
Liked 1,898 Times
There's always copper sheet:
https://www.mcmaster.com/metals/copp...ickness~0-021/
12"x12" for $16.95. Make a bunch of them. They have many other thicknesses available.
For those who can't find metal chainstay protectors, a 1"x36" piece of 304 stainless in .03" thickness will run you a whopping $7.15. They are easy to make. .024" is just over $6.
Likes For BFisher:
Quoted: 99 Post(s)
Liked 124 Times
Quoted: 99 Post(s)
Liked 124 Times
Quoted: 603 Post(s)
Liked 1,062 Times
You could also use copper vinyl wrap for a chain stay protector, just cut to size. About a thousand choices on eBay. Personally I usually use clear 3M leading edge tape, cut to shape and apply using the wet method in the instructions, almost invisible. Also works on other parts of the frame to prevent stone chip damage.
Tim
Tim
Likes For tkamd73:
Quoted: 99 Post(s)
Liked 124 Times
I used the copper tape from Amazon and it worked pretty good!!
