Trek 1x Conversion
Quoted: 9 Post(s)
Trek 1x Conversion
Hello,
I am looking to upgrade my old mountain bike to a 1x setup. The first thing is finding a compatible bottom bracket, I will attach a picture of my current one. I would like a Shimano setup, doesn’t need to be anything too fancy. Any help finding these items would be great.
Thanks
Thanks
Quoted: 1819 Post(s)
Liked 1,693 Times
Choose the bottom bracket after you choose the crank, not before. The crank you buy will determine the spindle length and type you need
Likes For alcjphil:
Quoted: 6193 Post(s)
Liked 4,808 Times
That BB tends to indicate that your shell is BSA threaded 1.37"x 24 tpi and 68mm wide. I'd verify the width by measuring the bb shell though.
Look for a groupset that has a crank you like that also has a BSA threaded BB as one of it's options. There are many of them. I prefer two piece cranks. But I've always used road bikes with road groups. But in mountain bike groups you'll be able to find plenty of 1x groups. If you can't go two piece crank, I'd at least get ISIS or Octalink. It'll leave you with less specs to worry yourself about than the square taper bb.
