Foot problems and pedals
In late 2020 they operated on my right foot. Between a bunion and bone build up from gout they took enough bone off my foot that it is a half inch narrower. May of 2022 they removed the sesamoid bones on the same foot. The joint where the big toe joins the foot does not bend titanium plate and screws. They want to do the left side. I have just got back to being able to ride this year. I find that I am running the pedals in the arch of my foot, instead of the balls of my feet because of tenderness. I have a set of inexpensive wide pedals ordered to try on mountain bike to hybrid/gravel conversion. Are wider pedals going to help me? I'm doing better as this is the first time since 2018 I have rode over 50 miles in a month and I am now over 120 miles for this year
ignominious poltroon
Quoted: 2242 Post(s)
Liked 3,443 Times
That is hard to deal with. I would recommend finding the stiffest bike shoe available, because you want to prevent the foot from flexing. You will probably want to figure out what the best insoles would be, too, essentially to take all of the pressure off of those joints and other areas where bone tissue has been removed. Also, there is a school of thought that advocates riding with the pedal spindle under the arch of your foot. I think there are specific pedals made for that kind of thing, too.
Liked 3,443 Times
Quoted: 4806 Post(s)
Liked 3,932 Times
Just a thought - shoe with a really stiff sole might be a large benefit. You could then build up under the good parts of your foot and have less under the sensitive areas. With that very stiff sole, you would have more options on where you place your foot on the pedal since its pressure will be distributed throughout the shoe. A shoe based on a carbon fiber or wood sole might be just the ticket. (With a leather upper and full length lacing so you have room to raise your foot .) I have no idea where this shoe might be found. Maybe a cobbler would have ideas.
Quoted: 896 Post(s)
Liked 2,065 Times
If the OP wants pressure spread along the foot, then yes a stiff sole will help get that done. That's typical of a person with healthy feet.
OTOH, if he needs to avoid pressure on the ball of the foot, a different approach is needed. He's adapting now by moving feet forward, and that might be what's needed. Right-sized pedals, flexible shoes, and something like Power Grips that will allow foot placement to be forward, might be the ticket.
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
Maybe post on the Internet-bob Google Group, asking about midfoot pedaling. It comes up there from time-to-time. It definitely has its adherents.
Quoted: 4560 Post(s)
Liked 2,802 Times
Check out iSSi Thump pedals. Generous platform, concave surface, very grippy even with the molded in pins (replaceable steel pin version available), and affordable. I've had a set on one bike for about five years, no problems or complaints. Great with almost any shoe, including my heavy leather winter boots.
To relieve pressure on sensitive parts of the foot, try ProFoot Miracle insoles. Best I've found. I've had foot problems since I was a kid -- narrow feet, high arches, very little natural padding over my walky bits -- and used to need custom orthotics. I've tried many off the shelf insoles and ProFoot Miracles are the best by far.
They aren't gel or memory foam. It's an ultralight foam that compresses and takes a set with use, conforming comfortably to the foot. Easy to trim to the desired size. They'll last six months to a year or longer, depending on usage and user weight. I usually get about a year in my walking shoes, and several years with my clipless cycling shoes. The ProFoot Miracles relieved hotspots better than anything else I tried.
I've changed the pedals on my 3 Surly's that are similar to the pedals linked above. Two sets are Rockbros and I don't recall the brand of the third set. . I rode my steamroller 8.3 miles today . I usually ride in stiff soled shoes. I rode in Crocks today to see how much the wide pedals helped . They are definitely easier on my feet
