Tubeless Tire Removal Problem
Old 12-05-23, 05:20 PM
gregjones
gregjones's Avatar
Bikes: K2 Mod 5.0 Roadie, Fuji Commuter
Quoted: 23 Post(s)
I have bought a used bike with M975 wheels. 19mm inner rim width, 26X2.0 tires. One tire was deflated and loose on the rim. I got if off the rim with just a little effort. The other inflated OK and held air for a day or so. Soapy water foamed around the rim/wheel mounting area. Today the tire is STUCK to the rim. I've been using 91% iso alcohol and letting it soak a bit several times. I still can't get the tire to separate enough from the rim to even begin to get a lever in. I have no idea what sealant was used. Any ideas to get it off?? Thanks!!!
gregjones is offline
Old 12-06-23, 10:33 AM
gregjones
gregjones's Avatar
Quoted: 23 Post(s)
It hit me last night that the utoobers use alcohol to remove residue from old rim tape. Water is the solvent for sealant. The tire should be off with a few more hours of soaking around the rim in sections. It's started working!
Old 12-07-23, 05:37 PM
tungsten
tungsten's Avatar
Bikes: 1962 Cinelli Mod. "B" / 1988 Bailey 531c /2 - '92 Rocky Vertexs' / Obed Baseline / Transition Scout/ Raleigh Willard
Quoted: 104 Post(s)
Liked 66 Times in 41 Posts
lay it on the floor and carefully step down hard on the tyre sidewall as close to the rim as possible
tungsten is offline
Old 02-13-24, 08:27 PM
sean.hwy
sean.hwy's Avatar
Quoted: 426 Post(s)
Liked 274 Times in 201 Posts
I have done something similar to this. I step down on tire close to the rim and pull up on the rim.
something like this
sean.hwy is offline
Likes For sean.hwy:
Old 02-22-24, 08:11 AM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times in 266 Posts
WD-40 is good to wick in and loosen the adhesion but clean well aftewards.
biker128pedal is offline
