Washing helmet in the dishwasher...Good or Bad Idea?
Bikes: No. 22 Bicycle Great Divide, Lynskey R260, Salsa Colossal Ti, Litespeed T5, Lynskey Peloton, Bianchi Vigorelli, CAAD 10, Giant FastRoad CoMax 1, C-Dale Quick 1
Quoted: 50 Post(s)
Liked 36 Times
The straps on some of my helmets are really grungy. What about the dishwasher? Anybody ever done that?
Quoted: 4806 Post(s)
Liked 3,928 Times
I wouldn't but have never tired it. I fill my bathroom sink about half way, add some laundry detergent, put the helmet in upside down and massage some soapy water into the foam pads, flip over, massage the straps and let the helmet soak overnight with the pads in the detergent water. Rinse in the morning. tamp with a clean towel and hang to dry. Not a whole lot of work.
A trick to keep your helmet cleaner and smelling nicer - wear a cycling skull cap under it. I wear the Pace caps year 'round, leaving for every ride with a clean one. Doesn't help the straps, but makes the rest a lot more pleasant and the foam pads last longer.
Ben
Ben
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Probably can't hurt.. though I wouldn't try unless this is a last ditch effort to save the helmet anyway before buying a new one. Turn off the high heat drying option though.. ie. I'd try the "crystal" setting if your machine offers it. Also consider taking out (for most helmets) the removable velcro pads.
What's wrong with washing under the bathroom/kitchen faucet, with a little soap?
Expired Member
Quoted: 3672 Post(s)
Liked 5,430 Times
I spray Oxy cleaner on the straps and pads, let it sit awhile, then rinse. It really does get the stink out. Also use it in the washer with the bike clothes.
Non omnino gravis
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Just let it get crusty and then crunch up the straps and collect the flakes. Makes good eatin'
Likes For Cyclist0108:
Likes For Dirt Farmer:
Bikes: 2017 Ribble CX5
Quoted: 704 Post(s)
The heat during the wash cycle cannot be good for the foam helmet or the adhesives used. I wouldn't do it. Too much risk just to save yourself a little work washing by hand.
Bikes: Cannondale CAADX
Quoted: 132 Post(s)
Bikes: Mongoose Reform Sport
Quoted: 34 Post(s)
Put it in a sink with water and a little hair shampoo. I do the same with my motorcycle helmet with out immersing it in the sink . I used a Microfiber cloth for the EPS foam in my helmet.
Quoted: 34 Post(s)
Be careful some chemicals with attack the EPS Foam that the helmet is made out of .
Quoted: 132 Post(s)
Ohhh I see. Ours allows us to choose between "cold," "mild," and "hot." I assumed they all were similar. My apologies.
Heat of dishwasher would probably loosen anything that is held in place by adhesive. Which could include foam pads, decals, and the entire plastic shell. I think most dishwashers are plumbed into the hot water line only with no option for cold. I wash mine outside in a 5 gallon pail with soap and a bit of bleach.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
5-gallon bucket with warm water and a dribble of detergent. Slosh around a bit and let soak for a couple of minutes. Rinse with garden hose. Works great for me and I do my gloves at the same time.
Bikes: Giant ToughRoad Giant talon
Quoted: 705 Post(s)
Water may get between the Styrofoam and the plastic cover, dribble out at a most inconvenient time.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Just bring it into the shower with you once in a while, along with your heart rate monitor strap. Hang on the towel rack to dry. Done.
If you are worried about the helmet then remove the straps and pads.
Done.
Done.
Quoted: 18415 Post(s)
Liked 15,539 Times
*smh*
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
Not really sure I see issue with it. Assuming you use a cool water cycle, or that your water tank isn't set to scald. Water only shouldn't cause a problem at all. You wear in the rain without it "falling apart".
I use the dishwasher to clean paintball masks. Doesn't do anything to the foam around the lenses or the seal between, straps hold up fine and hold elastic.
Fredly Fredster
The skullcap mentioned earlier helps a lot. I've never washed my helmets. They don't stink, but I'm not a heavy sweater. People who sweat buckets probably do have issues with helmet funk.
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
I don't like the idea of washing non-food items in my dishwasher, or kitchen sink for that matter. I won't bathe babies or pets in the kitchen sink either. Or dump out the dirty water from the carpet shampoo machine into the sink (like they do in the ad on TV). No way. I've even seen suggestions to wash small engine parts in the dishwasher or bake heat-proof or heat-setting paint in the oven - nope. I'd wash those icky things in the laundry sink or outdoors in a bucket. Helmet? Probably time for a new one, anyway.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
