Bike stems: cost vs quality, reliability, performance
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
I’m looking into some shorter stems, seen some priced $150 (Industry 9) and some priced $20 range (Amazon) that don’t look a lot different in functionality. Bonus points for style though.
So what are the major differences? Cheap Chinese aluminum vs American CNC aircraft grade? Is there more than meets the eye here I don’t know? Is there a solid middle ground anyone would recommend?
does the old saying “you get what you pay for” apply here or not?
thanks in advance.
thanks in advance.
Likes For Toadmeister:
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
Well, having the stem break is about the worst thing that could happen on a bike and it does happen on cheaper bikes. Probably don't need the 150 buck titanium option but I would not cheap out either. In fact, I would try and keep it stock if possible, and see if you can just change the handlebars instead. Probably possible to kill yourself with a bad handlebar/install but I doubt it's likely.
Liked 2,968 Times
composite or casted materials I'd go with a known reputable brand. CNC shouldn't be an issue, but be aware that a seller/brand might bring about other issues. If they/it hasn't been established & is way underpriced to other ones, it might be too good to be true [scam] .
-Oh Hey!
-Oh Hey!
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I think i have a aluminum 70mm and carbon 90mm I can part with. PM me if that's what you're looking for,
Likes For woodcraft:
Quoted: 198 Post(s)
Liked 332 Times
Certainly I have a history of being abusive and breaking things. . I place durability and robustness above all.
I’m not concerned with weight, I don’t count grams when I’m a Clydesdale who needs to loose many pounds! LOL.
Non omnino gravis
IME, the sweet spot for stems seems to be in the $40-50 range. Above that is bling, below that is (often) clunk. I've spent more (driven by the overwhelming desire to matchy-match) but they all work about the same.
I'ev never bought any of the bizarrely named Chinese alloy stems, though-- no reason, when something like a Kalloy is $20 and a ControlTech is $40. Heck, I got a Whisky for $40 recently.
Seems like in the really short stems (that is, MTB stems, 60mm and shorter) pretty much all start in the $40-50 area, including RaceFace, Spank, Truvativ, etc. Answer has a couple of stems ~$25.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
thanks in advance.
thanks in advance.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 645 Post(s)
Liked 797 Times
thanks in advance.
thanks in advance.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
For any given design and material, a forged stem will be stronger than a CNC'ed stem.
Quoted: 198 Post(s)
Liked 332 Times
No, Keith Bontrager’s old saying...”Cheap, light, durable. Pick two.”...comes into play. Inexpensive stems work well enough and I wouldn’t worry about their safety. They just aren’t very light. Expensive stems are strong and light but, well, expensive. If you are trying to find a length of stem that you want, it’s best to go with the cheap one. If you want something nice, go expensive.
For $10 I ordered a cheapo from Amazon just to try it out. If I don’t like it it will just get tossed into the spares box. I’ll pay more for something I really like if I figure out exact what I want.
BTW I have an adjustable stem today on my gravel bike and it falls into the cheap category, it does squeak a bit. Been using it a couple years now and it’s ready to be trashed before it fails!
Quoted: 4227 Post(s)
Liked 2,488 Times
I have some more expensive stems made by Thomson and Race Face and I also have some cheap no name brand stems. TBH I don't notice any difference in performance between them. I never had any stem break on me yet even under hard riding conditions, so I don't know how much difference there is in durability between cheap and expensive stems...The most important thing when it comes to stems is to make sure that your bolts are tightened correctly. Stem bolts is one place where I would consider using a torque wrench. I've installed many stems without torque wrench but using torque wrench gives me that extra peace of mind. Majority of stem failures are the result of user error and incorrect installation. A lot of people have absolutely no attention to detail and fail to realize the importance of installing components correctly. Components which have been installed incorrectly are much more likely to fail.
Likes For wolfchild:
Sunshine
Quoted: 10960 Post(s)
Liked 7,487 Times
often times yes, but for stems I don't think so.
A Kalloy Uno 7 stem on ebay only costs $25 and is lighter than any other stem ive seen. They are 4 bolt, well finished, light, and inexpensive. Keith Bontrager can pout about it.
The graphics are annoying, but 15 seconds of rubbing with nail polish remover leaves the stem simple and black.
I have Uno 7 stems on road bikes and my gravel bike- can't imagine paying more for a heavier stem unless its because I suddenly have to match the cockpit...but thankfully I've never felt compelled to do that.
Likes For mstateglfr:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
thanks in advance.
thanks in advance.
I've had good luck with 'house brands' like Oval (Spesh) Bontrager (Trek) and CODA ('Dale) as you can usually find those as 'take-offs' or overstock for really cheap.
I had a shop (not sure if it's there anymore ) that had a $5 bin, of stems that had been swapped during bike fits. I got two Ovals and a Salsa for $20 all-in, in different lengths when i re-did the cockpit on one of my road bikes, so I could keep swapping until i hit the right fit.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,990 Times
If it's one of those direct-ship cheapo's with the nonsense-names, it'll be a roll of the dice, although an aluminum threadless stem is a pretty simple component, you have to try pretty hard to get it wrong.
I don't waste time with cheap no name stuff. You don't have to buy the most expensive stem but there can be benefits from either stiffness, less weight or maybe more flex (if you want that) or more strength and stability. In some cases you are paying for nice anodizing and the fact it is Made in 'Merica by people who enjoy their jobs and are generally getting paid a little better and I don't mind that.
Quoted: 822 Post(s)
Liked 1,960 Times
I recently purchased and swapped a Nitto Quill Stem onto my Peloton. Really sharp looking and forged aluminum for $45. Fits perfect and no problems.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Quoted: 1109 Post(s)
Liked 1,200 Times
thanks in advance.
thanks in advance.
That said, I recommend you look on EBay and buy "name brand" used stems. There's a million of them because stems are something that a lot of people experiment with and sell. I've bought and sold a gazillion used stems on Ebay. I have absolutely no worries about a name brand stem. It's easy to see if it's been crashed or damaged.
Frankly I don't worry too much about cheap generic stems either. There's several fairly common brands that are cheap (but heavy) that I have no worries about buying either. Also available on eBay.
FWIW - comparing EBay to Amazon. These days, I've found EBay to be totally reliable as far as expected shipping time. The pandemic has not affected an individual or small operator to fulfill through eBay sales. Shipping times have been totally normal. Amazon has been HORRIBLE lately. I believe the fact that they operate out of large warehouses has really degraded their fulfillment. I've had small items that should - at worst - be received in 2-5 days take 3+ weeks to arrive. Haven't seen any of that with eBay sales.
Likes For Camilo:
Quoted: 198 Post(s)
Liked 332 Times
The old durable, lightweight, cost equation applies.
I’ve bought Lots of specialty bike tools lately this way from LBS within 200 miles. They usually show up in my mailbox 3-5 days.
Quoted: 7652 Post(s)
Liked 3,473 Times
A Kalloy Uno 7 stem on ebay only costs $25 and is lighter than any other stem ive seen. They are 4 bolt, well finished, light, and inexpensive. ...
Likes For Maelochs:
Likes For 2old:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I would not cheap out on a CF stem (TBH, they seem silly to me anyway), but i don’t think twice about cheap Al stems. With the amount of tweaking I do with fit, cheap is good, and functionally I have found zero difference between cheap stems (Kalloy Uno and Dimension) vs expensive (Thomson). As long as they are 4-bolt faceplates, I’m happy.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
I have ordered these stems from eBay:
https://www.ebay.com/itm/224467814348?var=523251044300
Cheap carbon stems and used them on both my MTB and my road bike. Pretty lite and have held up to all sorts of abuse. I use a 60mm version on my 26" "huck" it MTB, a 70mm on my 29er and a 110mm version on my road bike.
Run these for over 5 years without issue. Would never spend big bucks on a stem again.
Quoted: 4806 Post(s)
Liked 3,928 Times
Question, John - are the Ritchie stems forged? (I bought one for my ti custom; 12mm -17. Had the builder make me an identical ti custom with our $$ gift from China through GW.)
Yeah. Cheap(ish) doesn't mean garbage. A stem is a basic item that shouldn't cost a lot. Id be more suspicious about super light weight, exotic materials, boutique stuff. If its for a carbon fork id rather not get a stem with most of the clamp cut out. They do tend to dent the carbon.
