Front wheel play after replacing bearings
I replaced my sealed bearings with some new ones but my front wheel play remains so at this point I think the play is in between my hub and the fork because my hub is 1 mm to small or my axle to wide or a combination.
Roval wheel set in a salsa cutthroat 2020 with a stiff fork
What do you guys think?
And how to fix it, try some spacers?
Replace the end caps?
Quoted: 6193 Post(s)
Liked 4,809 Times
I would go back and find out why you have the play first. Measure the new and old parts and find out where the difference is. If I couldn't find anything thing different, then I'd have to ask if I'm installing something incorrectly. This bike has a thru-axle and I only have one bike with a thru-axle, so I don't have enough dealings with them to say anything about adding spacers willy nilly as I have on bikes with skewers and solid axles.
Blamester
2020 bike and wheels?
Look closely to see where it is moving.
Take your time.
Is there a difference between one side of the hub and the other side?
Google image a photo of the hub see can you spot anything.
Is it the same installation as the rear?
See if something is different.
Take your time.
mechanically sound
Is it possible the roval hubs use a different thru-axle system from the fork? (assuming those wheels didn’t come with the bike.)
Take your time.
Take your time.
No in front I have sealed bearings and in the back cup and come.
I have put spacers on different places:
When between inside fork and the end caps play seams a little bit less but still existing, when put on the thru-axle before installing (between the inbus hole and left outside fork) they play remains the same.
One other thing every time the front wheel is put back in the bike the play is gone till I ride it and after the ride one's the play is back the axle is still tight.
The bike is from 2020 the wheels are a probably 1 or 2 year's older but both boost.
The play didn't exist for the first 1000 km but became more and more especially after a really heavy trail in italy.
The wheels didn't come with the bike but they should both be boost sized(what is confirmed bye the wheel and fork sliding in a perfect fit in to one a other) thru axle different since they are often specific for that bike but should be a universal fit for thru-axle wheels aside from the old school non-boost and the newer boost sizes. (I use the original thru-axle that came with the bike)
Liked 4,809 Times
All your stuff is made for the same thru-axle diameter? If you have something made for a 15 mm thru-axle with a bike that has a 12 mm thru-axle, then you'll have play.
I'd check your new stuff with calipers even if the label says the correct diameter. Mistakes happen in packaging and elsewhere sometimes.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I can't see the play from here. It's up to the OP to determine where the play is......and it's right in front of him.
Likes For trailangel:
All wheels have some method to adjust play. Are you saying that you've run out of adjustment?
There is definitely not a 3 mm gap. besides the old and new sealed bearing cartridges where the same and I run these wheels with out any problem for a few thousand km
