Spoke length fudge factor
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I have a Kinlin rim with 285 ERD. I measured it myself. The spokes all go top nipple and frankly I am a bit surprised they were not too long but the wheel tensions up fine not issue. I want to replace that rim and use another Kinlin that has ERD of 588. Will that work to you think and I am reusing the spokes of course than the nipples as 14mm. I don't want to buy new spokes because at some point just buy another wheel is a better option. I would just like to have the spare wheel and the hub is fine.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
plug the numbers from the previous hub into a spoke calculator. how much longer of spokes do you technically need for new rim? 3mm of ERD is not a lot, so it's likely just fine. I would think that would mean your spokes are within 1.5mm of long enough. if you're pushing pat 2mm of too short, you might want different spokes. I'd do the calculation first.
don't use longer nipples to make spokes that come up short "long enough." that's a lousy kludge for amateurs who don't care about doing things right the first time so they last.
Quoted: 336 Post(s)
Liked 309 Times
Likes For aggiegrads:
Quoted: 399 Post(s)
Liked 185 Times
I already have the 14mm nipples that is with the current spokes I am using. I fully understand the issue of 12 vs 14 mm nipples. I just was asking about fudge factor on spoke length. I think it would work but now no sure if the rims are actually 588 ERD. The manufactures are not consistent with this and always best to measure yourself regardless.
Really Old Senior Member
285 ERD? Did you mean 585?
Assuming so AND your new rim is 588, it'll basically make your spokes seem 1.5mm shorter.
"The spokes all go top nipple..."Do you mean the top of the nipple or to the screw driver slot?
IF the top of the nipple, your spokes should fit the "larger" rim better.
Crap in, crap out.
Crap in, crap out.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
It depends on the brand...
If you go to DT Swiss spoke calculator and run the same rim/hub measurements with 12mm, 14mm and 16mm nipples, you will see that the 14mm one needs a 1mm shorter spoke compared to 12mm, and 1 more mm shorter for 16mm. I snatched this figure somewhere quite a while ago:
DT Swiss nipples
-- for every 2mm of length they add 1mm of thread.
This is not the case for Sapim and others, those probably follow what mack_turtle and aggiegrads say. So if you have 14mm Sapim nipples going to 14/16mm DT Swiss may get you extra 1/2mm. I understand the problem with the nipple breakage at the head, but we should probably ask DT Swiss engineers about it
Also, there is a database of ERDs and some other data: Browse Rim Database | Freespoke - may be of some use for you.
Quoted: 1074 Post(s)
Liked 295 Times
I’ve seen that pic too, and it has made me wonder.
It seems very difficult to build a wheel with the precision needed to get full thread engagement in the head using their 16 mm nipples. You’d need to hit required tension and bottom out pretty much simultaneously.
and then what about later trueing? You’d be left with a one-way margin.
Now, the bike biz has certainly had its moments of less than brilliant engineering, so maybe this is DT’s contribution to the hall of shame.
Or full head thread engagement isn’t as important as conventional wisdom would have us believe.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
Would that be to measure ERD and calculate spoke length to meet bottom of slot? I then round up to nearest 2mm since I always use double wall rims, and so ok if a little spoke protrudes. The video by Bill Mould on spoke position in nipple is also good.
Likes For IPassGas:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
So, yes, you could use 14, or 16 mm long DT Swiss, or SAPIM nipples, and for all the measurement purposes, it will be analog to using 1, or 2 mm longer spokes, respectively.
However, that will also result in the top part of the nipple (outer most) not being supported with the spoke inside of it. And can cause even good quality brass nipples to break off. Experienced something just like that (4th chapter talks about the failure):
Custom built wheel with spokes too short
